Question about Stoves Kitchen Ranges
Pellet Stove Help!!
I have a Quadra Fire 1000 that the blower motor won't come on once the stove reaches temperature. The reset button doesn't need to be reset for some reason. The stove resets if you unscrew the fuse holder for some reason. What sends the signal to the blower motor? Is the computer board bad? How do you test its functionality? Any ideas?
6ya staff
SOURCE:
Musselman
  • 7 Answers
SOURCE: why dose my pellet stove
This can be caused by wind. Especially if the vent is a direct vent, or in the center of the wall of your house. Has this happened since installed or just started? If since installed, probably not installed properly. If recent, just needs a good cleaning.
Have you cleaned the Tee Cleanout at the bottom?
Posted on Mar 23, 2008
Anonymous
SOURCE: St Croix pellet stove: pellets drop
ignitior is bad ....
Posted on Mar 29, 2008
MNTECH
Carl Schulzetenberg
  • 1543 Answers
SOURCE: PF on Whirlpool super capacity 465 electric Stove Model RF366PXGW2
PF = Power Failure. Sounds like you have a bad electrical connection. With your breaker off, check that the connections from the cord to the range are all good and tight. Next, check the receptacle where the cord plugs in. Remove the cover and check the connections there as well. Examine the power cord also. There could even be a poor connection at the breaker box (at the circuit breaker or the neutral buss bar) but not as likely, as your problem appeared when you moved your range.
Posted on Oct 19, 2008
Anonymous
SOURCE: st croix pellet stove
Had the same problem which I discovered this weekend..........
I have an eleven year old Afton Bay....the versa grate was not moving. I look into the inner workings of the stove and saw a bracket which had broken off....
The bracket was attached to the versa grate rod and made contact with the cam system in the stove...this is what moves the versa grate...........
I called my dealer, the part costs about $12.00 and looks like it can be replaced with out having a service guy come out..........
Hope this helps
Posted on Nov 09, 2008
mrgreenz
Daniel Arellano
  • 962 Answers
SOURCE: My pellet stove will start
You need to replace the auger motor. Go to fasco .com they may have one. Or enco.com I have a pellet stove and i have replaced both the auger motor and the motor that turns the hopper.
Posted on Nov 20, 2008
Why does my quadra fire 1000 not lite..i checked blower moter ignighter could it be thermocouple?
Wood burning or pellet stoves create acid vapor. The vapor damages thermocouples faster than a gas stove.
Jan 17, 2016 | Cars & Trucks
Quadra-fire pellet stove auger does not operate
motor not turning cause could be motor burnt check fuses or at worse faulty mother board have some one to have a look at it
Oct 11, 2014 | Heating & Cooling
Quadra Fire Pellet stove-will not ignite
I own a Quadrafire pellet stove. I have had this thing for 10 yrs. It seems every year at the start of the season I have some kind of problem. I clean it at the end of the season completely. First couple of burns are fine then get a good cold day and it doesn't work. All the gaskets, the exhaust blower, ignitor, glass front, and exhaust piping have had to be replaced. Now I have a blinking red light in the control box and cannot find anything on line to help. Does anyone know why this red light blinks 3 times every 10 seconds inside the control box? It's not the call for heat light. Think I may change to a wood burning stove to many headaches.
Oct 20, 2011 | Napoleon Auburn Pellet Stove Heater
Quadra-Fire Pellet stove-Pellet pot fills. Motor is running but will not light.automatically shuts down after about 5 minutes. Cleaned out
Sounds lie an Ignition Box problem. Quadra Fire recently redesigned their Ignition Boxes, so your may wan to replace yours. In addition, contact Quadra Fire Technical Service and speak to Steve Tate. He's a real guru when it comes to this problem. Don't settle for anyone else.
Hope this helps solve your problem.
Mar 10, 2011 | Heating & Cooling
I have a Quadra fire 1200 pellet stove insert. The convection blower does not stay on continuously. 2 min on 2 min off
It may be working properly. If it seems that it's a little cool in the room and the blower is cycling like you say then the stove may be getting chilled. If this is the case then the low-temp switch is cutting the blower off.
If the room is quite hot there may be a problem with the blower. Check to see if it has a bunch of dust in it making it run hot and tripping the internal thermostat.
Please respond with the 'comment' button, down below the ads. I'm considering a pellet stove and I'd like to hear anything you have to say about yours.
lp
Jan 11, 2011 | Napoleon Auburn Pellet Stove Heater
My Quadra fire 1000 Pellet stove is not igniting correctly, the fire box fills with lots of smoke, the when it finally does the flame is erratic, extremely high and is giving off alot of black, and does...
Hi lovinthepine:
1st. clean the unit, inside and out! Clean fire bowl/pot, it'll have small'ish holes for air and a larger one for the igniter. Clean out all holes in fire pot! Make sure fiberglass gasket material between firepot and firebox floor is in tacked and not leaking. make sure ash pan door is closed tight. Clean finned heat-ex's, this requires pulling out the two heat exchanger cover plates inside the firebox., next pull the right side panel and remove neg pressure blower & clean. These can get cloged up with ash and half burnt pellets. Tall flames & black smoke mean the unit is out of adjustment. Try closing up the pellet feed plate some, it's located in the pellet hopper area. Adjust opening smaller and wait 15 min, takes that long for change. If that doesn't get it, try opening the positive pressure blower's restrictor plate some. Remove left cover panel & find semi funneled blower cover plate, loosen screw and slide plate sideways +/- 0.25". If that doesn't do it, make sure all blowers are coming on, check for exhaust blockage in stove output/Flue sys. I hope that help ya, good luck!
C.B.
Oct 21, 2008 | Heating & Cooling
Pellet stove
PRESS H THEN TROUBLE THEN START THEN HIGH 6 THEN LOW 1
THEN PRESS BLOWER & HIGH FOR 3 BEEPS
Sep 30, 2007 | Stoves Broan 40000 Series Hood - 36" Hood...
Kitchen Ranges Logo
Top Stoves Kitchen Ranges Experts
Paul Carew
Greg Bernett
Greg Bernett
wayne murphy
Are you a Stoves Kitchen Range Expert? Answer questions, earn points and help others
