Question about Sony FD Trinitron WEGA KV-32FS120 32" TV
How do i take off the tv/video label? - Sony FD Trinitron WEGA KV-32FS120 32" TV
  • 566 Answers
Hi there
To answer your question;
If you have an original sony remote control, hit the "display" button on your remote until it say`s "display off"
Hope this help
Cheers
Posted on May 03, 2010
The tv is on video 1 and i dont have the remote how do i put it back on cable
find the video button or the button labeled( video ) or labeled ( tv \ av ) or try
the tv ch + -
you can find a door hiding some buttons on your tv open it and try to find
May 22, 2011 | Sanyo DS31590 31" TV
Can't get my Proview TV to recognize the signal
Good day!
Please check the connection of the jack from your TV to DVD.
Follow this step on how to connect the AV (audio and video) jack.
  • For the DVD connection.
  1. Find out where is the video out of the DVD.It is usually have a label (video out) and the color is yellow.
  2. After that,connect the jack (color yellow) to the video out of the DVD.
  3. Next,find out where is the audio left and right out of the DVD.It is commonly have a label (rear,front and center) choose 1 of the location you want.also it have a standard color (red and white)
  4. After that,connect the AV jack(red and white)to the audio out of the DVD.
  • For the TV connection.
  1. Find out where is the video IN on the rear side of the TV.It is usually have a label (video in) and the color is yellow.
  2. After that,connect the jack (color yellow) to the video IN of the TV.
  3. Next,find out where is the audio left and right IN of the TV.It is commonly have a label (audio in ) and found in the rear side of the TV.also it have a standard color (red and white).
After you connect the AV (audio/video) jack.Try to open the TV and the DVD and set your TV to the AV mode by pressing the AV label on the remote or on the TV button.
If the video is not appear on the AV1 try AV2 ,AV3 and so on.Or also try other AV on the TV.
I hope this solution will be helpful.Thank you and good luck.
May 06, 2011 | Televison & Video
My SONY KV32FS13 DO NOT HAVE IMAGEN ON THE SCREEN NO GET ANY CHANNEL OF TV OR CABLE ONLY WORK WITH DVD EVERY TIME WHEN TURN ON COME OUT NO SIGNAL.
Try pressing Tv/Video on the remote control and see if it doesn't switch input modes. If it doesn't, follow these steps:
1) Press the menu button
2) Navigate over to Channel Setup
3) Move down to Video Label and select it
4) Make sure none of the video inputs are labeled "SKIP". If so then do the following
5) Highlight the input labeled "SKIP" and select it
6) Use the up and down arrows and you should see a different name for the input. This will enable the selected input to be used.
7) Exit the menu by pushing the menu button on the remote.
8) Press Tv/Video on the remote and you should see the other stuff (cable, vcr, xbox, etc.).
Aug 15, 2010 | Sony KV-32FS13 TV
What channel for the TV?
The connection to your TV should be with the cable that has three RCA type connectors on one end, 1 yellow, 1 red, and 1 white. These would connect to corresponding labeled connections on the back of your TV. The TV connection would be called something like VIDEO 1 or A/V1. On your remote you should then have a button either labeled the same, or labeled as SOURCE. This would allow you to switch between different connectors until you have the one you actually connected your Wii to.
Mar 16, 2010 | Nintendo Wii Console
Video label remains on constantly
On the original TV remote there is a button located just above the "3" labeled "DISPLAY".
Press the "DISPLAY" button a couple times until the label goes away....
Good Luck...
Jan 25, 2010 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Sony (KDF42WE655). Always have a video 7 label on the screen
Try these:
  1. Press MENU on the remote control
  2. Select Settings
  3. Highlight Setup
  4. Select Label Video Inputs
  5. Select Video 7
  6. Select None if available or
  7. Leave the label blank
Aug 23, 2009 | Televison & Video
My akai receiver to my vcr
hi my name is mark, if you have cables. first unplug the power cords to the vcr and the receiver. on the back of the vcr there will an input and an output audio and video connectors. if your vcr does not have them you will need a new vcr that does. if you just want sound, find the Output connectors. there will two. they will be idenified as Audio OUT. plug one end of the red plug into the one labeled Audio R OUT, then the white in the one labeled Audio L OUT. if you are connecting the video up connect the yellow plug to the connector labeled Video OUT. the other ends connect to the receiver, on the back of the reciever find connectors labeled vcr or dvd AUDIO IN. then connect the red plug to the connector labeled R IN and the white plug to the connector labeled L IN.if you are just hooking up sound you done. to hook up video find vcr dvd Video IN and connect the yellow plug to the Video IN. on reciever. if you want the reciever to switch the TV you also need to run a yellow video cable from Video Out from receiver to Video IN on back of TV. when finished plug in vcr and receiver. select dvd or vcr on receiver to listen ot vcr on the receiver i dont know what model you have or it features i hope this helps thanks for your question.
Mar 17, 2009 | Akai 42 in. LCD TV
Video Labels stay on - Sony TV Model KV-32V16
Press Display / ' i ' button TV original remote and on-screen display will disappear.
I repeat, you need Sony TV original remote to do so, universal remotes do not have such button.
Jan 14, 2009 | Sony KV-32V16 TV
Video Input Label Displayed Constantly
You need Sony TV remote and press Display button and screen display (green label) will disappear.
Regards,
Aug 26, 2008 | Sony FD Trinitron WEGA KV-27FS120 27" TV
Cant access input jacks
Go into the setup menus IE:Video,Audio etc: The last page has the video label option. It is there where you select the label you want to give such as VHS,Beta,DVD etc. You can also select SKIP and that is why you can't access those inputs. Select any label besides SKIP and your issue will be gone.
Apr 23, 2007 | Sony FD Trinitron WEGA KV-36HS420 36" TV
Sony FD Trinitron WEGA KV-32FS120 32" TV Logo
80 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
