Question about KitchenAid 24 in. KUDI02IRBS Stainless Steel Built-in Dishwasher
Pump noise - KitchenAid 24 in. KUDI02IRBS Stainless Steel Built-in Dishwasher
    President:
  • 949 Answers
If the noise is present for about 2 minutes at a time then goes away then the issues could be with the drain pump.
If the noise is there for most of the wash and rinse cycle could be the main bearing on the motor that is failing, this is due to a leaking main seal, if this the case you would need to replace the pump and motor assembly. This same noise could also be from food or other debris stuck around the chopper area that can be cleaned out. I have put together some instructions on how to clean out the sump around the chopper if you are interested in trying. Here is the link.
http://www.fixya.com/support/r4628450-poor_cleaning_or_noisy_pump_whirlpool_or
Posted on May 03, 2010
Ive got power, hot and cold to my existing pump and shower, but the pump doesn't start, just makes a whirring noise.
Above Ground Pool Pump Won't Start or is Humming & How ...
? 6:16
https://www.youtube.com/watch?v=RH78q36liks
Apr 15, 2014 - Uploaded by Above Ground Pros
Above Ground Pool Pump Won't Start or is Humming & How to Fix It ... Pool Motor - Humming-Loud Noise ...
How to fix your pool pump from humming - YouTube
? 2:43
https://www.youtube.com/watch?v=3v2v6aDDq9A
Mar 25, 2013 - Uploaded by James Hayward
Do you have a pool pump not priming (pumping water) andmaking a humming noise ... not only give a ...
pool pump makes humming noise and does not pump - Trouble F
Dec 08, 2015 | Home
BUZZING NOISE FROM MY HEAT PUMP
Take a look at this YouTube page that explains with good videos what are some of the common problems with heat pump noise. The one that seems dominant is the defrost cycle a heat pump goes thru when it melts ice off the evaporative coils. In defrost cycle, The compressor runs but the cooling fan does not, so you will hear a loud buzzing sound and the unit sounds like it is stalled...because only the compressor is running to generate heat to melt coil ice.
https://www.youtube.com/results?search_query=American+Standard+5000+Heat+Pump+makes+a+buzzing+noise
Defrost cycle noise video:
https://www.youtube.com/watch?v=wudLk0WoIVo
Mar 06, 2015 | American Standard 5000 Heat Pump Unit
If the seals have gone will the car make a noise
You don't say which seals or which pump however via elimination if the oil seals have gone well yes you could have noise from damaged bearings ( most likely a whine or a grating sound). Water pump gone well sounds could start because of overheating, if bearing in water pump gone sometimes sounds like a rattle as impeller blades rub, Oil pump failure then yes as the engine struggles for lubrication you will hear plenty of noises ( Costly ones ) .If fuel pump fails they can make noise as they struggle to reach pressure but eventually will give out and your car will stop from fuel exhaustion. Whatever the reasons for this noise ( and you didn't make it clear where it's coming from or what type of noise ) you may want to get your car serviced, this may save you a whole lot of cash and maybe even your life, a car seizing up can cause a serious accident as everything locks up and you lose control if you can't check it out yourself seek a mechanic soon.
Sep 02, 2014 | 2001 Ford Focus
Pump or bearing problem?
If this is a top load maytag, the pump bearing sleeve will rub the pump pulley and make a grinding noise. Replace the pump.
Sep 26, 2013 | Maytag Washing Machines
Maytag MVAT346AWW
Remove the back lower left access panel. You will find the drain pump there. 95% of these problems that you have described is from the drain pump bearing going out. If possible, run the washer with this panel opened and listen to the pump. If the noise you hear is coming from there replace the pump with the new designed pump. Here is the pump to order. To replace the pump, tilt the washer back and remove the belt, then remove the two hoses from the pump and then the three screws that hold the pump on. If the pump is not the problem, post back to me.
Nov 16, 2012 | Washing Machines
Hi I have a magnum 1000 Jacuzzi pump for my
alot of companies use to have a damper ring on pump shaft which would knock down some of the noise a pump motor made pumps make noise and the bigger the pump the louder the noise if its not vibrating or clunking then its running as it should
Apr 21, 2010 | Jacuzzi MAGNUM FORCE POOL PUMP - TWO SPEED...
Fuel pump noise 2005 Buell xb9sx
That is the fuel pump doing its job of pumping. If it stops making noise, it stopped pumping, and no gas is getting into your motor. Your bike will not run without a running fuel pump. :)
Apr 14, 2010 | 2005 Buell Lightning CityX XB9SX
I have to replace the oil pump, but the mechanic said that after i replace the pump the engine might still make noise. what can cause the engine noise after i replace the pump? how can i fix it? its a 1987...
Why replace the oil pump? That won't make noises go away or cause noises. Your mechanic should be able to answer theses questions, as to the cause of noises.
Mar 10, 2010 | 1987 Ford Mustang
Air pump noise
air pump noise is common and in most cases it will last a very long time after it gets noisy. U can't buy parts for the air pump for this car, it is either a usd one or a rebuilt one, try A1Cardone, I am sure if they have your pump it is far less than $1000.00
Mar 31, 2009 | 1991 Mercedes-Benz 420
Noise when I turn my steering wheel.
If there is fluid in the pump and it makes noise, that may indicate that the pump is going bad. Some PS pumps just make noise. Ford pumps, for example make a lot of noise, and there is nothing wrong with them. If it's a squeal, it might mean the bearings in the pump are going bad.
Nov 07, 2008 | 2003 Honda Accord
KitchenAid 24 in. KUDI02IRBS Stainless Steel Built-in Dishwasher Logo
163 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
