Question about Maptech Offshore Navigator (EMSWOS)
Is SOG (speed over ground) displayed? - Maptech Offshore Navigator (EMSWOS)
Yesss! On the top line, click on " view", then click on " on water mode"
you will then have all the navigations needed for running your boat...better yet, click on "sphere" on the bottom line and see your boat showing your displacement on the chart...I love it !!!
Posted on Jul 12, 2010
Where are all the ground wires located on a 2008 chevy cobalt?
It wouldn't be a ground problem If it were the whole instrument cluster would be dead . Checking the BCM an the IPC for DTC'S - diagnostic trouble codes is the proper way to diagnose this type problem . Not worrying about grounds .
Odometer
The vehicle odometer is calculated and stored electronically in the body control module (BCM) and is sent via the serial data circuit to the instrument panel cluster (IPC) for display. The BCM calculates and stores the mileage based on the vehicle speed serial data information from the PCM/ECM. The IPC displays the season odometer information from the BCM in the driver information center (DIC). The odometer will display error if the IPC detects an invalid odometer data from the BCM. After an invalid odometer data is received from the BCM, the IPC will display the last known odometer reading for 1.5 seconds before error is displayed in the DIC.
Speedometer
The instrument panel cluster (IPC) displays the vehicle speed based on serial data message from the body control module (BCM). The BCM receives vehicle speed data from the PCM/ECM via the serial data circuit. The speedometer will default to 0 km/h (0 mph) if:
• The PCM/ECM detects a malfunction in the vehicle speed sensor circuit.
• The BCM detects a loss of serial data communications with the PCM/ECM.
• The IPC detects a loss of serial data communications with the BCM.
Your best bet would be to take it to the dealer !
Apr 19, 2017 | 2008 Chevrolet Cobalt
Hi, water intake leaking on greenworks 1600 ele. sprayer thanks! its brand new!
Send it back - if you are in the UK the SOG act applies if in the US then Tough
Oct 23, 2015 | Greenworks 1600 PSI 1.3 GPM Electric...
How much does this cost?
the are about 66 dollars on amazon dot com. Nice unit, I have one.
Feb 13, 2014 | Sog PowerAssist EOD - Black Oxide - Nylon...
Engine stalls, p0720 engine light on. Runs ok than goes sporadic.
There are 2 possibilities here:
1.- There may be a problem with the new speed sensor, the electrical wiring between the speed sensor and the PCM, or an internal PCM problem. To see if VSS signal is present at the PCM a scan tool capable of displaying live data is required.
2.- There is a recall action on this model year for erroneous speed sensor signals; the cure is an updated software calibration. If your truck has not yet had the updated calibration installed, you should call your local Dodge dealership with your VIN number and ask the service department to check to see if there are any open recall actions on your vehicle. If the software calibration has not been updated yet, they will perform this procedure free of charge for you. If you do not have the current software calibration in your PCM to correct the VSS issue, you need to have this done before proceeding any further with attempting to diagnose this problem
This sensor is located at the rear of the transmission.
Symptom: P-0720 LOW OUTPUT SPEED SENSOR RPM, ABOVE 15 MPH
When Monitored and Set Condition: P-0720 LOW OUTPUT SPEED SENSOR RPM, ABOVE 15 MPH
When Monitored: Continuously with the key on, engine running, and gear selector not in park or neutral.
Set Condition: This code is set if the vehicle speed (as determined from the vehicle speed sensor), is above 15 MPH, and the output shaft speed is below 60 RPM for 2.6 seconds.
POSSIBLE CAUSES DTC CODE RETURNS:
OUTPUT SPEED SENSOR DEFECTIVE
PARK/NEUTRAL SWITCH CODE PRESENT
OUTPUT SPEED SENSOR GROUND CIRCUIT OPEN
OUTPUT SPEED SENSOR GROUND CIRCUIT SHORT TO GROUND
OUTPUT SPEED SENSOR SIGNAL CIRCUIT OPEN
OUTPUT SPEED SENSOR SIGNAL CIRCUIT SHORT TO GROUND
PCM DEFECTIVE (DRB SHOWS > 60 RPM)
OUTPUT SPEED SENSOR HARNESS OBSERVABLE DEFECT
OUTPUT SPEED SENSOR WIRING HARNESS INTERMITTENT DEFECTIVE
Hope helps.
Sep 14, 2011 | Dodge Ram 1500 Cars & Trucks
Hi, Do my plantronics Back Beat 903+ compatible with lenovo laptop?
