Describe your parser message RCINT failure string
May anyone give me a solution.i have have a problem that my PC says (Parser message RCINT failure string table id not found '42'
at line 462 Problem)
Please help. Please!
  • 1 more comment
  • 210538130 May 04, 2010
    Ok! it started when i downloaded an Anti-virus and deleted all the viruses when i was done a message appeard saying tom restart my computer to delete hiden viruses, that's when i was unable to restart,logoff or shutdown my computer until I switched off using the Button on the CPU. Never again i was able to logon all it says is " Parser message RCINT failure string table id not found '42' at line 462 Problem" assist me please i really don't know what to do.
    it all started when i was delteing computer viruses.
    from a nearly installed Anti virus i managed to delete more that 2500 Viruses. Than my computer comanded me restart it becuase there are hiden viruses that will automatically be deleted,Well tried restarting,logingoff and shutingdown, nothing happened untill i switched it off through the button on the CPU. That's when i turned it On and it said (Parser message RCINT failure string table id not found '42' at line 462 Problem) Please give sollution or atleast advice at 210538130@ukzn.ac.za
  • Chris Williams May 11, 2010
    When does this happen? What software are you running, and is there anything that you or the computer does that seems to provoke the error message?
Hmmmm, I meet too, Now I'm searching how to fix?
Posted on Jan 27, 2011
Rcint failure. string table id not found. '46' at line 246
let me tell what will i do if i m at your place.. i will prepare a windows 7 bootable pendrive first.. then i will forcefully shutdown windows.. then i would turn on pc & i will boot from pendrive and perform a clean install .. i will also format whole harddrive so that problem is uprooted.. try this
Nov 29, 2011 | Computers & Internet
Format whole hard drive & Re-install OS. By doing this all problem will be gone. Backup sensitive data before formatting
Nov 29, 2011 | Microsoft Windows XP Professional for PC
My PC SONY Firmware Extension Parser is missing,a driver Details of my PC ARE ,sony pERSONAL cOMPUTER mODEL PCG-BZ2L USA,
The latest drivers for your device and operating system can
be found here-
http://support.vaio.sony.eu/computing/vaio/index.aspx?l=en_GB
download, install and restart your computer.
If the problem persists reply with any error messages or
additional information.
//javaftper
Jul 31, 2010 | Sony VAIO VGN-CR115E/P Laptop
VAIO VGN-NS240E/W PC Notebook: I upgraded from Vista 32 bit to Windows 7 32 bit (...
It is required to install the following Drivers/Utilities in the following order to fix the issue with the functions Keys.
You can click on the link to download the Drivers/Utilities.
Video Driver.
Video Driver Update
Audio Driver.
Sony Shared Library
Sony Firmware Extension Parser Driver.
Sony Firmware Extension Parser Driver Update 1
Sony Firmware Extension Parser Driver Update 2
VAIO Event Service.
Please download each file in the Computer to a folder. After that open the folder where the file was downloaded and double click to begin the installation. Then, please follow the onscreen instructions to complete the intallation process. Make sure that you restart the Computer after each installation. Installing all the above Driver/Utility in the correct order should fix the issue with the Volume/Brightness Function Keys.
Good luck...!!
May 17, 2010 | Sony VAIO VGN-NS240E/W Notebook
I have problem when i start my pc a error message appeared rcint failure string table id not found 42 at line 462
This problem usually occur due to soft booting the machine (reset) and then it could not restart. Usually after the xp logo screen u can only got the parser message: string table not found '42' at line 462. (which is a registery sincronization error (r,sint)). Click the ok button many times and your machine will boot up. Then go to control panel, user accounts, create new account. soft boot your machine again log onto new account and delete all files found in file search with stylexp and tgtsoft in them. Tthen log off and restart and log on as usual user (p.s. administrater privalidges required on both) and delete the new logon account. Hope this will fix the problem, otherwise you have to format your hard disc and reinstall your OS.
Sep 21, 2009 | Microsoft Windows XP Professional
I want to read text file which is located in c drive using java code can anybody help me out
import java.io.*;
import java.util.Scanner;
public final class ReadWithScanner { public static void main(String... aArgs) throws FileNotFoundException {
ReadWithScanner parser = new ReadWithScanner("C:\\Temp\\test.txt");
parser.processLineByLine();
log("Done.");
* @param aFileName full name of an existing, readable file.
public ReadWithScanner(String aFileName){
fFile = new File(aFileName);
/** Template method that calls {@link #processLine(String)}. */
public final void processLineByLine() throws FileNotFoundException {
Scanner scanner = new Scanner(fFile);
try {
//first use a Scanner to get each line
while ( scanner.hasNextLine() ){
processLine( scanner.nextLine() );
finally {
//ensure the underlying stream is always closed
scanner.close();
* Overridable method for processing lines in different ways.
* <P>This simple default implementation expects simple name-value pairs, separated by an
* '=' sign. Examples of valid input :
* <tt>height = 167cm</tt>
* <tt>mass = 65kg</tt>
* <tt>disposition = "grumpy"</tt>
* <tt>this is the name = this is the value</tt>
protected void processLine(String aLine){
//use a second Scanner to parse the content of each line
Scanner scanner = new Scanner(aLine);
scanner.useDelimiter("=");
if ( scanner.hasNext() ){
String name = scanner.next();
String value = scanner.next();
log("Name is : " + quote(name.trim()) + ", and Value is : " + quote(value.trim()) );
else {
log("Empty or invalid line. Unable to process.");
//(no need for finally here, since String is source)
scanner.close();
// PRIVATE //
private final File fFile;
private static void log(Object aObject){
System.out.println(String.valueOf(aObject));
private String quote(String aText){
String QUOTE = "'";
return QUOTE + aText + QUOTE;
Jun 22, 2009 | Sun Java Programming Language (cdj-275)
Parser error
the Bin folder was not on the installation cd given by a provider
allow also webdav on IIS
Mar 19, 2009 | Polyvision RoomWizard Room Scheduling...
Computers & Internet Logo
657 people viewed this question
David Payne
David Payne
