Question about Home Fencing
Iv'e got a belle cement mixer 150, i think the motor is on its way out, its around a 2007 model can you tell me if you can put new brushes in the motor if so how, or if i can have the motor reconditioned ? thanks.
I have a belle 110v cement mixer just over a year old.Everytime i use it ,it switches itself off after mixing 2 barrows of concrete but it will run perfectly for hours when empty.(tryed this out on Monday)So therefore it only switches itself off when loaded.
Gets very hot quickly.
Any suggestions would be much appeciated.Brian
Posted on Jul 28, 2010
The motor in my mixer is not working. I have had several years and just recently retired and started using. how can I tell is it is a rebuilt mixer. tag on bottom - 050805318. Box says 150 watts
dust of baking powder can give (dirt) over time in microswitch or switches and also the carbon brushes of the motor , cleaning and measure the electric is the point.
overload and burned collector is interrupted in the motor armature or one of the two coils of the field winding. in the latter case, a cable break.
Apr 01, 2016 | Emerson 120 Watts EM82821 Hand Mixer
A belle cement mixer,wont stay on when start button is pushed,changed switch ,still the same?
Sometimes the most simplest of fixes is verifying that you have voltage at your outlet and that you have voltage getting to the motor.
Check the motor's overload button; reset if necessary.
Take resistance readings:
  • start capacitor
  • run capacitor
  • and motor
If anyone of their specs are out of whack, that's the component that is defective and will need to be replaced.
Mar 24, 2015 | Masonry Tools
When mixing pizza dough in hobart se 601 mixer the dough hook stops under load any suggestion
Depending on how old the mixer is, I would check the belts (if it is belt driven) to the planetary gears. If it is not belt driven, it sounds as if the motor is faulting out. I would replace the motor brushes first before spending money for a new motor. This may not be an intelligent question but I have to ask, are you overloading the mixer? A 12 quart mixer will do fine with cake batter but when you mix pizza or bagel dough, the moisture content is much less and it is equivalent to cement. Sorry, I had to ask because I have seen this before. Good luck and I hope this helps.
Oct 20, 2014 | Hobart Mixer Only, Planetary, Bench, 12...
Why does the motor cut out after 4 mins. running, and overheats?
Is the air way clear? It is not likely to be the brushes, possibly a dry gear box?
Jul 11, 2014 | Masonry Tools
I have a KitchenAid mixer Model K5SS, Ser #W83808959. The motor stopped running and in checking the brushes, I found they are are both stuck in the brush holders. I suspect this is the reason the motor...
Download a Copy of the Kitchenaid Service manual.
http://www.kitchenaidparts.be/centers/servicemanual/mixer.pdf
You may have to remove the Motor Housing and use a small screwdiver
to completely remove the brushes or all portions of them if they are broken.
Jul 30, 2011 | KitchenAid K45SS Classic Stand Mixer
How to replace motor brushes? I only can take the small springs after unscrewing the caps on both sides. The carbon brushes are still inside? Tell me how to take them out and just put new brushes with...
I believe the brushes and the spring are one piece, so the brush should come out with the spring. Either the brushes are so worn that you just aren't noticing the little bit that's left, or the block has come loose from the spring. You can tip the machine over so the brush hole is facing down and let gravity do the work. If there's any brush left inside, it should slide out. Otherwise just install the new brushes.
Dec 14, 2010 | KitchenAid KSM90 Ultra Power Series Stand...
I need wiring diagram for Belle 150 cement mixer 110v
Small BLUE at top right hand corner, then the two rows of two...
top left is BLACK, top right is GREY, bottom left is BLUE from the power supply and bottom right is a short BROWN wire with a spur, which leaves a BLUE to connect to the spur. should be it :)
Oct 09, 2010 | Garden
Home Fencing Logo
1,031 people viewed this question
Top Home Fencing Experts
 Russ Hill
Russ Hill
Tom Chichester
ray gallant
Are you a Home Fencing Expert? Answer questions, earn points and help others
