Question about Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner
When I turn on my printer I get a constant orange ink light, although I have replaced my printer cartridges with epson replacements !
    Problem Solver:
  • 6 Answers
Depending on the model, you may need to replace the printhead(s) as well. If there is no error message on screen, remove all cartridges and printheads then re-seat them into the printer again. The printer should run through a cycle like you installed new cartridges, and then should display a message with instructions (or not, if maybe it didn't realize you have replaced the cartridges from the last time).
Posted on May 03, 2010
My printer is not recognising the replacement ink cartridge although I've used these before many times
If you have just installed a new cartridge and you still see an ink related error, the cartridge may be incorrectly installed. Follow these steps to make sure the cartridges are correctly installed:
  1. Make sure the Epson Stylus is turned on.
  2. Do one of the following:
    • If your printer indicates that an ink cartridge is expended, press OK.
    • If your printer does not indicate that any ink cartridge is expended, press Setup, select Maintenace, and press OK. Then select Change Ink Cartridge and press OK.
  3. Open the scanner.
  4. Open the cartridge cover.
    Caution:
    Never attempt to open the cartridge cover while the print head is moving; wait until the cartridges have moved to the replacement position.
    To avoid damaging the Epson Stylus, never move the print head by hand.
  5. Press down all the ink cartridges until they click into place to make sure they are properly seated.
    Note:
    If a cartridge is properly seated already, you may not hear a click.
  6. Close the cartridge cover and press it until it clicks into place.
  7. Close the scanner.
  8. Press OK to begin charging the ink. This takes about 2 minutes.
    You see a message on the display screen when ink charging is finished.
    Caution:
    Never turn off the Epson Stylus while the ink is charging or you'll waste ink.
If the issue persists, it appears to be an issue with the cartridge(s). Contact Epson for further assistance.
Sep 25, 2014 | Epson Stylus DX8400 All-In-One InkJet...
Orange colors are brown
You are having a hardware problem with the printer, the sensor is damaged. call epson @ 1-855-383-7237 for replacement ink and printer.
Mar 06, 2014 | Epson Printer
Epson CX3900 says all cartridges empty but not true
Did you use Epson Genuine Cartridges?
ALL…. Epson & Brother Requires Genuine Epson Cartridges. !!!!!!!!
Also go thru the utility to change cartridges. This will make the chip know that you have all new cartridges and will move the ink station in place.
In Purchasing Epson's CX 5400, CX4600, & CX7400 and more, I found out that Epson does not like Generic Printer Cartridges. I also Purchased a Brother. That also does not like Generic Print Cartridges. Color that should be Yellow, will turn out Green, Blue Brown, etc.
These printers have a CHIP that will detect if it is Generic or Genuine. When they see it’s Generic Cartridges, it will print lines thru the words, stripes across the picture and also do a mix match with the colors. It also will not let you print anything, if only one of the cartridges is empty.
I wanted to print only Black, and would not let me, because I did not have any ink in one of my cyan cartridges. Go figure.
That's what these Companies do., so they can keep selling the ink cartridges. Some Printers, are able to use Generic, and some are refillable. Some you can refill them up yourself and I heard, quite MESSY.
So I learned, thru trial and error, that you must use the ORIGINAL Genuine Cartridges for these PRINTERS. Some people say some models work fine compatible, but not mine.......
I had to replace the printer, but Epson, Lexmark & Brothers are always on sale. My Brother & Epson cost me $50.00 with Rebate. .
This is the only advice I can give you. If you find this helpful, pls rate me.
Thanks and Good Luck :0)
Feb 04, 2010 | Epson STYLUS CX3900 All-In-One InkJet...
Do I need to have 4 ink cartridges in at all times to make my Epson S20 printer work. I only want to print black, and have only installed one black compatible ink; the machine is telling me the printer...
Yes the machine will require you to install all the cartridges to function. The cartridges also have kill chips that will tell the machine if they are empty or not. Because of this you will be required to always have some of each ink in the machine at all times.
That being said, because of the way Epson printers are designed the print head is integrated into the printer and generally not a replaceable part. This means "Use it or lose it." applies. If you would like to be able to print quality color in the future you should be sure you print a little of each color at least once a week to keep the print nozzles clear and functioning.
Jan 15, 2010 | Epson Office Equipment & Supplies
Epson Stylus Photo R800 driver ran out of ink weeks ago. Today new ink cartridges arrived. Replaced all cartridges (even the ones that were ok) because the printer's low ink light would not go out until I...
His could be because epson print jets plug up. and usualy cost more to repair than to purchase new printer. i had epson and now buy HP because hp when you replace the ink cartridge the spray jets are incorporated into the cartridge the only thing you have to be carefull of is that somel manufactures now put a chip on the cartridges to expire the units so they can sell you another even if you dont use the ink HP included so look for exp. date on new units. look into food warehouses like sams. costco, Bjs etc. they usualy have good prices on printers. sunday paper is also a good place to look.
Sep 22, 2009 | Epson Stylus Photo R800 InkJet Printer
R1800 yellow ink out light on constantly
Do replacemen procedure from status monitor (How to..). When asked to replace ink tank, unplug and plug again all of ink tank.
Aug 18, 2009 | Epson Stylus Photo R200 InkJet Printer
My printer has a new ink cartridge but does not recognize the ink
What model printer do you have and can you list the print cartridge?
Also have you selected on the onboard printer menu that you have inserted a new cartridge?
Jul 28, 2009 | Epson Stylus Multifunction Inkjet Printer/...
My Epson CX6600 prints but the words seem to have skipped parts. No word or line is complete. Although there is ink, printing is very light. Any suggestions?
This sounds like you need to replace the ink cartridges. Stuff is missing because the ink is very low or empty. Also, if you have just replaced the ink cartridges then you might need to do a cleaning cycle on the printer.
Jun 09, 2009 | Epson Stylus CX6600 All-In-One InkJet...
Epson D92 Printer. The orange light remains on.
to solve the orange light problem u need to make sure you replace ALL the ink cartridges and they are for your printer make sure u push them all the way down. this should solve the orange light prolem.
Nov 02, 2008 | Office Equipment & Supplies
Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner Logo
91 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
