Question about Panasonic Lumix DMC-TZ3 Digital Camera
Camera gives following message when switched on ---switch camera off and then on
    Genius:
  • 1,040 Answers
There could be a battery problem or software problem or mechanical problem...
first try with by inserting another battery. or update firmware of your gadget........... If problem persist then get it serviced
Posted on May 03, 2010
2 Suggested Answers
kecik
  • 70 Answers
SOURCE: lens error
Some problem can be fixed easily, but some need more.
Read and follow in this page:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Posted on May 28, 2008
Tip
Memory card locked
This is a tip explaining the error, "Memory card locked". We will also give you the resolution for this error. This error, or rather message, is usually the result of the following situations.
Situation 1:
Well, this is usually the problem, on the memory card, there is a little switch on the left side, which can switch between "Lock" or "Unlock".
If you get the display, memory card locked, remove the card from your camera, or USB adapter and have a look at the switch, if it is switched to locked, move the lever top the other side and place it back. This should solve your problem, if not, lets have a look at situation 2.
Situation 2:
Open the card slot of your camera and have a look inside with a bright light/ torch. You should see a little metal tab or switch inside the card slot. This is the write protection switch.
With time and repeated use , the switch will start to bend slightly until it will no longer depress when a unlocked card is inserted.
With a toothpick or needle , slightly and very gently push this tab up a little bit. (some camera's will require you to pull the tab down), This will allow the switch to operate once again and should solve your problem.
I really hope this can steer you in the right direction. Please rate accordingly.
Kind regards
Andrea
on Feb 27, 2010 | BenQ DC C740i Digital Camera
Facing below problem with my Advent MP82 Digital Camera. Can't switch it on. On replacing new batteries too. Opening for a second and switching off by giving message replace new batteries
theres already some problem with camera power supply particulary in its charging circuits, have it check with authorized camera service center.
Feb 18, 2011 | Cameras
When i switch on the camera i get a message 'reinsert memory card'. Same error reappears once I re-insert it. I have also seen the message 'error formatting memory'. Any suggestions?
The camera is asking you to format the memory card. You didn't give the camera make or model so I assume it has a SD or an SDHC memory card make sure the card in in the "write" position here is a diagram for this
Diagram.
SD card are the same so it doesn't matter that this diagram has used Canon memory cards.
Next go into your camera's set up menus and scroll down through the different functions to find format, follow the on screen instructions. you should be good to go
Jan 13, 2011 | Cameras
Hi, My Nikon D90 with Nikkor 18-200mm lens is giving me the following error message: Memory card is locked. Slide to "write" position. Any ideas how to correct this? Thanks! Jennifer
Take the memory card out of the camera and look at it. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again. Then put the card back into the camera.
Nov 20, 2010 | Nikon D90 Digital Camera with 18-105mm...
My Kodak C913 sometimes follows switch on with the statement memory card needs formatting. I have tried to do this several times but to no avail. I am then faced with a message which says that I should use...
First of all, stop putting your cards in another camera....this can corrupt the card. With no card in the camera, go into the menu and find "reset"...follow the on-screen instructions. Insert your card, turn on the camera and go into the camera menu and find "format"...follow the on-screen instructions. Let me know the outcome.
May 25, 2010 | Kodak EasyShare C913 Digital Camera
Inserted new sandisk ultraII 2gb into camera. error message, disk locked. unlocked, still error message
Hi!
Does it work with other cards? There's a small switch on the memory card reader inside the camera which tells the camera that the card is locked. Most likely this switch is broken. You can try to point it with needle or something but I'm afraid you will have to give it away for a repair to a local repair shop or Canon service center.
Tom
Sep 27, 2009 | Canon PowerShot A540 Digital Camera
When switched on camera gives message - memory card is write prot
Jun 27, 2009 | Nikon COOLPIX S52c Digital Camera
My Camera keeps giving me an error message and the zoom lens is staying out even when the camera is switched off. I am unable to take any photos
Hello!!
Firstly switch off the camera
press and hold the ok button and turn the camera on and off for few times
whilst keeping this button depressed
Regards
Smilemaker.
Aug 19, 2008 | Cameras
Lens is stuck out
push up on the inner lens housing,
Dec 24, 2006 | Kodak EasyShare LS753 Digital Camera
Panasonic Lumix DMC-TZ3 Digital Camera Logo
156 people viewed this question
Top Panasonic Cameras Experts
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
