Question about KitchenAid 24 in. KUDI01FLSS Stainless Steel Built-in Dishwasher
Dishes are coming out very filmy.
Ran dishwasher and very thing has a white film on it!! How do I fix this problem
    President:
  • 949 Answers
A couple of things could be causing this. I will create a list here of the most common causes, if they do not help I have attached a link at the end to some other tips I put together.
- Be sure your rinse aid dispenser is full, if you have run out it could cause filming
- Looks for suds in the dishwasher, if present it would indicate that some foreign detergent like dawn or other sudsing detergent got in there. If this happens run a short cycle or two adding a bit of vinegar or cooking oil to help dissolve the suds.
- Use the amount of detergent for your water quality. In the spring as the water table rises the amount of calcium and magnesium changes. They can cause filming, if you water is soft use less detergent, if hard use a little more and you may have to use an additive (see link)
Let me know if this helps at all, your honest feedback to me would be appreciated.
Thanks
http://www.fixya.com/support/r4666624-hard_water_calcium_white_powder_build_up
Posted on May 03, 2010
Items are coming out looking like they have a coating or film on them. I first thought it was a 'fluke' w/ the detergent (Cascade powder), so I ran a rinse cycle w/out anything. The glasses,...
The scum, film and white residueproblems have started since the reductionof phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
DishwasherResidue and Film on Dishes
heatman101
Jul 12, 2011 | GE Dishwashers
When I wash the dishes whether it is liquid or powder cascade soap the dishes come out woth a white filmy substance. What causes that?
Hi
White film deposits are observed if water is hard or when you are using more detergent than needed, try filling detergent cup half way. Try using white vinegar after the wash cycle is complete, run a complete cycle. Also turn down the heat on the hot water fed to the dishwasher. Try using water softener for better results.
You can also add vinegar in the final rinse cycle. Make sure that your soap dispenser drawer is opening and closing fine.
Hope this helps... Please post back if more information is required.
Daniel
Mar 25, 2011 | Maytag Dishwashers
Bosch Dishwasher leaves a sandy filmy residue on our glasses. Cascade Dishwasher soap is always used and dishwasher cleaner used about every 5 weeks. Dishwasher is run thru a complete cycle every 2 days. ...
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Dishwasher Residue and Film on Dishes
heatman101
Feb 06, 2011 | Bosch SHX55M02UC Built-in Dishwasher
When my dishwasher is finished running and drying there is a filmy residue on my dishes, and it's not cleaning like it did before. I'm doing everything the same way, it just started doing this. Please...
heatman101
Feb 02, 2011 | Kenmore 24 in. 15079 Built-in Dishwasher
Dishes are filmy at end of cleaning cycle. decreased amount of soap.. believe the rinse aid is not being properly dispensed...
heatman101
Dec 20, 2010 | Whirlpool 24 in. DU1148XTP Built-in...
It' no longer cleaning my dishes
hello,
If your dishes are coming out of the dishwasher covered by a removable dirty film, your water may not be hot enough, or you could be using an inferior brand of automatic dishwashing detergent. If you have tested your hot water and find it is between 140 degrees and 160 degrees Fahrenheit, consider how long it takes for the hot water to reach the dirty dishes in the dishwasher. If the hot water has to travel a long distance to reach the dishwasher, chances are the water filling the dishwasher starts out cold. To alleviate this problem, run the hot water nearest to your dishwasher until the water coming out is hot. This will guarantee the water filling the dishwasher is as hot as it should be to properly clean dirty dishes.
To remove this type of film from dirty dishes, after running the dishes through a basic rinse cycle, set a bowl filled with a cup or two of white vinegar on the lowest rack of the dishwasher. Remove any metal pans or utensils, and with the vinegar on the bottom rack, wash the dishes as usual. Dirty dishes that were once covered in film should come out squeaky clean
thanks.
Oct 23, 2010 | Dishwashers
My dishwasher is leaving the glassware spotted and filmy. Silverware is also being left with a film or in some cases residue from food.
heatman101
Jun 25, 2010 | Frigidaire PLD4555RFC Dishwasher
Even after a wash-a white detergent residue is left.
I have a Whirlpool Gold dishwasher and had the same trouble. I found the solution. Fill the detergent dispenser to the top with Cascade Complete liquid gel - it is in a green bottle, then put a half a cup of white vinegar in the bottom of the tub before you start the dishwasher. I have tried them all and Cascade Complete Gel works best. Don't use powder. It really builds-up on my dishes and only the gel keeps the film off my dishes.
I also add Jet Dry in the rinse-aid dispenser but I have a friend who use vinegar in that too. The dishes come out sparkling clean with no film or white build-up. If they still are filmy after three washes using this method, then you may have some build-up in the dishwasher and you can put a cup or two of white vinegar in the bottom - with no detergent or dishes and wash and rinse well. That helps get rid of build-up.
Apr 01, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
Spotty, filmy glasses
Even if you are sending it 120 degree water from your hot water heater, if the internal heating element has failed, your will get poor cleaning, including a film on your glassware.
Replacing the heating element will almost certainly fix the problem.
Good Luck!
Apr 03, 2009 | Maytag 24 in. MDB4000 Built-in Dishwasher
Soapy film left on dishes
Turns out it was my water softener leaving hard water on my dishes...now I have to fix that.
May 18, 2008 | Dishwashers
KitchenAid 24 in. KUDI01FLSS Stainless Steel Built-in Dishwasher Logo
166 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