It should if your Lenovo laptop is Bluetooth enabled and supports all the necessary profiles for the BackBeat 903+ (HSP, HFP, A2DP & AVRCP). SOG is not necessary, but it's fun.
Good luck from Headsets Direct!
Feb 06, 2011 | Plantronics Backbeat 903 Bluetooth...
With alcx-27c with gps do i need a transducer with the speed on it? or will my gps give me the speed my boat is traveling
The unit will give you speed over ground directly form GPS. there is a difference between Speed Over Ground (SOG) and ocean speed. Ocean speed will only be available from a paddle wheel type transducer.
Aug 10, 2009 | Lowrance LCX-27C GPS Receiver
Hello- My 332c will not show speed. It worked before.The spinner wheel is not damaged.Speed just flashes 0.00 mph Thanks, Jeff
Try setting up the speed in the overlay data menu again:
1. Press MENU, arrow down to OVERLAY DATA and press ENT
2. Highlight the option for speed (WATER SPEED or GROUND SPEED) and press ENT
3. Highlight the REMOVE button and press ENT
4. Highlight (PRESS ENT TO ADD) and press ENT
5. Arrow down to SONAR DATA and press ENT
6. Arrow down to WATER SPEED and press ENT, a check will be displayed in the box
7. Press EXIT twice
If the speed is still flashing, the data is still invalid. Try resetting the unit completely:
1. Turn unit off
2. Press and hold the PAGES and POWER key until the "DO NOT RELY..." alarm appears
3. Set up the overlay data for speed again: 1. Press MENU, arrow down to OVERLAY DATA and press ENT; 2. Highlight (PRESS ENT TO ADD) and press ENT; 3. Arrow down to SONAR DATA and press ENT; 4. Arrow down to WATER SPEED and press ENT, a check will be displayed in the box; 5. Press EXIT twice
If the speed is still flashing, good chance the speed sensor is bad even though the wheel still spins. Install the latest LMS-332 updates from http://www.lowrance.com/en/Products/Marine/Full-Size-SonarGPS-Chartplotter-Combos/LMS-332C/Downloads/LMS-332C-Software-Update/ and set up the overlay data again.
If it turns out that the speed sensor is bad, just use speed from the GPS. This can be set up from the overlay data menu as GROUND SPEED.
(note: the overlay data must be set up for each page individually. So if you set up speed to be displayed on the map screen, it will not also be set up on the sonar page)
Jul 12, 2009 | Lowrance LMS-332C GPS Receiver
Oem Radio installation
*** 91 park ave with delco bose =
black = ground
dark green = lights on input
grey = panel lights
pink = on input
yellow = power input
orange = battery power input
nca = shield ground
tan = left fr spkr +
orange/black = left & right spkr -neg
lite green = right fr spkr +
nca = shield ground
dark blue = right rear spkr +
dark green/yellow = right & left spkr - neg
brown = left rear spkr +
purple/white = display dim output
pink = vehicle speed input
**** 91 park ave without delco bose =
grey = left front - neg
tan = left front + pos
dark green = right front - neg
light green = right front + pos
black = ground
dark green = display dim signal
grey = panel lights
pink = power antanna
yellow = ign input
light blue = right rear - neg
dark blue = right rear + pos
yellow = left rear - neg
brown = left rear + pos .
there YA go
Dec 27, 2008 | 1991 Buick Park Avenue
Log and trip function not registering
It is unlikely the problem is in the A65 screen.....most likely it is an issue with the paddlewheel itself, its circuit in the depth/speed transducer, or least likely, in the DSM25 sounder module.
Both the log and the trip functiions are read from the paddle-wheel sensor of the connected DSM25 sounder module and transducer.
1. Make sure you have a DSM25 sounder module and transducer with a paddle wheel (the A65 is available without the DSM25 option.)
Double check the connections between the DSM25 and the A65, as well as the transducer connection to the A65. There is an indicator light on the DSM25 to confirm it is on.
2. Make sure the paddle wheel turns freely. They tend to get fouled easily with debris and growth.
3. Make sure the A65 is giving to a reading for SPEED when underway or when having a buddy spin the paddlewheel by hand. Do not confuse SPEED with SOG. SPEED is from the paddlewheel.....SOG (Speed over ground) comes from your GPS sensor and is not used by A65 for log or trip purposes.
If you get npo speed reading at all the paddle wheel may be defective or the depth/speed transducer may be defective. See your dealer about a replacement.
Nov 06, 2007 | Raymarine A65 Combo GPS...
Maptech Offshore Navigator (EMSWOS) Logo
Top Maptech GPS Experts
Are you a Maptech GPS Expert? Answer questions, earn points and help others
