The wash dial on my hotpoint wmf760 is not selecting
The wash dial on my hotpoint wmf760 is no longer clicking when turning and not selection cycles. Is their anything I can do to fix. Thanks
    President:
  • 1,430 Answers
The knob needs to be removed and the knob and the mating part will need to be replaced. The teeth on these parts wear off with time. There is a clip on the back of the knob that pulls off this holds the knob on. Then the mating piece will pull out. Eneter your model # at www.appliancehelponline.com for diagrams and illustrations. All parts come with installation instructions.
Posted on May 03, 2010
Washing machine not selecting cycles. It is stuck on fast wash, dial moves but wont click and select any other cycle.
Hi
the problem is the shaft on the control knob
is cracked so the knob turns but won't grip
the shaft on the control panel
requires an new knob
Jun 06, 2016 | Hotpoint Washing Machines
Hotpoint WMF760 wont fill with water..spin cycle not working either
replace the water inlet valve under the top cover from the manufactures website quoting the model nr eric
Jan 18, 2018 | Hotpoint Washing Machines
I have 'somehow' removed the tension spring that holds my washing machine seal in place... and i cant get it back in place. HELP!!! The model is hotpoint wmf760.
If you are talking about the door seal spring clip and you have difficulty in getting it to slide back in it's grove use a bit of washing up liquid in the groove and the ring. Is it not adjustable?
Dec 30, 2012 | Hotpoint Washing Machines
I have a new hotpoint aquarius washing machine, I put it on Cycle 1, and it stops before spin and I have to manually turn dial to B. is this correct thing to happen?
Make sure that you have selected a programme that does not have a spin, or a reduced or slow spin. if it spins o/k when you select 8, then it cannot be motor problem
Mar 01, 2010 | Washing Machines
I have an older Hotpoint topload washer that the dial just spins. I am unable to set a wash cycle now. The dial is pulled out to stop the wash cycle, pushed in to start and to select a cycle. Can the dial...
HI, this timer mechanism is damaged, and i recommend the replacement of this defective timer control module asap. it can be accessed by removing the cover that is located behind the control panel. the timer is screwed onto the panel from the backside.
replacing this timer control module will correct this issue.
Sep 18, 2009 | Washing Machines
Beko wma1510s washing machine dial problem
my beko wma 1510s will not spin and is heating up
Apr 11, 2009 | Washing Machines
Hot point wmlt80, dail clicking and turning, cycle wont start,
Yes, I work for GE what you need to do is to resent the appliance. Something should had happened with the computer of the washer. Just unplugged the machine for 40 seconds. You can unplugged or turn off the circuit breaker for 40 second and plugged back in. Select a normal cycle and let it run.
Jan 15, 2009 | Hotpoint WMTL80 Top Load Washer
Neff 5644 - how does it work!??
"e" is economy - ignore this there is a selection of spin speed - most people use the fastest half load is what it says - most people wash a full load so ignore the temp dial just selects wash temp. for normal washes set to 40deg can't remember the symbols on program dial but think they are fairly self-explanatory this machine is just a washer remember to check the filter regularly
Jun 14, 2007 | Neff W5340X0 Washer
Washing Machines Logo
1,137 people viewed this question
Top Washing Machines Experts
