Question about Car Audio & Video
Factory radio keeps blowing fuses.
  • 1993 Lexus sc400 keeps blowing the main radio fuse,with the ignition off.The antenna is broken so I disconnected it,still continued to blow the fuse.CD changer stopped working about 5 years ago.Could it be the amp or cd player that's causing the short or what?
    Problem Solver:
  • 7 Answers
You should bypass the factory cd player. I installed a panasonic cd player in a 1994 gs 300 and it was hell. there are alot of wires that have nothing to do with the radio i believe one or some of those wires may be whats causing your problem try this solution if that doesnt work you may have a serious electrical problem
Posted on Mar 26, 2008
Fuse f23 keeps blowing, removed all lights on circuit still blows . Also disconnected power antenna and trunk release solenoid no change. When turning on headlights gauge lighting and radio lights inop....
if you are still blowing fuses with nothing connected in the circuit you have a dead short-a pinched or grounded wire-look at the wiring going into the deck lid-you might call this the boot-the other stuff may be happening because the computor can't understand whats happening with the short going on-its confused-cheers Denny
Oct 30, 2013 | Lexus Cars & Trucks
I HAD ALL MY FUSES CHECKED INCLUDING THE RADIO FUSE..THE GUY AT AUTO ZONE SAID IT'S NOT MY FUSE BUT THAT I NEED THE "FACTORY CODE" TO RESET THE RADIO/CD PLAYER.. PLEASE CAN YOU GIVE ME THE CODE FOR MY 1992...
The password/code can only be retrieved from service center or from the dealer of the unit. Because at the back of the unit there is a serial number mentioned and the password/code only can be retrieved from the serial number. Each and every device/unit has its own serial number so one serial number code/password will not work with other serial number code password. The service center or the dealer has the list of code for the serial number so as soon as you provide the serial number he will get the password/code retrieved for you through the list. This will help.
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Jun 29, 2010 | Lexus SC 400 Cars & Trucks
Radio stops working. Why does the fuse keep
First is that the stock a radio. If it's an aftermarket disconnect any amplifiers, also if there's a power antenna disconnect that sometimes they become jammed. If you still blown fuses disconnect the radio and check to see if it's still blowing fuses. If not get a wiring diagram and find out what other things are on at circuit. It's a simple process of elimination. Good luck with that.
Jun 06, 2010 | 2004 Ford Explorer
How do you remove the broken plastic gear fromthe antenna motor 1997 lexus SC400
You will need to take the antenna motor out and take the cover apart to remove that piece. Pretty simple.
Nov 23, 2009 | 1997 Lexus Sc 400
I can't find the fuse box for a 1993 lexus sc400
The dash fuse block is located behind the kick panel to the left of where your feet would be on the drivers side of the car. There is also a block in the engine compartmentt
Jun 24, 2009 | 1991 Lexus LS 400
Starter fuse under the hood keeps blowing....the factory deck was replaced by a new deck...every since then the ignition fuse keeps blowing..
the new radio install is causing this if the power was taped into the starter system. rec. removing wires then try to see if you can blow your starter fuse
Jun 01, 2009 | Car Audio & Video
1992 Lexus SC400 No Heat, AC, Defrost (mode controls)
Change the 15amp fuse in the kicker fuse panel labeled cig. My stopped working for the same reason.
Feb 20, 2009 | 1992 Lexus Sc 400
Radio Blowing Tail Light Fuse
by the way you tell me that the radio illumination is the gray wire and all of the rest you are wrong. try the correct way red is key positive,yellow is constant power,black is ground,orange is illumination,blue is remote,gray is right front positive and gray black is negative,white is left front positive and white black is negative,green is left rear positive and green black is negative,violet is Right rear positive and violet black is negative,
Nov 23, 2008 | 1993 Oldsmobile Cutlass Ciera
Car Audio & Video Logo
374 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
