Question about Car Audio & Video
Volume switch stuck
Its a small electronic push switch to lower the volume dont no the name of the part to order a spare
  • wolf471 May 12, 2010
    thanks
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 155 Answers
I think its time to get a new one, aye.
Posted on May 12, 2010
Testimonial: "thanks mini micro switch ,cost £3 easy fix. "
Can my son's forgotten password on his Zeiki tablet be manually overriden?
You have to reset your tab its at the back of your tablet .or you may go nearest service provider to unlock it.if is not working go to unlock account enter your user name then choose pattern enter your new pattern and then enter it again for confirmation..or u shut down the device then hold the power button hold again the volume up and the power button together.you see the recovery mode scroll down the with volume down button press the factory settings using the power button..then press the power button again to reboot make sure your battery is fully charge.
Apr 25, 2015 | Tablets & eReaders
I bouhgt replacement battery for my jet bok, but dont know how to change it?
Remove the small round rubber covers on four corners, no need to open the two bigger ones
now comes the toughest part
try to push in a small screw driver through the edge, do it gently and preferably on the lower corner,so that u dont damage screen in case u slip.
once u get a small opening try to take apart the cover.
this requires a lot of patience but once u get an opening of a inch or so it becomes easy
then when u are done with removing the whole cover u will c the battery
find the connector and again with a small scerw driver gently push away the connector, again lot of patience.
Again the connector of the new battery has to be put in carefully.
Once its pushed in all the way u r done.
Close the cover and charge the battey for atleast for 10 hours.
U r done with the replacement
May 07, 2012 | Ectaco jetBook
Vizio VF550M volume stuck at 100
The 2 suspects are possible but there is a way to find it..try to get the control board and remove the vol+ button on it..then back the controller then power it on again try to push vol- on remote or TV..if no help you have faulty main board..
Mar 06, 2012 | Vizio VF550M 55 in. LCD HDTV
Lately, my vacuum will only turn on when the accessory hose is hooked up. If I have the carpet brush attachment in place, the power will not turn on. I noticed that there are 2 switches that need to be...
It is most likely the switch. To be certain, hold the lower switch button on the front in with a small screwdriver and push the switch. BE SURE to push the button in first, and then the switch. If the motor doesn't start, you need a new switch assembly.
Feb 23, 2011 | Kirby Ultimate G Bagged Upright Vacuum
The on/off button is stuck in the on position and we can't get it to turn off. The fan is running constantly. If you push the other buttons (boost, higher & lower volume) nothing happens. Anyway to...
your switch has burned to the on position this is due to a dropped brass striker in the switch you will need to have the switch replaced pop the switch out and re install the replacment switch as per the wiring on the old one and it will work fine you will need to find you nearest appliance spare parts retailor they are listed in your local phone guide
best of luck
merry christmas
please take time to rank this advice
Dec 08, 2010 | GE Monogram ZV1050SFSS 42" Island Chimney...
Silent mode button broken.
Dont try to take short cuts. They make make things worse. Just send it in to iphone recharge. They can open it and maybe fix it without any parts (cheaper).
Try iphone recharge.
Jul 16, 2009 | Apple iPhone Smartphone
Up & down push button not working
Repaired the same problem several months ago. The up/down control has a very small switch located under the button. The switch is part of the selector switch assembly that costs upwards of $100. However, the switch itself is available from Digi Key electronics part # P12321-SCT-ND at about $1.00 each, plus shipping. If you can handle the unit disassembly, which is extensive in this repair, and can solder very small switches, this is an inexpensive fix. I suggest you buy some spares. I'm looking for a seal replacement for this unit right now. Good luck.
Dec 02, 2008 | Thermador UCV36A 36" Universal Cook 'n'...
My car won't go in gear
I got same problem when I first got the car (bought used), took me a day to find out one of the fuse blown caused the problem now I always have 10A fuse spare in my glove comparment, check all your fuses (I believe it's an Audio/Clock 10A fuse) will solve your, good luck ...
Oct 06, 2008 | 2005 Chevrolet Aveo
Zenith dvt412
Sounds like the system switch is broken. They use a piece of spring steel thats bent up to provide a snapping action (its very small). After years of continuous pressing the metal fatigue fails and breaks so there is nothing to keep the contacts apart. The most common button you will see this is in the volume up because its used the most. It seems that people usually adjust their volume up in more steps than lowering the volume as their ears adjust to the levels plus people tend to push the volume up button harder than the volume down.. There are a couple things you can do when this switch goes bad. There is probably a button on there that you dont ever use or could live without (loudness perhaps). You can take the good switch off that button and replace the volume button with it. You can do this by either desoldering them or by popping the clip off the switch and replacing guts. I have found it much easier to desolder them however because the small pieces are difficult to manipulate. If you dont want to lose the function of another button, you can try matching the switch with one from an electronics supply place like digikey, or go to a repair shop and ask them to replace the button or sell you a good button out of a broken face. Good luck!
Dec 12, 2005 | Zenith DVT412 System
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
