Question about Sony Playstation 3 (PS3) Console
GAME FREEZES AND DONOT READ DISC AFTER - Sony Playstation 3 (PS3) Console
    President:
  • 1,469 Answers
You can try the steps below. Its from PlayStation Forum:
1. Turn off Playstation®3.
2. Hold the power button down; the system will turn on and turn off once again.
3. Once the System has been shutdown, re-press you finger until you hear 2 consecutive beeps
4. When you hear the 2 beeps take finger off power button.
5. You will be prompted to plug in your controller via USB and then hit the PS button
6. The Recovery menu will pop up.
The current Recovery Menu supports:
• Restart System: Restarts the PLAYSTATION®3 System.
• Restore Default Settings: Reset all system settings back to default.
• Restore File System: Checks for corrupt/missing system files.
• Rebuild Database: Rebuilds the OS for the PLAYSTATION®3.
• Restore PS3 System: Fresh restore; Deletes everything and starts from Scratch.
• System Update: Update the PLAYSTATION®3 System
If the above steps still does not solve the problem, then I think will have to update your Ps3.
Update your PS3 (in the settings menu the 1st option).
Go on the internet browser on the PS3 then go on the menu press triangle then on one of them there are delete cookies and the delete the others as
well as cookies.
You could also try this as well: put the PS3 on then press the eject button (with no disc in) then hold it and switch the PS3 off at the back with your finger on the eject button still holding it, then put it back on and the fan test should be working this may cool it down. It might be over heating.
But if your problem is not still solved, then maybe you should call sony for further assistance.
I wish you good luck.
Posted on May 03, 2010
4 Suggested Answers
  • 11 Answers
SOURCE: disc read error clean disc
The laser hasn't necessarily failed. This has happened to me in the past with certain games. I solved this problem by deleting the Xbox 360 cache. This can also solve various other problems on the console.
Clearing the cache removes all game updates which means you have to download them again but it WILL NOT remove your save games and your content so it's safe.
To clear the cache, do the following:
1. Go to the System Tab and select Storage Devices.
2. Highlight your HDD and press Y for options.
3. Enter the following button sequence: X, X, LB, RB, X, X.
4. When the system asks if you want to perform maintenance, choose yes.
5. Now restart your console.
If this doesn't work I'm not sure what to suggest, it probably is a hardware fault.
Hope this helps a little.
Posted on Nov 16, 2009
  • 1093 Answers
SOURCE: XBOX can't read game. Cleaned disc but still get
If your Xbox 360 is not reading games this is because the sensors on the back of the drive have overheated, you need to stop the heat build up.
The good news is that you can use a good repair guide to fix it yourself or you can send it in.
Posted on Dec 31, 2009
SOURCE: wont read game disc but
This is the 2nd most common problem with PS3's. This isn't a bad problem. Your laser/lens will need to be replaced. Do you see the time clock in the top right corner going around and around? If so, you are just having laser/lens problems. If you do not see the time icon spinning when you insert a disc, your PS3's Blu Ray drive controller board has gone bad and you will need to send it to Sony and not a
3rd party technician. Certain problems are only repairable by Sony. Good luck.
Posted on Jan 20, 2011
Nba 2k11 freezes in the middle of the game and if it doesnt freeze the volume goes out and you can only hear the crowd.
It sounds like the system is having problems reading the disc. If this is the only game it happens with, then the game disc might be bad. If it happens with multiple games, there might be a problem with your PS3's disc drive.
Mar 16, 2011 | Sony PlayStation® 3 (60 GB) Console
My PS3 is 3 yrs old never had a problem till last week when my blu-ray discs started freezing and then noticed games freezing also. So now we do not use it. We get a invalid disc error with blu-rays and...
Well from what i hear it is just that the laser inside the ps3 that reads the disc could be damaged, dirty, or even not in the right spot. sometimes the read laser that reads the disc can move from on spot to another if you hit the ps3 or if it falls (ETC).
Nov 20, 2010 | Sony Playstation 3 (PS3) Console
My game keeps freezing up, what is the problem and can it be fixed?
Hi. There are many possibilities why PS3 keeps freezing up to a certain point of time. First is, this could be a game disc issue. Ifthis happened to a certain game disc only then probably you might have a purchased a bad game disc. Second is, lens problem. might be the lens is getting hard time reading the disc and needs replacement.
Sep 13, 2010 | Sony Playstation 3 (PS3) Console
Won't play ps2 games
take the Ps2 gaming console to nearest Sony service center the problem is with lens it sometimes run quiet well but sometimes got hang you can do one little thing & try it take any of the Ps2 games which are getting freeze while playing take Colgate toothpaste the regular one take a little bit of it & apply on the game disc rub it on the disc & then clean & wipe out with a clean smooth cloth & clean properly after cleaning the disc will look good neat in condition but please make sure no particle is left after cleaning & now play the disc on Ps2 & see if it still get freeze then their is a problem with console better check it at nearest Sony service center for trouble free working
Jun 29, 2010 | Sony PlayStation 2 Slimline Console
Ps3 40gb wont read disc
Contact Sony @ 1-877-253-SONY to request an RMA for your machine, this is a common issue and you should get a new machine.
Sep 02, 2008 | Sony Playstation 3 (PS3) Console
PS3 having trouble reading game discs!!!
hey guys. the problem is that the blue ray reader is some how broken and it won't work. mine kept freezing during games like after 3 mins. and it wouldnt read any more discs for that day. you need to change the blue ray reader and that costs about 175$. thats alot of money and its probably not worth it.
Apr 06, 2008 | Sony Playstation 3 (PS3) Console
Un able to read disc, freezing
try holding the A button when booting.This clears the cach. worked for me .when i got the unable to read disc error.
Dec 28, 2007 | Microsoft Xbox 360 Console
Sony Playstation 3 (PS3) Console Logo
61 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
