Question about NEC Dterm DTP-2DT-1 Phone
Problem getting NEC Dterm SeriesE phone to forward to voice mail
I have an NEC Dterm SeriesE phone, stock # 590041. I can't figure out how to get it to go to voice mail, when I can't answer or am away from my desk. The only current option I have to get recorded messages is to set it to Do Not Disturb. I would like for it to only go to voice mail when I cannot or am not there to answer. I have tried the commands I have found listed for this type of phone. The only one I have had success with is the *8 and #8, which do activate and deactivate Do Not Disturb. The *6 and *7 are not working to forward calls to voice mail.
SOURCE: NEC Dterm 80
NEC Dterm 80 phone, 1 ext. is blinking and we can't get it to turn off. It shows a busy signal when you try to call it.
Help it is the owners phone!!!
Posted on Nov 17, 2009
SOURCE: taking off DND
press "feature" 69 then press "feature" again ~ problem solved!
Posted on Jun 17, 2008
I need instraction on how to put the phone on night mode
Posted on Aug 27, 2008
SOURCE: NEC dterm series II phones-name desplay
This works on the series E phones. It may or may not work on the series II.
  1. Press the Speaker key (do not use the handset).
  2. Dial the Name Assignment access code and wait for the special dial tone.
  3. Using the key pad spell the name. Press each number until the letter appears.
  4. When the correct letter is displayed Press the HOLD key. Pressing the HOLD key will lock the letter in place and advance to the next position.
  5. Repeat steps 3 and 4 continue to spell the name.
Pressing the TRANSFER key will change the current letter to lower case.
Example to enter the name “Pat” press:
77 HOLD 22 TRANSFER HOLD 88 TRANSFER HOLD
Posted on Sep 23, 2008
  • 13 Answers
SOURCE: NEC Dterm 80 LCD display is defective.
The common thing on this style of phone is the silver ribbon cable that connects the display to the main circuit board comes loose after being dropped or knocked around and needs to be reinserted. You will need to open up the phone to do this. If this is not the solution then you will either need to purchase a used phone, send it in for repair or use another phone to take parts from.
Posted on Dec 08, 2008
Voice Mail
It depends on what type of phone system your terminal is running on. On a NEC 2400 IPX and SV8500 for example it's ASYD sys 1 index 140. A 2000 & key system is different.
Mar 22, 2010 | NEC Dterm DTP 16D-1 Corded Phone
How to turn on Voice Mail again.
You phone is no longer forwarded to the voicemail pilot number. It should be forwarded in a no answer condition and a busy condition.
Mar 11, 2010 | NEC Dterm DTP 16D-1 Corded Phone
Voicemail not picking up even though voice mail is set up
from each phone hit speaker dial 42 than the voicemail pilot number. could be 200 depends on system programmer. your busy forward no answer is not setup.
Jul 06, 2009 | NEC Dterm DTP 16D-1 Corded Phone
DTERM SERIES E VOICE MAIL
If its an intergraded VM,, somply dial the main Voicemail number from that phone
Apr 14, 2009 | NEC Dterm DTP-2DT-1 Phone
NEC 16C Telephone
That would be a call forward no answer case. Ususally this is setup for forwarding you phone to voice mail. Same goes for if you want to ring another phone. Do you know your system access codes? Usually it starts with a * then follows by a number. Good Luck. Jerry
Aug 26, 2008 | NEC Dterm DTP 16D-1 Corded Phone
NEC Dterm 80 calls won't go to voice mail
for us i just found this out.
1.Fwd B/NA
2.1 - 1:set-0:cancel
4.200
5.speaker
after 4 rings it goes to voicemail
this works for us.
i hope it works for others too.
turn this feature off
1.hit fwd b/na
2.0:cancel
3.exit
4.exit
should see the normal display then.
Jul 17, 2008 | NEC Dterm DTP 16D-1 Corded Phone
Voice mail not answering
Press speaker, 43, xxx, speaker. "xxx" is the number of your company's message box, if you know that.
Jun 13, 2008 | NEC Dterm DTP 32D-1 Corded Phone
Password
Your phone does not have a password. It sounds like you are asking about voice mail. You will need to locate a programming manual or at least an "administrator" manual for the voice mail system, possibly the phone system itself. Using the phone's part number will not help you in this search. You need to find out what NEC phone system version you have along with possibly what voice mail system/version you have.
Oct 10, 2007 | NEC Dterm DTP 16D-1 Corded Phone
Dterm80 NEC phone
How do I get the following off my display?
MSG >>> In-Mail #2
Sep 12, 2007 | NEC Dterm DTP 16D-1 Corded Phone
Lands Phones Logo
547 people viewed this question
Top NEC Lands Phones Experts
Brian LaDuca
george  peters
george peters
Are you a NEC Lands Phone Expert? Answer questions, earn points and help others
