Question about Dometic RM2652 Refrigerator
Work on gas but not on eletricity
I have a Dometic RM2804 on my 1992 RV, when turning it on using electric it will not cool off, however when I switch to gas it work just fine. Please help.
  • Dometic Master
  • 6,674 Answers
More than likely the AC (hydro) element is defective. Take a multimeter and carefully test for 120vac at the 2 spade connectors that the element plugs into on your circuit board. If your getting 120vac, then element is probably shot. ( element can be removed by lifting and twisting it up and out of sleeve along side of stack) be sure it's cool to touch. You may also have to remove, or reposition metal flap over it prior to removing. Make sure when testing for voltage at spade connectors, that fridge is calling for cool.
Posted on Jun 03, 2010
110 volts works but 12 volt does nothing, checked voltage 13.6 v. Any suggestions. Thanks.
RV Refrigerator Stop Working? - RVing - Fun Times Guide
rv-roadtrips.thefuntimesguide.com/2009/09/rv_refrigerator.php
If your refrigerator works on gas, but won't work on electric, you may have a burned out.... Cirtis, We are camping in Montana and our dometic refrigerator decided to stop ......Won't know until you can confirm you have proper voltage to the fridge. ... If you have confirmed both 12 vdc and 110 vac power at the fridge, I would ...
[PDF]Dometic Manual Refrigerator Diagnostic Service Manual
www.nationalserroscotty.org/resources/dometic-service-manual.pdf
Dometic Manual Refrigerators. ... 110 Volt Plug. 2. .... This is Dometic's Manual Refrigeration Diagnosis and Troubleshooting program. In this ... we will discuss the way an absorption cooling unit operates, and the ... gas, 120 volts AC and 12 volts DC .....In this condition we are still boiling ammonia but have no hydrogen for.
Dometic Fridge problems - RV mechanic
Dec 28, 2015 | Dometic CF-050DC CF-50 Waeco CoolFreeze...
It was working fine it was unplugged to be moved now it wont work on electric or gas its a rm 760 gas or electric domestic
When operating on Electric, if the rear of the cooling coils get warm and the fridge is level, but the refrigerator does not get cold then it is more then likely your cooling unit that has failed. Visit ArctiCold Refrigeration We keep it cold for info on replacement cooling units.... I have also attached a video with tips on diagnosing the RV fridge,
Arcticold New replacement cooling units can be purchased from Ebay Dometic RM760 Brand New Manufactured Cooling Units LIFETIME WARRANTY
Sep 16, 2013 | Dometic Refrigerators
Prroblem with rv gas refrigerator Dometic ndr1062
I assume you've checked baffle distance above flame? Anything changed above fridge, as in clearance, ventilation above etc. Maybe even removed a piece of panel, that was used above fridge for vent deflection etc?
Jun 25, 2010 | Dometic NDR 1062 Refrigerator
I have a dometic dm2652 rv fridge. its new and is
The DM2652 comes with an optional cooling fan to help with cooling the amonia. The fan cycles on and off as required as it has a tempeature sensor (thermistor). We turn ours off at night by removing the inline fuse (glass tube fuse 3 amp) located in your outside acces panel. The fuse is located in a black fuse holder with a re wire connecting both sides.
Jun 06, 2010 | Dometic RM2652 Refrigerator
Why would the furnave be blowing air if the gas is
Sometimes the fan stays on a little longer to cool the motor down before turning completely off.
Feb 20, 2010 | Dometic Rooftop RV Air Conditioner
The freezer seems to be working fine but the
If you want a service manual for a Dometic Brand click on the link below. They are good people they will help you.
http://www.gasrefrigeration.net/dometic_manuals.htm Aug 06, 2009- If I can help you let me know, I work and talk to Dometic a lot, Thanks Sea Breeze
appliancepartsse@yahoo.com
Aug 05, 2009 | Dometic Refrigerators
Dometic Rv Refrigerator cools on gas not electric. Checked electrical connections. It is 30 years old. But has seen great care.
The problem is cavitaion, to fix it, turn it upside down, I know they say never do this but trust me it will work, leave it bottom side up for about an hour then turn it upright for 24hrs, this will relieve the system cavitation and it will run normally when restarted.
Jun 23, 2009 | Refrigerators
Dometic rv refrigerator
Does it switch automatically to gas if so the plug may be losing voltage on the back side were it plugs in. As you say the voltage is good I would then look to the eye brow control board inside the trailer or the lower control board outside as being the issue. It is hard without testing the board to tell witch one it is.
Aug 26, 2008 | Refrigerators
Dometic RM2652 Refrigerator Logo
335 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
