Question about Dacor Preference PGR30 Gas Kitchen Range
Touch pad in a depressed position.F0 - Dacor Preference PGR30 Gas Kitchen Range
  • geeboy May 03, 2010
    I can not turn on the oven...Display reads F0..Which indicates touch pad is in stuck position..How do I fix this.....
3 Suggested Answers
JOE LLAMA
  • 26 Answers
SOURCE: Control Panel Problem
Sounds like a membrane issue and I would certainly call dacor corp and maybe they will assist in the costs. That is if you provide repeated service part replacements.
Posted on Apr 01, 2008
SOURCE: oven failure code F0
I had the same problem-Christmas Day, just as I needed to put in the turkey. I turned off the breaker for 45min. and then turned it on. It works fine--was able to get my turkey cooked.
Posted on Dec 27, 2008
Getting error code F0 during oven cool down. During F0 keypad does not respond to clear error, however after waiting several hours error can be cleared. Next use is fine but error reoccurs during cool...
F0
Stuck touch pad Usually means that either the touch pad or the oven control
(also called clock or ERC) is defective and needs to be replaced. If this fault
code cannot be cancelled, replace the oven control (also called clock or ERC),
touch pad, or both.
Jan 31, 2011 | GE Profile JGS968 Gas Kitchen Range
I keep getting an F0 error code on both ovens
F0
touch pad, or both.
Dec 29, 2010 | GE WPSF5170W Profile Performance
Error code - F0
F0 Stuck touch pad Usually means that either the touch pad or the oven control (also called clock or ERC) is defective and needs to be replaced. If this fault code cannot be cancelled, replace the oven control (also called clock or ERC), touch pad, or both.
Sep 14, 2010 | GE Profile JTP56 Electric Double Oven
Dacor oven code FO means keypad is in depressed mode.....and then what?
Hi john56584,
The "F0" error code description is a stock function key. Here are basic test that will help you to determine if the ERC or touchpad is defective.
1. Unplug the range power cord or turn the power off to the range at the circuit breaker.
2. Gain access inside the control panel.
3. Disconnect the touch pad (also called keypad or membrane switch) ribbon from the ERC.
4. Make sure there are no lose wires, or anything else that may cause a short when power is turned back on. Assemble the control panel back the way it was.
5. Turn the power back on.
6. Wait for at least one hour to see if the code comes back.
7. If F0 comes back, replace the ERC. If it does not, replace the touch pad.
Hope it helps.
Thank you for using FixYa.
Sep 01, 2010 | Dacor Preference RSD30 Gas Kitchen Range
What does an error message "F0" mean for kenmore model 911.41185991?
for a maytag the F0 code means a function key is stuck, and recommends changing out the touch pad, or touch pad and oven control assembly if one unit. google your model number for error codes.
Jun 21, 2010 | Ovens
Dacor 48" range, double oven. ovens do not work. Letters FO appear on the display. Any suggestions?
F0 means: Clock pushbutton is stuck in a depressed position. Check clock buttons. You might need a new touch pad.
Dacor range repair in orange county, ca
appliance repair orange county, ca
Feb 07, 2010 | Ovens
F0 fault code
Hi ,
F0 is Function key faulty.
Replace touch pad or clock assembly (also called the ERC)
You can find parts online at partselect.com , or appliancespartspro .
May 29, 2009 | Jenn-Air Ovens
Hi minnabristol,
The F0 Fault Code Description is "Function key stuck". The only solution to this is to replace the touch pad. If the touch pad is part of the clock, you need to replace the clock or ERC.
Hope it helps.
May 14, 2009 | Dacor Preference RSD30 Gas Kitchen Range
Oven failure code F0
Nov 01, 2008 | Dacor Preference RSD30 Gas Kitchen Range
Apr 01, 2008 | Dacor Preference RSD30 Gas Kitchen Range
Dacor Preference PGR30 Gas Kitchen Range Logo
105 people viewed this question
Top Dacor Kitchen Ranges Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Are you a Dacor Kitchen Range Expert? Answer questions, earn points and help others
