Question about Maytag Neptune Washer
Maytag neptune washer just stopped in middle of the cycle???
Hey there I have a Maytag Neptune washer model number MAH3000AWW. I was washing cloths and went out to get them because it had stopped, I opened the door and the cloths were soaking wet. Not with soap but like it was in the rinse cycle and it just stopped. I tried to start it in the spin cycle and it would turn it made a low volume noise every time it was supposed to start spinning and then it would stop. Now it wont even make any noises and the drum is full of water. Does anyone have any idea what could be the problem?
  • Cindy Wallis May 03, 2010
    I will go take it apart and find out if it is a piece of clothing. I just want to make sure if a sock or something of that nature is stuck somewhere with being a front loader I have never seen anything missing from laundry. And I haven't seen anyplace that something could get out of the washer but I will check and get back to you. Are pumps expensive?
    I opened up the back and the belt had come off. I have put it back on and am running a cycle. It seems to be fine. Maybe a unbalanced load knocked it off. Thank for the help.
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Usually water not draining at all is due to the drain line that is clogged and/ or because of kinked drain hoses that’s attached to the Drain Pump. In many washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the hoses from the pump and pull the item out. To remove the sock from the outer tub port, open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using needle-nose pliers try to grab and remove the clothing through the port. Sometimes you can't remove the stuck clothing from below. Then you have to remove the agitator, top of the outer drum shield, and inner clothes tub. If you think that this isn't easy to do--and you may need special tools—then you might be happier getting a qualified appliance repair technician to do the job. If the drain line isn't plugged, the problem may be with your pump. Even if the pump appears to be turning, the internal impeller may be broken. If so, you need to replace the pump. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on May 03, 2010
  • Rylee Smith
    Rylee Smith May 03, 2010
    Sure please post a comment for assistance. You can also get the parts from this link.
SOURCE: maytag neptune mah3000aww
volume resistor r-11 on control board
Posted on Apr 29, 2008
  • 113 Answers
SOURCE: maytag neptune front loader washer has NF error code
Does it agitate and does the door lock light come on? Theres a panel on the back you can take off via 4 screws. Here you can check the belt and watch to see if it spins or moves at all. If the door lock light comes on, and you here the door click. Than chances are your motor control board is bad. Seen this many times. Im actually replacing one tomorrow on the exact washer.I believe the part # is 22004045. Heres a diagram. If the door doesnt lock than you need either a lock assy or a new computer for it. The computer is in the top panel where the timer is. If you look at it you should see a burnt resistor. If no burnt resistor than its more likely th lock assy. Ill try and find the part # for the lock and computer, and a digram. Hope this helps. Dave www.washermd.com
Posted on Dec 19, 2008
  • 109 Answers
SOURCE: maytag neptune mah3000aww spin problem
there are 2 wires going back to the board. They connect to a blue harness. Make sure their is continuity thru the harness. It connects to 3 out of balance swithches. Also check to see if lock light comes on.
Posted on Jul 07, 2009
SOURCE: I have a maytag neptune washer model# mah300aww.
Your tub seal leaked water into the tub bearings causing them to fail. Maytag only offers the bearings as part of the outer tub assembly and the repair can be pricey. A little research may turn up a service company in your area that has the tool to replace only the tub bearing. The repair becomes more affordable that way.
Posted on Jan 25, 2010
Testimonial: "Thank you. You gave me enough evidence now to get a new washer. Any recommendations? Most reliable front loaders."
  • 311 Answers
SOURCE: My maytag neptune MAH3000aww washing won't go into
most common issue with these is the door lock assy. You need to remove the control panel and check the R11 resistor on the board most likely it will be burnt. This was a common issue a few years back. If the R11 resistor is burnt you need to replace the door lock AND control board or your problem will occur again.
Hope this helps _MJ_
Posted on Jan 31, 2010
Wash cycle are running to long
FIXED Maytag Neptune, Timer Problem - ApplianceBlog
www.applianceblog.com/.../23387-Maytag-Neptune-Timer-Problem
Mar 4, 2011 - 8 posts - ‎3 authors
My countdown timer is stuck at the 33-minute level in the "wash cycle", and repeatedlyruns for a 30-40 seconds, then stops, then runs, then ... Maytag Neptune TL Washing Machine stops in spin cycle ...
Jul 25, 2013
Maytag Neptune Washer Won't Spin/drain
Jul 4, 2013
Neptune TL Washer FAV6800AWW - DC and UC ...
Jul 3, 2007
MAYTAG NEPTUNE WASHER CONTROL PANEL ...
Jun 29, 2005
More results from www.applianceblog.com
Troubleshooting a Too-Long Wash Cycle - whirlpool washingmachine ...
ask.metafilter.com/233920/Troubleshooting-a-TooLong-Wash-Cycle
Jan 25, 2013 - We have a Whirlpool Duet washing machine (about 2 years old). Thecycle is taking WAY too long to complete. The load that's running now ...
Maytag Neptune washer repair: motor/motor control circuit ...
? 12:10
https://www.youtube.com/watch?v=ITTbDh8CFEU
Dec 11, 2013 - Uploaded by daytonaturbofreak
Maytag Neptune washer motor/motor control circuit board ... my board just fried - is your washer still working? wondering how longthe conversion fix will last. ... Other times it will run a completecycle without any malfunctions.
Jan 11, 2016 | Maytag Neptune MAH5500B Front Load Washer
MAH3000AWW washer goes thru spin cycle but leaves the clothes really wet and is really noisy.
had similiar problem , there was a piece of clothing stuck in a drain hose
Mar 02, 2013 | Maytag Neptune Washer
Maytag washer wiring diagram
machine start when you push the start button but stops 3 or 4 seconds after the button is released help me dennis montgomery maytag neptune model #mah3000aww
Aug 27, 2010 | Maytag MAH8700AWM Neptune Front Load...
Maytag neptune washer clothes staying wet after cycle
Is your door lock light on when machine is in use? I am having the same issue as you and I believe it is because my door is not locking during use.
Apr 17, 2010 | Maytag Neptune MAH5500B Front Load Washer
Maytag front loader HE washer.
cheak your tube if there is a nail or an object is stuck in one of the holes
Jan 24, 2010 | Maytag MAH6700A Neptune High Efficiency...
Maytag Neptune washer MAH3000AWW seems to backfill after cycle
It could be a leaking water valve. The MAH3000 has two flavors, the earlier model had (2) extra wax motors in the soap dispenser for the bleach and softener controls and the newer ones have the bleach and softener valves integrated into the water valve assembly.
Contact me via the www.neptunehelp.com site and let me know which serial number you have and I can detemrine which water valve you will need.
See www.neptunehelpsong.com for a funny new song dedicated to Maytag Neptune owners explaining the door latch wax motor issue.
Feb 10, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag neptune washer MAH3000AWW
order the wax motor kit and replace parts from the internet. there are plenty of videos how to do this. it does require minor soldering and a little mechanical aptittude.
Dec 30, 2008 | Maytag Neptune Washer
LR == locked rotor, which translates to a bad motor and motor control board( usually depending on age sold a 1 set. Neptune repair kit. retails for about $200 part number 12002039
Oct 26, 2008 | Maytag Neptune MAH5500B Front Load Washer
Washing Machines Logo
116 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
