Question about Samsung Cameras
Samsung D85 lens keeps getting jammed.
Today I switched my Samsung D85 on and the lens only came half way out and I got an error sound and the camera then shut off. I tried switchin it on and off quite a few times but it kept switching off and the lens didnt retract. I thought it might just have gotten jammed, and gave it a tap and the lens did retract, but when i switched the camera on again, the lens jammed as it did before and the camera switched itself off. Is there any way that I can fix this?
  • 130 Answers
SOURCE: Lens is stuck so Camera does not turn on
The battery packs in these units dont have a very long "shelf life" meaning when you charge the battery you need to use it within a few days or it will loose charge. Have you tried a fresh charged battery? They are very power hungry devices and the more advanced they get the more power they need. How old is this unit? how many charges have you put on the pack? it may be time for a second pack. An emergency backup pack good power is key nowdays.
Posted on Apr 03, 2006
  • 114 Answers
SOURCE: Olympus Mju 400 error code d: 1E12
the lens is with problems and needs to be changed. doesn´t happen when u connect to computer, because when is connected the lens doesn´t move.
Posted on Jan 23, 2007
SOURCE: Camera shutter does not retract
I just had this problem with my DSC-W5. It just needed a new battery. I hope you enjoyed the wedding!
Posted on Aug 29, 2007
SOURCE: lens error on brand new G9
i got the exactly same problem!!
i bought it on 16th/Feb, next day,17/Feb not more than 20 pictures i took, the issue comes (lens won't action while shift the zoom lever, but it's working ok while switch on and off the camera)
so i bing it to the shop with my angry, they just said to me that you must dropped the camera.
--but i sware i didn't !!!
now they took the camera to Canon base for the exam...
Posted on Feb 18, 2008
SOURCE: Lens error
It's about $124 repair charge if your camera is out of warranty. However, when I called customer service, he said to be sure the batteries are not getting old or running a little down, because besides that, the issue is something that will need repair work done.
Posted on Jun 21, 2008
I can't get rid of 'Lens Error' message and keep my camera switched on for more than a minute.
You don't need to drop a camera to get a lens error. Could be anything, from holding the camera in a wrong way (touching the lens barrel) or a bit of dust in the barrel or a gear, or a gear that breaks off. If the lens retracts correct when the camera is switched of, and comes out to the full extend when it is switched on, you should think everything is in working order. But when you say, the screen looks ver blurry that could be an indication, the lens is not coming out correct, or the focus mechanics does not work correct. I'm afraid you have to bring the camera in to a service centre (or buy a new one) if you can't solve this, by again take out the battery, charge the battery and reinsert the battery.
Jan 26, 2014 | Nikon COOLPIX S3300
My Lens will only close half way.
Hi Natalie:
Lens stuck, is common defective that need new lens unit replacement or just repairable.
Causes of a Lens Error: There are a number of ways with which a lens error can be caused. Particulates might have managed to get into the mechanical bits that allow the lens to retract, a purely physical interference with the lens mechanism. If the camera was dropped, especially while the lens was extended, there's a pretty good chance something might have been knocked loose, such as the guide pins upon which the lens withdraws and retracts.
How to Repair a Lens Error: As scary as a lens error might seem, there are some easy fixes. Before trying any of them out, however, first take a good long look at your camera warranty and maybe have a chat with the company. If the lens error will be covered under the terms of the warranty, go for it. Even some of the simple fixes mentioned below might void the camera warranty. Frankly, however, it's unlikely that a lens error will qualify for the warranty.
Hope this helps; also keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using Fixya, and have a nice day.
Nov 15, 2011 | Samsung Digimax S800 Digital Camera
Zoom error
There is a problem in the zoom functions of the lens assembly. Dust and lint can get in it and jam it, and you can try to spray compressed air into the lens in hopes of freeing it up. A gear can also be jammed, or stripped. If it's just jammed, you may be able to fix it yourself. Here is a web page that details all the things you can try to get it working. They say about half of the cameras with these problems can be fixed by trying their suggestions. The article says it's for lens errors, but it applies to the problem you're having:
If none of these tips help, the camera will have to be serviced. Get an estimate first, since the cost of repair can exceed the replacement cost of a new one. Good luck, and hope this helps.
Jun 14, 2010 | Fuji FinePix A600 Digital Camera
Camera turns on, then the lens will not come out but it sounds like its trying to, then camera shuts off (all this happens in about 1-2 seconds)
Sounds like a stripped gear in the lens assembly (the gear that drives the lens out). Not an easy, or inexpensive fix, if it is stripped. If could just be jammed, however. Here is a blog about the problem, and things you can try to get it working. They say about half the cameras with this kind of problem can be fixed, using their steps. The blog is about lens errors, but it's the same problem you're having, and applies.
Jun 10, 2010 | Kodak EASYSHARE M763 Digital Camera
Samsung L739 lens stuck half way, makes a beeping sound
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Dec 14, 2009 | Samsung Digimax L730 Digital Camera
L730 wont turn on, lens stuck half way
Hi, Lens is jammed, lens motor gearbox requires restting. If you in the U.K I can help you out.
p.m me at
Aug 09, 2009 | Samsung Digimax L730 Digital Camera
Hi i have a fuji 9600. it worked fine untill today ehen i switch it on i get message: focus error.
the lens is getting jammed ....see if anything is coming in its way while opening up ..... like the lens cap or your hand ..... if not then there is a problem with the control gear set which intializes the lens ..... its a repairmans job
Oct 26, 2008 | Fuji Cameras
Lens error
This may be related/helpful: My S3 in normal home use (no sand, wet or shock) just now displayed the ?Lens cover error? message, with cover only half open. Using a tooth pick I ?eased? it gently and it popped open, took a few trial pictures- fine, but would not fully close unless eased. Now will open and close slowly on own but error message blocks camera use. Then spotted cause - a loose thin sliver of silver trim from below flash around (there?s a gummy substance where it should be). When I first saw one end of this it was between the lens cover and the camera body as tho part of the mechanism, so I did not touch it. Now I know it?s jamming the lens cover operation is it OK to open the camera case to get it out? Questions: (a) Has anyone done this please? (b) Will this clear error message? Thanks.
Aug 21, 2007 | Nikon COOLPIX S6 Digital Camera
System Error SOO41
Minolta Dimage G500 My lens is jammed in, and cannot eject itself or focus. It keeps on stating SYSTEM ERROR SOO41. Can you please let me know what i can do.
Jul 04, 2007 | Konica Revio KD-310Z Digital Camera
Cameras Logo
126 people viewed this question
Top Samsung Cameras Experts
Are you a Samsung Camera Expert? Answer questions, earn points and help others
