Question about Dean Edge 4 Bass Guitar
My Dean Edge 5 bass stops working after 20 minutes or so. If I hit the strings hard, I can get it to pop and buzz a bit but that is it. Battery is OK. All wiring is solid. Amp and cables are all fine. The problem is deffinately with the electronics. Is there a part that I can replace without having to purchase new pickups and knobs? Like just the circuit board that is in there? thanks for your assistance!!!
  • Dean Master
  • 5,603 Answers
This would be characteristic if the battery is failing. Try a new battery. Batteries fade out and then they tend to recover if not used for a few minutes. The only real way to test the battery is with a brand new one. Try that first IF you have not done so.
One other problem is if the output jack is going bad. The jack is a stereo type and they use the ring connection on it to ground the battery to turn it on. If that contact gets marginal, then the battery voltage to the preamp collapses and sound fades out.
It is UNLIKELY there is a problem with the pickups causing this. A cracked circuit board could also do this but I don't think it would wait 20 minutes. Delays like that point to the battery. DO NOT believe any battery indicators... they OFTEN lie !!!
Posted on May 03, 2010
No sound from dean bass
Check battery. There is a small circuit board that is not attached to anything except a few very fine wires. These came loose on mine and no schematic is available. I trashed mine and bought a Fender Jazz. sorry
Jan 20, 2014 | Dean Edge 4 Bass Guitar
Fret buzz only on E string. Adjusted truss and action, and still buzz. Some relief when I turn bass knob higher than the rest
This sounds like a worn nut groove. The string is sitting too low. Does the buzz happen all the way up the neck or just on open string?
Aug 14, 2013 | Dean Guitars Dean Edge E09M Electric Bass...
My double pick up Dean edge quit working while playing. I checked the wiring and all looks good, but three is s a black wire coming from hole to center of body attached to nothing. Looks like it never was....
Make sure you have two wires soldered to the output jack on the bass. having a wire lose is not purposely put like that, for no sound from the bass then that wire is either from the pickups and connects to the pots on the bass or on the output jack. I would suggest taking it to an authorized dean dealer to inspect the wiring.
Jul 13, 2011 | Dean Edge 4 Bass Guitar
My Dean bass' strings rattle when i play and i hate it. It says i need to tighten the bolt in the neck but i don't know what to use to tighten it.
These often use a special Allen wrench. It is easy to damage the neck.
I would recommend taking it to a guitar place/shop and have them evaluate that the neck is the problem. There are other problems such as the bridge that can cause this.
Apr 05, 2010 | Dean Edge 4 Bass Guitar
Dean edge bass quits
The wiring in the back is so very thin and the circuit board isn't attached to anything but the wires that are attached to it. I found two weak solder joints there and one in the battery compartment (you'll have to remove it to get to the solder joints). I don't know which repair did the job, but it's working for now, anyway. I'd like to replace the tiny wires but there's not enough room in that compartment. I, also, had to replace the 4 bridge screws with larger diameter SS screws months ago as ALL 4 were stripped. Thread too fine for wood that soft. Come on Dean, step it up a notch! The bass plays and sounds great.
Feb 24, 2010 | Dean Edge 4 Bass Guitar
I nd to find parts for my bass
its a dean custom zone active bass get the parts off the dean site
Oct 24, 2009 | Music
Wiring for a dean edge 4 string with one soap bar pickup
You might find it at http://www.mediawebsource.com/guitar/pickup.htm If you can figure out what brand the pickup is you could check the manufacturers site. http://www.guitarelectronics.com/category/wiringresources/ has original factory wiring diagrams for guitar and bass for various pickup manufacturers. Hope this helps.
Jul 10, 2009 | Dean Edge 4 Bass Guitar
Dean Edge 4 Bass Guitar Logo
330 people viewed this question
Top Dean Music Experts
Matthew Spark
Matthew Spark
Rick Moore
Rick Moore
Tom Rood
Level 1 Expert
Are you a Dean Music Expert? Answer questions, earn points and help others
