Question about Life Fitness 9500HR Next Generation Remanufactured Treadmill
Had a technician come and work on the treadmill and he said the motherboard was bad and had to be sent back and reconditioned. Took the motherboard and now he is out of business. Is there anything that can be done?
    President:
  • Life Fitness Master
  • 832 Answers
Best place to start is to call Life Fitness and their # is 1-800-351-3737 they may have the board in stock keep your fingers crossed
Posted on May 05, 2010
Damaged sd card
Call them back and get a new SD.
Aug 18, 2016 | Nordic Track Exercise & Fitness
I recently bought a used Precor 954i it worked fine then when i brought it home and wired it in with a 20amp breaker and 240 volt im getting error 29 as soon as i turn the machine on any ideas?
Precor Error 29, Excessive AC Input Current Probable Cause 1. The running belt and/or deck are badly worn.
2. Bad lower PCA.
3. Drive motor is shorted or de-magnetized causing a high power demand.
Corrective Action
  1. Check the amp draw using a clamp on AC volt-amp meter during loaded and no load conditions and compare values to a similar treadmill that is known to have a good running belt and deck. Replace the belt and/or deck if necessary. Don't forget, some units have a double sided deck which means it may be flipped over rather than replaced if it has an unused side.
  2. Test unit with a known good lower PCA. Replace lower PCA if necessary.
  3. Test unit with a known good drive motor. Replace drive motor if necessary.
Precor Error Code 29 Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
Sep 22, 2015 | Precor 954i Experience Series Treadmill...
Belt won't start
Does the incline work? if so, the controller is most likely bad.
Feb 21, 2015 | Weslo Cadence G 5.9 Treadmill
Ryobi problems
This is not that bad of a problem we should be able to resolve this-
bring a lamp or radio which ever one you have used and know it works plug it into the wall outlet if your lamp or radio work then we know its the plug, now plug in yr Ryobi random orbital sander it should work to do not involve an extension cord while we are trouble shooting if neither have worked on the same plug you must have a 3 way light switch on the wall that needs to be turned on, try and slightly spread the the metal blades on yr Ryobi outward for a better contact between cord blades and wall plug make sure you have firmly pressed in the the on off switch.
Ryobi tests all of its factory reconditioned power tools before they are sent back to be sold in stores to the public...
Aug 10, 2014 | Ryobi Factory Reconditioned ZRRS290 2.6...
Track 5500 Treadmill problem
Dear Sir:
Please adjust the Reed switch, see the diagram below 1/8-1/4" 2) Tight very well the ribbon cable from key panel 3) Tigh the connector from display board vs the lower board(main motor board).4)main motor board.can be faulty. 5) However RUN your software utility for easy diagnose and troubleshooting. see the block diagram attached.
2_18_2012_5_06_16_pm.gifsincerely. God bless you.
ernesto cuadra
managua, nicaragua.
Feb 17, 2012 | Exercise & Fitness
None of the touch buttons work. Fans, volume, speed, incline etc etc. The only two buttons that work are incline buttons 6 & 7. Power comes on and key turns on and off though. Can anyone advise??
sorry but i dont have a solution for you!! i bought the t9ci back in nov of 2008, like you none of the buttons worked had to wait till march of 09 for nordictrack to send me a reprogram card, which did not fix the problem. i then recieved a new console, in april 09, which stopped working in feb 10. a service tech came out and had no clue, so the sent another new console which did not work. in march 10 they sent a whole brand new treadmill, and when i got on it last week the console was not working once again!!!!!!!!!!!!! i hope you dont have as many problems as i did
Nov 05, 2011 | Nordic Track NordicTrack T9 ci Treadmill
We purchased a reebok edge 2.2 treadmill about 3 weeks ago, a couple of nights ago the electic trip out whilst using the treadmill and since then the belt hasn't moved the display still works and counts...
i had the same problem, i beleive its the motor it may have burnt out.
only had it less than 4 weeks, argos sent a replacement treadmill and took the broken one away.
Feb 11, 2011 | Reebok 8000 ES Treadmill
As soon as the power supply was connected and switched on, the motherboard would power up and the fans would spin.. all hard drives/optical drives etc would turn on. But there was no post, or beeps, just a...
Sounds like you have a short in your display plug or the display itself.You also should try different or new ram sticks to eliminate ram as the cause.Try an external monitor also to see if there is any video showing.Technicians seem to always say the motherboard is bad to get the most money when the motherboard most of the time isn't bad its whats connected to it(ram,display,cd/dvd drives etc.
Jul 01, 2010 | Acer Aspire 3000 Notebook
Battery light still on after changing alternator and battery.
Did you check the fuses? Are your cables to the battery corroded? Is your ground wire connection clean . Did you get a cheap-*** alternator? Did they check it where you bought it? You may have to have it checked at a napa or other store. Sometimes "reconditioned" means "repainted"
Hey, I've been there. If its a discount store alternator get another place to check it. May save you some grief.
Jul 08, 2009 | 1999 GMC Sonoma
Life Fitness 9500HR Next Generation Remanufactured Treadmill Logo
99 people viewed this question
Top Life Fitness Exercise & Fitness Experts
Howard
Howard
Electro Med Services...
Matt Olenzek
Matt Olenzek
Are you a Life Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
