Question about Intel Motherboard
I have an intel dp35dp with video problems double image one inverted
  • 63 Answers
Pls add a pci grafics card
Posted on May 03, 2010
Screen upside down
If the mouse is also operating inverted then the video has been rotated by the video software. You can fix that by going into the video setup (nVidia/ATI Catalyst/Intel) and finding the rotation feature and re-inverting the image. If the image is inverted, but the mouse moves normally on the screen, then you have a haunted PC and should run for the hills!
Nov 08, 2015 | Acer Aspire 5241 5251 5332 5334 5338 5516...
Motherboard DP35DP Installation Problem
You should try a regular ps/2 mouse and keyboard.  You probably don't have the USB drivers installed for the new board.  After you get booted into windows you'll be able to install those.
Oct 12, 2007 | Intel Motherboard
How to reset cmos intel motherboard dp35dp
disconnect from power. remove case cover and remove motherboard battery/power cell. leave unplugged for five minutes the n re-insert battery and power up. All peripherals should also be switched of at the power outlet. IF,after having performed the above procedure, the fault still occurs it is probable that you need a new motherboard.
May 22, 2014 | Intel Motherboard
Upper sise of screen flickering problem
Technology b> A laptop's display assembly consists of an LCD panel, an inverter board and a backlight lamp. The inverter board supplies power to the lamp which lights up the LCD screen as it generates images. Light from the lamp is then uniformly distributed over the panel to create images. b> Cause b> Flickering is commonly caused by a damaged or malfunctioning inverter. Because a faulty inverter is not able to supply adequate power to the backlight lamp, the screen goes dim each time the backlight loses power. In some cases, flickering may also be caused by a faulty connection between the inverter and backlight lamp. Diagnosis b> Resolving a laptop screen's flickering problem entails correctly diagnosing the problem and replacing the faulty component. You may diagnose the problem by hooking up the laptop to an external display unit, such as a projector. If the external display has the same display problem as the laptop's LCD screen, it is indicative of a motherboard or video card problem. If the external unit displays bright, crisp images, the problem is probably caused by the backlight or inverter. b> Solution b> You may repair a laptop screen's flickering problem by replacing the inverter board or backlight. Order parts from a trusted supplier and replace the component by referring to your product documentation.
http://www.tech-faq.com/how-to-repair-a-laptop-screen.html http://www.laptop-repair.info/laptop_screen_repair.html b> Hope this helps.
Jan 21, 2013 | Lenovo IdeaPad S300 59359327 Silver Gray...
Intel DP35dp motherboard
sounds like you "might" be having a capasitor starting to fail look at your cap's to see if any have a dome look insteed of flat like the rest if so you have 2 options have the cap's replaced (some tv repair shops will cost $5.00 per cap for $50.00-179.00 or upgrade to a new mother board if you know someone who talks ham radio they can fix it also if they have the equipment
Dec 24, 2009 | Intel Motherboard
About motherboard
asus p5nsli has a lot more options as compared to the intel. it also supports overclocking so you will be able to boost your processor when the time comes :)
Oct 13, 2008 | Intel Motherboard
Still Doesn't Work
You needed to configure bios (F2) when you first installed the processor,
now the Bios hangs before anything can happen,  You need to remove the Bios Battery (looks like a coin on the mobo) for about 30 secs (with the power disconnected)  then re-insert the battery and power on.
you should get the same power on message as you did the 1st time (maybe with a missings settings error too but this is expected)
Enuro12 is right about legacy USB in that your keyboard should work in BIOS (setup)
Motherboard Installation Problem - Intel DP35DP
Have you tried clearing the CMOS, and rebooting with a standard keybord and mouse. ? (non usb)
Intel Motherboard Logo
65 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
