Missing Tv stand pieces
I have a legend tv model l1928. It was in the new travel trailer I bought last year. I replaced it with a larger TV. The TV was mounted on the wall. I need the stand assy. so I can Stand it up by itself. These pieces were not with the trailer when I bought it. Can I get these pieces?
SOURCE: how to remove the stand from samsung LCD TV
Place the tv on its screen flat on a soft surface,
you need to remove all the screws, not just the stand one marked.
Lift the back panel and then you will be able to slide down the stand, when you have removed the back cover you will also see where how your wall mount will fit to the chassis.
Place all the screws back on the back lid.
Posted on Feb 09, 2008
SOURCE: removing stand from tv
Ive just removed the base stand off my 40" Samsung and all you hace to do is remove the 4 screws that are marked S and the base slides out
But the screws must be fully removed from the sockets before the stand comes away so a magnetic screw driver or something simular is what to need to fully take them from the sockets.
Hope this helps as some of the prevoius replys really helped me
Happy Screwing Folks
Posted on Oct 27, 2008
SOURCE: taking stand off toshiba regza tv
forget the four holes on the bottom of the stand. Remove the five allen bolts on the back bottom of the tv-not the stand. Yank on stand and metal plate slides out with stand.
Posted on May 17, 2009
SOURCE: stand wont come off grundig tv model gu19wdvd3 to mount it
Remove the three screws from the back of the stand.
Remove the four screws from the bottom of the stand.
Looking down at the bottom of the stand, push the four protuding clips inwards (not easy - you may need to gently ease them with a small screwdriver)
This unclips the oval base and allows you to unscrew the remaining screw inside the stem of the base
Posted on Dec 26, 2009
  • 62 Answers
SOURCE: how do I remove the stand to mount the TV on the
the TV will mount to the wall via the VESA screw mounts on the back of the LCD. If it is a smaller, monitor sized LCD then the screw pattern will be either 75x75mm or 100x100mm. On larger TVs is it usually 100x200mm. Sometimes the base is screwed into this mount and othertimes to the bottom. Simply unscrew it from the screen. Be sure that the wall mounting kit can handle your LCDs VESA screw pattern, screen size and screen weight.
Posted on Feb 07, 2010
Tele wont switch on only 23 months old can I claim back part of purchase money
Not sure about the tradestander office statement, but saying that a TV should last at least five years is like saying that my dishwasher should last the same amount of time (which mine has lasted longer). You, like most of us are up against the hope that products produced in today' world will stand up to longevity as those products produced 20 years ago; it just does not apply anymore. That is why there are warranty's, depending on what model is purchased. I've always bought a Sony TV, and NEVER had a problem (my last Sony TV lasted for almost 20 years, and that is because someone in my house, and no one will say who, turned the volume too high and ruined one of the speakers, less I would still have it). Just my opinion. If fixing the TV is more than 50% of the cost, then it probably is not worth fixing.
Nov 16, 2014 | Televison & Video
My Panasonic TV HDTV Model PT-56TW53 - 52 inches / 1080i I bought the projection TV in October 2003.
This TV has reached well beyond its normal lifespan for the TV type and size. The new LED/LCD displays are so much better that you will wonder why you haven't replaced before now.
Jun 29, 2017 | Televison & Video
Bloom Stand VS91350-01 has piece or pieces missing that holds TV to stand, where can I purchase these parts
Universal "Jimmy stand" for just about any TV available at Walmart or other places. They're 70 to 90 USD though. They include wall mount or a base to set the TV on a table or other surface. Search
sj-Stand-3755BB If you have parts missing on the manufacturer's one, good luck finding those, they typically come as a unit.
Apr 01, 2013 | Panasonic Televison & Video
TV wobbles on its pedestal stand.
Sounds like stand has been installed wrong an maybe miss aligned, and screws may be loose! Try removing and start over, or call installer back.
Feb 28, 2009 | Televison & Video
Need TV Code for a Legend TV
legend tv bought in 0507. No picture just sound
Dec 07, 2008 | Televison & Video
Removing the stand from a flat panel TV
None of these TVs have any problem removing the stand.
Stands for 32'' and larger TVs plug into the TV's body and are attached by 4 to 8 bolts that go through the cover, then through the plugged-in part of the stand and attach to the internal frame.
In most cases the bolts are 4 - one for each ray of the fork that goes into the TV.
Since bolts for the frame are metal bolts and bolts for the plastic back cover are usually wood-type screws (sharp on the top, wider thread) you can visually tell the one for the stand from the rest.
Look right above the stand for four, six or eight symettrically placed heads that are different from the ones you see on the corners.
Once you unscrew those the stand should feel more flexible and you can simply pull it back.
In order to do all that you have to have the TV laying on its face or back.
Watch out if it's heavy - you may need to support it towards the end of the operation. It's unlikely for it to get damaged if it falls down, but you still don't want to try your chances.
Giving it a little lift also helps unscrew the last bolts...otherwise all the force of the TV is pressing against it...and that makes it harder to unscrew.
May 21, 2008 | Televison & Video
Televison & Video Logo
182 people viewed this question
Top Televison & Video Experts
Electro Med Services...
