Question about Honeywell ER150B Air Conditioner
No cold air....external fan blowing....line between furnace and compressor unit is cold (with ice on it)and dripping water
  • 674 Answers
Check your air filters and replace if necessary. Check the indoor and outdoor coils and clean if needed. If the line is still is freezing get the refrigerant charge checked.
Posted on May 03, 2010
Not staying cool
sounds like it is either low on Freon or the compressor is going out. The blowing ice cold is an indicator that it may be freezing up because the low Freon. when it stops blowing cold, turn it to fan only mode and see if it gets colder again. If that is the case then the unit is low on freon and freezing up. I know that sounds confusing but that is how AC works. The low freon pressure means the gas is expanding too fast and the air flow cannot take up the cold from the evaporator fast enough. Turning the compressor off and keeping the fan on will alow the room air to take up the cold.
Apr 22, 2014 | Frigidaire FAM157S1A Air Conditioner
My dehumidier blows very hot air while working. Makes it hotter than it was before starting. Like a furnace.
It is normal for a dehumidifier to discharge warm air. A dehumidifier is really an air conditioner - a fan blows humid room air across a cold fin coil that causes the moisture to condense on it and drip into a container - thus cooling AND dehumidifying the air. The cool air is blown over the warm coil and discharged out the back. A dehumidifier WILL normally increase the temperature of the room it is in.
You can do the same thing with sitting an A/C unit on a stool in a room. Room air will be drawn in, cold air will come out the front, hot air out the back and water will drip on the floor. And, the room will get hotter, due to what is called "heat of compression" even though you're running an A/C unit.
Jun 26, 2013 | Windchaser WDH928 Dehumidifier
GE( 2-door) ref portion door left open the whole night,it's not working now except the freezer. Tried unplugging it for 24 hrs, but still not working.
the air ducts could still have ice in them,remove the bottom kick panel,you should find a tech sheet either on the kick panel or taped in the cabinet area down there and it will tell you how to manually put your fridge into defrost, you don't want to work on it while it's running or you'll make it worse,you'll know it's in defrost when the compressor shuts down and the fan in the freezer stops blowing if you can't find it shut down the fridge or unplug it again,remove the food from the freezer,if you're handy remove the back inside wall of the freezer and with a hair dryer melt out any ice up in the vents and blow the air from the hair dryer up above the fan motor and in the corners, ,you'll see water dripping where the ice is,heat it up until no more water drips down,hit one side for a few minutes and then the other side for like 5 minutes at a time so you don't damage anything from heating it up to much,or if you have another fridge leave it unplugged for a couple of days.if you can't remove the wall blow the air into the air slots in the back wall panel,in the right and left side corners and then in the middle,have a light or flash light,you should be able to see water dripping down,keep blowing the air in until no more water is dripping,might take you like 30 to 45 minutes to do this,then turn it back on and see if you can feel cold air blowing into the fridge section,if not shut it down and heat it up again,if you see water dripping there's still ice in there,all that happens is the evaporator coil in the freezer gets cold,the evap fan blows the cold air up nto the fridge section and the air returns to the freezer through the air ducts,when the door was open warm and cold air meet and forms ice in the air ducts,if the fan is working and depending on your model and next time you write send the model number you could have a damper it could of got damaged but it sounds like all you have is frozen air ducts
Aug 25, 2012 | GE Refrigerators
Carrier A/C unit not cooling..but freezing refrigerant tube.
if the fan isnt running or you dont get enough return air (on the furnace) the coil will freeze up or if you have it set too low it will freeze up overnight, make sure your filters are clean, and that you dont have any return vents (air sucking in) covered with rugs and whatnot. If you have animals, the coil (on top of the furnace) could be clogged with hair, even though you change your filters it still gets clogged with hair and must be cleaned. if your coil was froze up you need to make sure it is completely thawed out, run the fan in the on setting with the a/c off until you dont see or hear any more water then turn it on again. and finially make sure when the furnace goes off (thermostat clicks and is satisfied) the outdoor condenser goes off as well the contactor could have been stuck in the on position. if you cant fix it call someone who can when your coil freezez up it can cause slugging in your compressor (liquid entering the compressor) which will destroy it !!!!!!!!!!!
Jul 20, 2010 | Heating & Cooling
The aircondition is on and blowing hot air,the fan
Have you checked your filters to make sure they are not dirty? Is the Insulated suction line starting to get
covered in ice? Is the indoore coil Iced up?
If yes, turn furnace off, try and change the filters,leave
unit off for awhile while it unthaws and try it a few hours later.
Jun 24, 2010 | Heating & Cooling
My unit is running but not blowing cool air. I went outside and the condenor fan was not moving. Took a stick and shoved a blade and the fan started moving but the air is still not cool inside. I did...
Sometimes on new units it is common for the fan to not start until you give it a push. Did you happen to hear if the compressor was operating? If the unit was froze-up the Insulated Suction line would also be iced over as well. If it wasn`t it is more likely that either the compressor was not operating or it shutoff due to
high discharge pressure and can only be reset on its
own or cooling the compressor off with cold water.
Jun 15, 2010 | Carrier 38CKC024 Air Conditioner
Honeywell HE260 leaks somewhere
Neither, even if the solenoid or humidistat stick, it should always drain properly. Is the unit mounted on the cold air return duct or the supply plenum? If it's mounted on the supply plenum, the water panel might be getting blown forward and spilling the water. High efficient furnaces also can leak water on the floor if its drain is restricted. If hum. is mounted on return duct make sure drain is clear by blowing through it. On Honeywell hum's I've seen the rubber hose from the solenoid valve to the distributor tray leak too, check the rubber 1/4" hose.
Dec 28, 2009 | Honeywell HE260A1010 Whole House...
My ruud silhouette ii gas furnace is blowing regular air. i know nothing about a/c? is it freon?
Check outside unit to see if it is working. If fan is blowing outside put your hand over unit to see if air is warm. If outside unit is running and air is cool. Low on gas or compressor not running. You need to call a service tech to check it out. Also check the brreaker on outside unit. Russ
Jul 23, 2009 | Heating & Cooling
Uotside unit blowing cool air but hot on the inside
It sounds like you have a unit called a heat pump. When a heat pump unit is in cooling mode the outside unit blows hot air and the inside unit blows cold air. If the outside unit is blowing cold then the indoor unit is most likely blowing room temperature or warm air. It sounds like the thermostat could be controlling incorrectly or you could have a failed reversing valve which is the device that switches the unit from heating to cooling mode.
May 31, 2009 | Ruud UBHC Air Conditioner
Friedrich air conditioning - inside unit ice build up
Hi, Reduced air flow, low on freon or being continuously run during cooler weather such as at night. Some people turn their thermostat on 60 thinking that it will help get it cooler faster. They freeze up at night and don't get a chance to thaw during the day. It needs set no lower than 75 or so. The evaporator may be dirty. Don't know a lot about your particular unit but if the outside unit has the compressor and refrigerant lines running to it, The large refrigerant line should sweat all the way to the compressor if its fully charged. Please rate me if I have helped. Good luck kstfas
Aug 28, 2007 | Friedrich M18CF Split System Air...
Honeywell ER150B Air Conditioner Logo
168 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
