Question about Coleman Powermate DuraBuilt 1400 PSI Pressure Washer
The handle on the powerwasher leaks and the opening will not close. This has cost it to loose pressure. Can this be fix or do we have to purchase a new handle?
Why is gas tank leaking?
you either have a hole in tank or a hose is bad, take some silicome and patch
Jan 04, 2016 | Garden
Why does washer leak excessive water?
Some times the power washer are made poorly. If the leaks are at the hose connection you can replace plastic with a better one made of brass and the use of Teflon tape. Good luck
Sep 08, 2014 | FAIP Powerwasher Pw1400z 1,400 Psi 1.5 Gpm...
Where can I find a replacement for the trigger handle for task force 2000
There are quite a few replacement guns and hoses. If you do a search; " replacement power washer guns" you will have many sites wit numerous guns that will work.
  • Sorry, this item is not available in
  • Image not available
  • Amazon com Powerwasher 80012 Universal Electric Pressure Washer...
    Jun 03, 2014 | Task Force 2000 PSI Electric Pressure...
    Craftsman 2200psi powerwasher does not have much water pressure, why.
    This could be several things. There is a bypass valve that opens when you are not using the sprayer. This keeps the water from causing problems by building pressure. IT dumps the water back to the suction side of the pump from the output side. IT might be out of adjustment or it could be stuck open. The other thing is that the valves in the pump itself are not closing.
    May 18, 2013 | Garden
    Fixed leaking faucet, now handles leak at the base & the water pressure is low
    No, air can't get trapped in there. I don't think you did anything wrong. It sounds like the valve or internal parts are worn more than new washers take up for. Tightening down the valve just reduced travel for valve to open fully. Can't think of a fix; where's that joe da plumber?
    Nov 23, 2011 | Plumbing
    Lavor Super wash Powerwasher.Lidl. Pressure leak O ring replaced at Venturi & wrote down wiring diagram for On/Off switch as follows- Blue Red Brown, Black. Had to disconnect wiring from On/Off...
    hi i have a lavor 160 superwash all off the lances work except when i put the turbo lance on it gives high pressure and then goes to low pressure like starting then stopping can anyone help me or tell me what the problem may be
    Feb 28, 2011 | Kitchen Ranges
    Have a 1998 Jimmy, the driver door is stuck in the close position and can not close the door. The handle seems to be working properly; inside handle moves the cable that permits the door to close and...
    with the door open see if latch is stuck in close position . If so hold handle open and pry with screwdriver to open latch ..If that works latch needs to be lubed for smooth operation
    Feb 17, 2011 | 1998 GMC Jimmy
    My culligan water filter is leaking, no idea why. Is there any way i can stop this?
    Turn the water supply to filter system off, open the faucet to relieve the pressure.
    It depends are where it is leaking form. If you just changed the filter it is either not on all way, the o-ring is pinched or missing, or the inlet line, outlet line (or both) were worked loose and are leaking.
    Check the feed valve to the filter also. If it is a saddle/ piercing valve it may be leaking. After opening and closing these valves several times the "packing nut" may work loose and the valve leaks. Tighten this very slightly until leak stops. Here is a diagram of a saddle/piercing valve.
    The packing nut is right below the T handle as in this picture. There is seal under the packing nut and this is where it can leak from when the nut works loose. AGAIN tighten this very slightly to stop the leak.
    RJ
    Aug 23, 2010 | Culligan Under Sink Water Filter
    Just fired up my Coleman Powerwasher 1100. I have
    Nozzle is plugged. Stick small diameter wire in nozzle.
    Aug 30, 2009 | Coleman Garden
    Trunk/hatch will not open. handle seems loose, no action. Wondering if something is broken. How would you repair it. Can't find any other way to open trunk. The glass window part opens.
    2000 ford explorer back hatch handle loose door locked The linkage on the back hatch came unfastened and the handle was loose. Ford uses plastic fastener clips over perfectly good threads to hold this together. The outdoor plastic handle is only conected to the car with two aluminum ribets. One was already missing on mine. But if you just want to open the door, you can rip the handle off and pull it out. hopefully you won't crack the plastic. You can see the linkage screw hanging as you look up through the left hole. Grab it with a plyers and apply a steady force down. This will open the hatch. I just rigged up a different handle and put a nut on the treads to hold it together. This can all be done without tearing appart the interier and may only take 20 minutes. I used a rope and handle from the garage opener, a medium size washer and a nut. First make a small loop, with a small hole to slide over the linkage screw, then the washer, then the nut. Slide the other end of rope through the handle, move the handle very close to the vehicle and tie the not close. Trim the rope and wala ... the hatch works. Or you can pay $300.00+ to have it fixed with the clip.
    Jun 30, 2009 | 2000 Ford Explorer
    Coleman Powermate DuraBuilt 1400 PSI Pressure Washer Logo
    202 people viewed this question
    Top Coleman Garden Experts
    John Trevino
    andy just round the...
    Level 1 Expert
    Simon Flummox
    Simon Flummox
    Are you a Coleman Garden Expert? Answer questions, earn points and help others
