Question about Kohler 1209-LA-0 Hourglass Whirlpool with Integral Apron, Flange and Left-H
I bought a house with aqua glass whirlpool tub (14 yrs old). Motor won't come on and I can't find reset button or serial number. Where are these items?
    Top Expert:
  • 12,744 Answers
Will have to remove access panel or make one the motor /pump assembly is mounted to the tub test for power to the switch and pump the numbers u are looking for are their by pump
Posted on May 04, 2010
Aqua glass jetted tub. How do I get the on/off switch to turn off jets?
it is a air switch, it has a tube running from the button to a box mounted on the pump motor,it could the hose has came off
Oct 08, 2015 | Home
Hot Tub won't Turn On.
First check the breaker box for the house and see if it has power.
Jun 26, 2015 | Home
I have an Aqua Glass whirlpool tub, and the jets no longer work. When I hit the on/off button, it just makes a clicking sound. Do I need a new pump? If so, what type do I buy?
Air Switch Repair
It sounds like you have a bad air switch located in your motor.
The air switch is what the air hose connects to on the back of the motor or on the box on top of the motor. The other end of the air hose is connected to the air button on the lip of the tub.
This is a latching air switch and when you push the air button it latches to send power to the motor. When the air button is pushed again it opens the latch in the air switch and stops power going to the motor shutting it off.
888-521-6183
US Parts Center
Nov 30, 2013 | Home
Aqua Glass whirlpool with a Pentair pump wont turn on.
the pictures are not showing up. Sounds like maybe you have an ITT Marlow pump that has a circuit board on the back of it.
What model number pump do you have? I believe what you tell us here is model number R150VS11-C
If this is the case then what you have is a control with a knob on the top of it that controls the 6 speeds.
The control & "VS" series pump you have is no longer being made. (It hasn't been made for well over 5 years)
Your new system includes the following items:
• New 1.5 hp Pump
• AirStreme Control box and topside control panel
You will change everything from the old system to what comes with the new system.
The new topside panel replaces the one on the top of the bathtub and the pump will hook up to the same plumbing as the old one.
No cutting PVC pipe to get this installed.
http://uspartscenter.com/airstreme_system.aspx
Rod Kidman
US Parts Center
We locate the "seemingly" impossible...
Ph: 888-521-6183
Fax: 801-417-8027
Mar 26, 2013 | Home
Can't find a pump for Aqua Glass model 566042BC
What model of pump? Pumps are changed and identified by the model and brand name of the pump, NOT the model number of the bath tub.
Rod
US Parts Center
888-521-6183
Mar 22, 2013 | Home
We bought a house with an Aqua Glass jetted tub. When we tried to turn it on nothing happens. At our inspection in July it was working fine. There is no way to get in to the front of the tub and no box. ...
Get the manual and study how it works. Then with this new knowledge you will have a good idea of just what to look for.
Is power reaching the unit? ON/off switch good? Circuit breaker? Is water reaching the unit/valve shut off?
It has to be something simple.
Sep 09, 2017 | Pool & Spa
I have an Aqua Glass tub in the master bedroom. Today I filled the tub to clean the tubes out and the pump won't work. It almost sounds like it's lock up? When you plug it in and push the ON/OFF...
We service a ton of Aquaglass products. Need to know what kind of control we are talking about. Is this an electronic button you are pushing or an air button you push down?
US Part Center
Aug 13, 2011 | Home
My Aqua Glass Whirlpool tub has stopped working. The motor comes makes a sound when I turn it on but the jets are not working
Your motor is shot. you need a new pump. If it comes on and you can hear a hum then it is bad. If you can get us a model number of the pump we can recommend a replacement model for you.
US Parts Center
Jan 05, 2011 | Whirlpool Safety Bath Walk In Bathtub -...
Aqua glass jetted tub quit working
Hello. There are two reset buttons in the mechanical space or your tub. You should be able to access that area from the front by removing a few screws. it is not uncommon to have to push those reset buttons after a power outage. If you do need a repair I recommend that you call a store that sells hot tubs as they will have a technician on staff or be able to guide you to one. Regards, Joe
PS kindly rate my answer as helpful.
Feb 13, 2010 | Whirlpool Safety Bath Walk In Bathtub -...
Aquglass jet tub will only humm no bubbles out of none of the jet
When a motor hums, it usually is the result of what is called "locked rotor." This can occur when the motor's brushes remain on one pair of the commutator contacts. The magnetic field does not shift to the next set of windings and the rotor is locked in place by the unchanging magnetic field.
If you have access to the motor, turn on the power briefly and place your hand gently on the side of the motor. Probably you will feel the vibration of the hum you are hearing, together with some heat. In locked-rotor condition, the motor draws high amperage and heats up quickly. Turn off the power.
If this is the condition, the motor is shot and needs to be replaced. You should copy down the information from the name plate (model and serial number, manufacturer, horsepower, amperage, etc.) and contact the manufacturer or a local appliance parts store about a replacement.
As you said that you recently bought the house, you may have a home-owners warranty which may cover the appliance.
Nov 24, 2008 | Whirlpool Safety Bath Walk In Bathtub -...
Kohler 1209-LA-0 Hourglass Whirlpool with Integral Apron, Flange and Left-H Logo
478 people viewed this question
Top Kohler Home Experts
john h
Tim Whalen
Mike
Are you a Kohler Home Expert? Answer questions, earn points and help others
