Question about Sony KP-51HW40 51" Rear Projection Television
My tv is displaying a double picture.. i pulled the back off and covered the red lamp and the picture goes back to normal but no red in the colors.. pull my hand off the red lamp the picture doubles again.. any thoughts?
  • 4 more comments
  • fdimora May 03, 2010
    where can i find that chip? and a diagram of where it is located on the board
    it is a kp-51ws510
    it is a kp-51ws510
    it is a kp-51ws510
  • fdimora May 04, 2010
    it is a kp-51ws510
  • 10,594 Answers
Problem cause is red convergence output chip failure that will be replaced to fix the issue.
If you have experience of electronics stuff repair and can replace parts in circuit board as it requires soldering work with proper tools then can replace convergence output IC in your tv by yourself.
Let me know if you have additional question.
Thanks.
Posted on May 03, 2010
  • 3 more comments
  • Shahid Electronics
    Shahid Electronics May 03, 2010
    board
    Its big black IC mounted with big aluminum heat sink located on D board, actually there are Two ICs and its better to replace both.
    Convergence out ICs for Sony KP-51HW40 are available in Part Store, click to see an image and price info. if your tv model number is different, let me know.
    Thanks.
    it is a kp-51ws510
    Same IC is utilized in KP-51WS510 tv as well.
    Replace both STK392-560 in KP-51WS510 to fix convergence failure problem.
    I just replied your question about model KP-51WS510
    Shahid Electronics May 04, 2010
    Thanks.
    May 03, 2010 - it is a kp-51ws510
    Same
My tv screen when on turns yellow then after a while it will switch back to normal colors what can be wrong with it....
Televisions covered: all Projection with yellow picture, but not Projection TVs with a yellowish tint surrounding objects in a nearly normal picture.
Yellow = red + green
normal picture = red + blue + green (RGB). See illustration.
Fig. 1 Additive color mixing in an RGB monitor, or RGB Projection TV.
The circuitry powering your blue output, or the blue light engine itself is starting to fail.
Operating Theory:
The lamp module shines a bright light into the optical unit; there are a series of lens and baffles, and at the top of the light engine, a lens puts the picture into a mirror which is reflected onto the screen; All video and color is processed thru the light engine. Blue most commonly fails first, leaving a yellow picture.
Dec 26, 2011 | Mitsubishi WS-55805 55" Rear Projection...
My HL-P5063W won't power on. I replaced the Digital Video Board and the lamp. When I power up the the TV, there are several clicks and never a picture. The lamp does not appear to getting any...
Did u ever replace the Ballast board for this tv?No?,that ur tv problems.The Ballast board only job are to ignite the tv projection lamp to make it work.U hearing multiple clicks,lamp never ignite up the Ballast board.
Jul 29, 2011 | Samsung HL-P5063W 50" Rear Projection HDTV
What causes the picture to have a green tint
there are 3 color cathode in your TV red,green,blue cathode.The red and blue cathode might not working in your set that is why you have a green screen. Open the back cover of your TV you can immediately see the 3 cathode lamp at the back. Clean the lamp first using a clean clothe. Power up you tv and see whether the 3 lamps are lit. If lamps do not light up,check the circuit board where this lamp is connected re-solder all the components in this lamp. There is also an individual screen adjustment for the lamps it is located at the front panel and labeled RGB screen...try this first and let me know how it goes..
Apr 16, 2011 | Zenith E44W46LCD 44" Rear Projection...
My Mitsu rear-projection WS-B55 was purchased in '03 or so. Now the screen is sometimes turning red. I can do a system reset, and the color goes back to normal. Then it eventually (maybe days later)...
No,pictures go all red?Pictures have colors shaded shadows or 3D pictures look alike?Yes,than the tv it is developing a problem known as a convergence problems it dying.The tv convergence board have problems,must be resoldering those 2 or replaced 2 STK covergence ICS and some or all of it resistors too.To fixed the tv convergence board,to solved the convergence picture problems.The shop,will cost u like $300-350 for diagnose the problems and do all the resoldering work or replaces those parts on the tv convergence board.
Apr 08, 2011 | Mitsubishi WS-55809 55" Rear Projection...
My sony kv-36fs13 picture is very red. I tried adjusting the hue without success. I am getting the little red light on the front of the tv blinking five times. Any ideas?
open the back cover of your TV (unplug the unit) using a soldering Iron,resolder all the components at the CRT socket .the small square board attached to the tail of picture tube That's it! good luck and please dont forget to rate I need it to keep going...
Mar 08, 2011 | Sony KV-36FS13 TV
Sony kdf e50 a60 when TV is turned on picture goes off almost immedately and red light starts blinking in stand by mode.
Red light blinking is an indication of lamp problem. Check and secure tightly the following:
  1. Outside lamp cover
  2. Lamp door
  3. Lamp
If all of the above does not solve the problem, you need to replace the lamp. Let the lamp to cool for 30 minutes after unplugging. Use XL-2400 replacement lamp.
  1. Remove the outside lamp cover.
  2. Remove the lamp door.
  3. Pullout the lamp
  4. Hook a finger through the loop of the lamp handle and pull the handle upwards. Then pull the lamp straight out.
  5. Mount the new lamp securely.
  6. Reattach the lamp door. Turn the knob back to "CLOSE" and secure the cover.
  7. Put the outside lamp cover back in its place.
or visit http://www.fixya.com/support/t2631342-need_replace_42_in_sony_wega_hdtv
Aug 11, 2009 | Televison & Video
Samsung HCN4727W Rear Projection TV, green screen, audio works
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai2_bing.gif,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jul 10, 2009 | Samsung HL-R4667W Rear Projection...
TV..everything works...but screen goes red...I smack it, it goes back to normal, but then back to red.
it soinds like a convergence problem, i would try haveing someone take a look at it
May 20, 2009 | Hitachi 65F59 65" HDTV
I cant get a picture to display after just replacing the lamp
After replacement of lamp, please put back Lamp Cover securely as TV shows error of lamp cover (3 times blink)
May 07, 2009 | Sony Grand WEGA KDF55E2000 55" Projection...
Red & green lamps shutting off leaving a blue screen
Could you show a picture of the distended cover you mentioned?
Were the light blue lines you were referring to, diagonal, or truly horizontal?
Oct 15, 2007 | Sony KP-57WS500 57" Rear Projection...
Sony KP-51HW40 51" Rear Projection Television Logo
291 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
