Question about Apple MacBook Pro Notebook
How difficult is it to replace a CD-ROM drive in a MacBook Pro?
MacBook Pro has been reformated, but when I go to reinstall the software, the cd-rom does not appear to be working. How difficult is it to replace a cd-rom drive? Specs - http://www.everymac.com/systems/apple/macbook_pro/stats/macbook_pro_2.16_17.html
    Sergeant:
    Novelist:
  • 172 Answers
Hello, It's quite simplel, you just have to remove the screws underneath, remove the ram, and then the screws around the laptop. Then open the upper case.
Do not do it. The case is attached to the logic board via a ribbon cable.
Lift up the back of the case and work your fingers along the sides, freeing the case as you go. Once you have freed the sides, you may need to rock the case up and down to free the front of the upper case.
Then remove the data and screws from the optical bay and that is it.
I hope this helps.
Posted on May 03, 2010
    Problem Solver:
  • 16 Answers
It is very difficult to replace an Apple Superdrive and is not recommended to attempt to do so yourself unless you have pre-existing experience in doing so. Before resorting to such desperate measures, try testing your hardware with the Apple Hardware Test. You will find detailed instructions on how to use AHT here.
Why does cd rom not conned to my macbook?
I'm not sure about this, because I have an internal CD/DVD in my macbook. But this can be a driver issue. Do you have an Apple CD drive, or an universal USB CD drive? The last one could be very tricky, because the computer needs special drivers, so it can recognise the external drive.
Jun 06, 2014 | Apple MacBook Pro Laptop Computer with...
Cd rom does not run cd
Does your OS detect the drive ? Does it read DVDs or nothing at all ? try removing it and reinstalling it or use an external USB CD-ROM drive in the meantime.
Nov 20, 2012 | Computers & Internet
My macbook pro 13.3 will not print anything from the canon MF4300/D300 printer. What do I do?
Make sure you have installed the MAC drivers correctly from the CD-ROM. Connect the cables and leave the printer "OFF." Then insert the CD-ROM into the PC and follow the installation instructions to the letter. Reboot the computer and try it out. Also, go to the Canon support site to see if there are updated MAC drivers and software for this model. Install the updated drivers and then any software that came with the installation CD-Rom.
Aug 27, 2012 | Canon ImageCLASS MF4350d Laser All-in-One ...
Hello i want buy solution cd-rom driver..... my
your drivers may have been corrupted or you might have a virus run your antivrus program
you might have to physically unplug the leads for this cd-rom then plug them back in this should activate the found new hardware wizard or
you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device
click start control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you will see options to update driver,roll back driver,or
select properties you will have options under general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
Jan 16, 2011 | Dell (074JH) Internal 48x CD-ROM Drive
I can not get my Cd Rom to read a disk
make sure that the cd rom is getting enough power test all leads that are attached to the cd rom including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
you might have to physically unplug the leads for this cd rom then plug them back in this will activate found new hardware wizard or
you might have to uninstall then reinstall your cd rom or uninstall the driver then reinstall for this device
control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
hope this helps
Nov 26, 2010 | Acer (91.47A37.001) CD-ROM Drive
Cd drive wont open
hope this helps
Nov 25, 2010 | E-Machines emachines (emachinees) CD-ROM...
The fact that you realized replacement might be the best option and sought out advice tells me you are intelligent by nature. On a difficulty scale of 1-10 I would rate this in the 6-7 range. Someone like you would probably have very little trouble with this project. I have sent countless step by step instructions over the internet & through email but it seems like the best results always come from an in-depth tutorial, This way you can see EVERY step and even rewind if you're not sure about something. Powerbookmedic.com has a wonderful tutorial on the 17" MacBook Pro breakdown and optical drive (cd/dvd) removal. Just remember to always start with taking the battery out and be very careful about electrostatic shock. You should be fine on a hard surface but I don't recommend fabric/carpet surfaces once you open it up. Here is the link for your laptop. The videos will play in succession automatically. Good luck, you'll do just fine! If you run into trouble, just message back and I will be glad to walk you through it: http://www.everymac.com/systems/apple/macbook_pro/stats/macbook_pro_2.16_17.html
May 03, 2010 | LG SecurDisc 8x External Double-Layer DVD...
Difficulty to open cd rom o my pc how to solve?
Repairing your Optical Drive problem isn’t that difficult task.
Unfortunately you have failed to prove the Manufacturer Name and Model Number of your particular specific CD-ROM Optical Drive so I am unaware of what particular specific CD-ROM Optical Drive information to provide.
However if you use Google Search (http://www.google.com) and search the topic Repair CD-ROM you will be able to obtain information on how to disassemble and repair your specific CD-ROM Optical Drive. Examples of a Google Search are provided below ->
http://www.repairfaq.org/sam/cdfaq.htm
http://repair4laptop.org/notebook_op...cd_dvd_mo.html
http://www.repairfaq.org/REPAIR/F_cdfaq9.html
The most difficult part of the repair will be finding the correct size replacement 0-Ring that fits your particular specific CD-ROM Optical Drive. You could try checking with local Computer Repair Shops and see if the have a broken CD/DVD Optical Drive that has the correct size 0-Ring that might work in your particular specific CD-ROM Optical Drive.
On another note now days Optical Drives are inexpensive and you can obtain a replacement CD/DVD Optical Drive for less than 30 bucks.
Hope it helped you. Thanks.
Apr 20, 2010 | Gateway 1MB 166MHZ Pentium Motherboard...
CD rom can't read CD XP
yes i think the cd rom is the problem ,use external cd drive for the re installation or you can use a flash disc
Jul 12, 2008 | Acer Aspire 4315 Notebook
Apple MacBook Pro Notebook Logo
172 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
