Question about NEC IT1825 Printer
Initialize image drum counter
Want to initialize the drum counter on a Canon IT1825. I replaced the drum but I still get the message that drum must be replaced. Evidently the replaced drum did not reset the counter
    Brigadier General:
  • 3,917 Answers
Hi
Press # * C * This sequence may have to be repeated. Once the menu changes enter 24 then the key to start the copy then 7 and the key to start the copy. Press the CA key and printer will work fine.
Let us know if you want to know something more else please accept the suggestion.
Thanks for contacting Fixya.com
Posted on May 03, 2010
E0000670102
This is a partically complex error and has numerious causes all of them quite difficult to cure(sometimes also displayed is a message insert drum), there is rather a process than one solution.
(This error usually occurs when drum/s are replaced).
this can be caused by dirty contacts between drum and copier, can be caused under certain maintenance counter glitches(reset ITB usage counter) also if using generic drums never initialize drum/s.
It has been neccessary before to have to replace ITB assembly.
Primarily we will need to upgrade firmware(this requires a computer with canon service support tool loaded and the latest firmware for specific model in this case iRC2380/2880/3080/3380 ect). a connection between device and pc then must be made via network cable. load latest firmware, this usually solves issue. refer to help for service support tool usage
There can be other causes like transfer rollers ect, but these are not the normal cause.
Aug 06, 2012 | Canon iRC2380i
Printer unable to clean
This most likely means that the over flow tank is full. You can order a replacement tank but you have to disassemble the printer pretty far to get to it. You would also need to reset the counter so ..... if you want you can just reset the counter. Doing this without replacing the Ink Absorber will mean that once it is truly full it will leak into the printer itself. Do so at your own risk, but then again these are cheap printers....
Brother Maintenance Mode Commands:
- Quickly press Menu/Set * 2 8 6 4 to enter maintenance mode.
- Display should read maintenance.
- Press one or more of the maintenance mode commands below. After each command display should read re-init for a few moments then redisplay maintenance.
- Press 99 to exit the maintenance mode.
Maintenance mode commands:
01 Full RAM clear (see 91 below for retaining user programming)
02 scanner initialize (feed a white sheet, then a black sheet)
05 white level
09 print test
10 modify soft switches
11 print configuration list
16 panel test
19 CML test
20 signal test
21 tonal test
23 filter RX
54 scan edge
55 scanner area
66 test print memo
75 display drum life (if enabled on laser models)
76 reset drum life counter (laser models)
91 parameter initialize (user programming remains intact)
95 protection
99 Exit maintenance mode"
I would use the 01 and reset everything. Otherwise you can go through the 91 parameter list till you find the counter.
Jim
May 11, 2011 | Brother MFC 420CN All-In-One InkJet...
I changed the drum and there's still a message saying order drum....is there a way to reset that?
(from Okidata's support site)
After replacing the image drum cartridge, reset the drum counter to keep a correct count of the number of pages printed on the image drum.
1. Turn the printer on while holding the MENU 1/Menu 2 button. USERMNT displays in the control panel window.
2. Press MENU 1/Menu 2 three times. DRUM CNT RESET displays.
3. Press ENTER. The counter will reset and the printer will go ON-LINE.
Jun 30, 2010 | OKI Electric Industry B4600 Laser Printer
LaserJet 2840 Printer: I am trying to initialize a new drum. An error mes...
This means that the printer cannot read the E-Label on the cartridge, or it is not properly installed.
  1. Reinstalle the cartridge
  2. Power cycle the device
  3. If the problem is not solved, replace the cartridge. (Is the cartridge a remanufactured one? this can be a problem)
  4. Check if correct cartridge type.
May 10, 2010 | HP LaserJet 2840 Printer
"failed to initialize" camerawindow-downloading images to macbook
Do what the pros do...use a card reader to download to a folder you create on your desktop.
Feb 20, 2010 | Canon PowerShot A470 Digital Camera
Initialize Error
1. reset absorbers counter
2. if #1 does'nt work, see for mechanical problems...
If you're never disassembly your printer - call service...
Nov 03, 2008 | Brother MFC 210C All-In-One InkJet Printer
Dell 1700 image drum
After you replace the imaging drum, you should reset the imaging drum's counter. To reset the counter, press and hold the Cancel button until all lights flash in sequence.
Dec 13, 2007 | Dell 1710n Laser Printer
Brother Intellifax 2820 repair + automatic document feeder + sensor
Brother Error Codes
RAM clear (most models)
Quickly press function * 2 8 6 4
Press 0 1 for a full ram clear, or 9 1 to retain user data
Display should read reinit for a few moments then redisplay maintenance
Press 9 9 to exit the maintenance mode
Other maintenance mode switches:
01 ram clear (see 91 below)
05 white level
09 print test
16 panel test
19 CML test
20 signal test
21 tonal test
23 filter RX
54 scan edge
55 scanner area
66 test print memo
95 protection
B2 error = scanner or power supply error
Brother 950/980: On copy or transmit they may produce black pages. Prone to bad scanner (CCD). Brother may provide a replacement CCD at no charge to the original owner. Sometimes leaving the unit unplugged for a few hours will solve the problem temporarily.
Brother HL600 series laser printer toner will work in the laser fax & multifunction machines (part number TN100HL = TN100PPF). Drum units may be interchangeable as well (?).
Brother 1350/1550/1950: Problem: Record paper jams. Solution: Replace upper shoot. P/N UF6058001. Although there seems to be nothing causing the jam, the upper shoot gets stress marks on the ends. Replace even though it is not broken.
Thermal Transfer Machines: Only one side of the page is printing. Caused by the printhead latch being cracked. The latch is blue in color there is one on each side of the printhead, replace both latches
Nov 06, 2007 | Brother MFC-7220 All-In-One Laser Printer
Can't Initialize/Finalize
I dont have a solution, but the same thing is happening to me.
I've recently had an operation and I had before and after pictures,
And because finalize didnt show up I tried initilizing it and all the images got deleted!
Message me back if you find out how to do it!
Thanks!
x
x
Sep 10, 2007 | Canon DC210 DVD Camcorder
NEC IT1825 Printer Logo
23 people viewed this question
Top NEC Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a NEC Office Equipment and Supply Expert? Answer questions, earn points and help others
