Question about Pyle 3000 Watts 2 Channel High Power MOSFET Amplifier Car Audio Amplifier
Right channel doesn't work
Ok the positive post on the right channel quit working and i'm trying to find out what to do to fix it
    Problem Solver:
  • 7 Answers
Check you rca jacks switch sides if the right channel still has no sound then it needs repair if the left channel doesnt work then the rca jacks are messed up
Posted on Mar 26, 2008
Nakamichi 1000 Tri-Tracer.When switch the deck on right channel has noise and doesn`t play.After 10-15 min it appears and sounds ok.Condenser on right channel just gone?
It can be that or a bad FET or some other part of the circuit. To get it fixed right I would consult Tom at the below location as he is a Nak guy.
Tom Brucker
Hi Tech Service
2934 Nolensville Pk.
Nashville, TN 37211
615-331-9241
hitech@BIRCH.net
Oct 18, 2013 | Audio Players & Recorders
No trasnsmission coming out of the speaker on one. 1 works ok and the other one doesn't
I don't know if the smaller ones like what you have operate the same as my 2 watt motorolas but I have a sub frequency on top of the channel. Check into that.
Jan 23, 2013 | Motorola Talkabout FRS 250 (14 Channels)...
YAMAHA RXV350 RIGHT CHANNEL NOT WORKING
Adding on again: I have interchanged speakers, if i connect any speaker on the right front channel it will not work. When I do a automated speaker test only right front channel does work.
Jan 26, 2012 | Yamaha RXV-350 Receiver
One speaker channel not working
Hello
You haven't given any details about your Denon amp, such as Model number. Yet I posts this solution. Check the speaker of the defective channel, by using a multimeter. Check the wire that connects to that speaker from amp. If both are Ok, the defect is with the amp itself. Just check whethere 'balance' control of the amp is set to extreme left or right. If it seems to be at one extreme end, make adjust it to the center position.
If all are OK and still you do not get any sound from one channel, the set need repair. OK.
Jan 22, 2012 | Denon Audio Players & Recorders
Have a 4 voice coil sub and dont know how to wire it
OK, first make sure what ohm load your amp can handle. This is always the first step. There are a couple of ways to wire this thing.
1. 2 channel, 2 ohm stable amp. Go from the positive of the left channel to the positive of two of the voice coils. Then go from the negative of the left channel to the negative of the matching voicecoils. Repeat with the right channel to the other two voice coils. You have set up a pair of parallel series. Four 4 ohm voice coils are now two 2 ohm loads.
2. Monoblock amp (single channel) 1 ohms stable amp. Go from the positive of the amp to all 4 of the positive posts on the sub. Then go from the negative on the amp to all 4 of the negative posts on the sub. You now have a 4 way parallel set up giving you a 1 ohm load.
Hope this helps
Aug 29, 2011 | Car Audio & Video
Right front channel not working
try to check balance adjustment if working.
Apr 16, 2010 | Sony STR-DE475 Receiver
My CT17 has a bad right channel. It plays ok for
change the part connected to the heatsink that you are spraying.
Sep 19, 2009 | Audio Players & Recorders
Alpine type-r 2ohm dual voice coil help
try reconnecting your rca's from the deck to the amp when finished wire one speaker positive to positive on left channel and negative to negative on right channel then connect the 1st subwoofer. if all power and sound is fine and working turn off power to amp and connect negative terminal of 1st sub to positive on 2nd sub and positive from first sub to negative on second crossing the wires runs the speakers in series another way to try is parralel the speakers wiring by connecting positive left channel output of amp to positive on 1st sub same with the negative then splice positive to positive on second sub and same with negative.
Feb 09, 2009 | Alpine Type-R SWR-1222D Car Subwoofer
Only one sub works
The amp should produce no output when using the left negative and the right positive.
If the amp works bridged (left positive and right negative) with one speaker AND works when you connect one speaker from the left positive to the right positive, it would appear as though the right channel isn't getting any signal.
Try inserting only the left signal cable (nothing plugged into the right RCA jack) to see if the right channel will work when a speaker is connected to the right channel speaker terminals.
Jun 30, 2008 | Sony XM-2002GTR Car Audio Amplifier
Viewsat Ultra - No channel
try this, remove the cables and cross the wires over on the cable, use a piece of metal, hold it on the cable for around a minute, see if that work, also turn the view sat box off for 20 min, see if this helps
May 15, 2017 | GPS
Pyle 3000 Watts 2 Channel High Power MOSFET Amplifier Car Audio Amplifier Logo
153 people viewed this question
Top Pyle Car Audio & Video Experts
xxxxxx xxx
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pyle Car Audio and Video Expert? Answer questions, earn points and help others
