Question about Yamaha Full-Size Keyboard
Certain keys do not make a sound..
G , C sharp keys on left side of keyboard are silent, do not make a sound when depressed. Yamaha DGX-500
  • Yamaha Master
  • 5,603 Answers
The wire from pin 1 or 7 of CN1 on the GHL88L (left end) circuit board is open where it goes to the middle circuit board. This could be a bad cable, improperly seated cable connector, or a crack in the circuit board(s) connecting to these wires. These are the common matrix wires associated with only the C# and G keys for the left 1/3 of the keys. If more than 1/3 is dead, then the problem is likely on the middle board GHL88M that connects to the mating cable to the CN1 connector.
There are two wires dedicated to the keys for the two contacts that are used to measure velocity of the key strokes. There is a mechanical position between closing the contacts and the time is measured by the processor as velocity.
If you are the least bit worried about working on electronics you best have a service person do the repair. The keyboard has to be lifted out after removing the top and disconnecting other cables.
Posted on May 03, 2010
    New Friend:
I have a psr630 keyboard,and some of the keys are dead.solution please.
Posted on Oct 28, 2013
Yamaha DGX 220 All E and Bb keys above middle C will not play. All others OK
Just a shot in the dark but a lot of keyboards allow for splitting the keyboard in half or even in quarters to assign multiple sounds... have you tried a total reset? Or explore the manual for setting up a split keyboard. Might help.
Oct 26, 2017 | Yamaha Music
Does it have an internal battery?
HQRP AC Adapter / Power Supply for Yamaha PSR ... - Fixya
www.fixya.com/search/...hqrp_ac_adapter_power_supply_yamaha.../60...
HQRP AC Adapter / Power Supply for Yamaha PSR-280 / PSR280 / PSR-290 / PSR290 Keyboards Replacement plus HQRP Coaster, 600 related issues. ... is there an internal battery to protect memory and if so, do i need to replace it? yes there ...HQRP AC Adapter / Power Supply for Yamaha DGX-620 / DGX620 / DGX- ...
www.fixya.com/...hqrp_ac_adapter_power_supply_yamaha_psr/adapter
HQRP AC Adapter / Power Supply for Yamaha PSR-280 / PSR280 / PSR-290 / PSR290 Keyboards Replacement plus HQRP Coaster, adapter related ... need a new one, you could try to get a replacement from casio or try to get an ... It MAY appear to operate on DC BUT it can't generate the +/- voltages internally for sound .
Musical Instruments - Keyboard Accessories on Pinterest ...
https://www.pinterest.com/.../musical-instruments-keyboard-accessories/
HQRP AC Adapter / Power Supply compatible with Fulltone CATALYST / CHORALFLANGE Guitar Effects pedals Replacement plus HQRP Coaster by HQRP. $7.91. ... The MS-90 is a column monitor stand that features three internal channels - .... Yamaha SK88 Survival Kit for 88-Key YPG Series Keyboards by Yamaha.
Dec 25, 2015 | HQRP AC Adapter / Power Supply for Yamaha...
I have ve a DGX 640. When the play the C, followed by D, the D is silent. It occurs also when I play the black key after its white neighbour.
Possibly a rubber contact switch problem.
Open up your keyboard if you feel confident about doing so.
Remove the rubber contact strip under the faulty notes and clear away any dust ( this can be a cause of the note not sounding ) Swap this rubber ( part 220 ) on attached picture with the one next door to it. If the problem has moved to the next octave then it is a worn rubber contact switch replace ( see link )
If not you will probably need to take to a repair centre as it may be more serious.
Apr 03, 2014 | Yamaha DGX640 Music Keyboard
Yamaha dgx 500 keyboard
Unplug and leave it unplugged for a while and then make sure the plug is nice and secure on both ends and try again
Jul 28, 2013 | Music
The display screen for my DGX 500 is blinking on and off and is unresponsive.
Do you mean,"The HOUSE power went out" or, "The keyboard power went out"?
Mar 20, 2012 | Yamaha Music
Where can i find windows 7 x 64 drivers please help mee !!!
Your Yamaha DGX 203 Portable Keyboard - USB-MIDI Driver Version 1.2.2 ie. for OS Win9x/ME.
Yahama site does not have the Win7(x64) Drivers ie. USB-MIDI for your Keyboard Model DGX-203
But you can try the USB-MIDI Driver Version 3.1.0 for Windows(R) 7/Vista/XP 64bit for Model DGX-520 @ http://usa.yamaha.com/products/musical-instruments/keyboards/digitalkeyboards/dgx_series/dgx-520/?mode=model
I can't assured you that it will works on your system. Since your Keyboard is no longer in production, I doubt Yahama will provide you with the official USB-MIDI drivers for your Keyboard even you requested for it.
I guess this is an option you can try and hope it works & good luck.
Regards.
Apr 13, 2011 | Yamaha Dgx203 76Key Portable Keyboard
Can I connect a Yamaha DGX-500 piano to an amplifier?
yes - use two RCA cables from the left and right audio output and connect it to the aux audio RCA inputs of an amplifier or receiver.
Dec 06, 2010 | Yamaha Full-Size Keyboard
I am not getting any sound from my Yamaha DGX 200,
From Yamaha DGX 200 Manual
  • Q-There is no sound even when the keyboard is played or when a song is being played back.
  • A-Check that nothing is connected to the PHONES/OUTPUT jack on the rear panel. When a set of headphones is plugged into this jack, no sound is output. Check the Local Control on/off. (See page 69.)
Jul 29, 2009 | Yamaha Full-Size Keyboard
No sound when piano keys are pushed on my Yamaha dgx-620
I'm sorry but it sounds like you will have to have it repaired professionally.
Apr 20, 2009 | Yamaha Music
Yamaha Full-Size Keyboard Logo
500 people viewed this question
Top Yamaha Music Experts
Michial Gueffroy
Mike
Are you a Yamaha Music Expert? Answer questions, earn points and help others
