Question about Mitsubishi WD62627 62" HDTV
Re: Mitsubishi WD62627 projection TV issues
My Mitsubishi WD62627 HD rear projection TV will go all black and white after it's been on for a few hours. Turning the unit off for a few minutes and turning it back on will bring back a good color picture but it will eventually go all black and white again. Could this be something such as one or more defective surface mount capacitors? If so, which board(s) should be investigated or could it be the light engine?
  • gregz33 Mar 26, 2008
    ICS being which part? Forgive my ignorance, I'm new to this type of TV.
    Greg
  • gregz33 Jun 09, 2008
    I found the solution to my problem and it has worked on two different WD-62627's both with the same problem of the pictures going black and white after the sets had been on for about 20~30 minutes. I suspected that the color wheel might be the culprit. I removed the color wheels from both light engines and flushed out the back sides (where you can see the pulse coils in the back of the color wheel motors) liberally with Ronsonal lighter fluid, which is basically naptha. I used lighter fluid for years in camera repair to flush out micromotors that would slow down or bind over time. The Ronsonol evaporates quickly and does not leave a harmful residue, however, I blew each one out with compressed air to make sure there was no liquid left. I then cleaned the glass on the color wheels, installed them back into the light engines, and installed the light engines back into the TV's. Both have been working fine for several weeks now. I do not claim this technique as a panacea but it has worked for me.
    Greg
  • 3,037 Answers
This is the most common problem for rear projection tvs and it is known as the color convergence problem.You will need to replace or repair its ics to solve it.
Posted on Mar 26, 2008
  • 2 more comments
  • Benjamin Patri
    Benjamin Patri Mar 26, 2008
    Mitsubishi Contact Information
    Main support number 800-332-2119
    Support FAX (714) 229-3854
    Email support CustomerCare@meus.mea.com
    Please let me know if you need any more help on this, thank you and have a good day
  • Benjamin Patri
    sorry it is ICs
    An integrated circuit (IC), sometimes called a chip or microchip
  • Benjamin Patri
    Here is the definition
    you might want to take it to be repaired if you don't know what you are doing, and be careful because electronics can be dangerous if you choose to work on it yourself
  • Benjamin Patri
    I don't know if you still have a warranty, but I would think that this would be covered, have a good day
The color went out so that now it is black and white. If I turn off the tv for a few minutes it will go back to normal. Then after being on for a few minutes it will change back to black and white. If you...
This is unusual for this model, can you tell me what source you use for signal? Cable? Sat? Direct TV? Also how are you connected----via the coax fitting or the rear AV jacks.
Steve
Nov 01, 2011 | Mitsubishi WS-65809 65" Rear Projection...
Tip
Fix for Mitsubishi WD-62627 going black and white
I found the solution to my problem and it has worked on two different Mitsubishi WD-62627 DLP rear projection HDTV's both with the same problem of the pictures going black and white after the sets had been on for about 20~30 minutes. I suspected that the color wheel might be the culprit. I removed the color wheels from both light engines and flushed out the back sides (where you can see the pulse coils in the back of the color wheel motor in the picture below) liberally with Ronsonal lighter fluid, which is basically naptha. I used lighter fluid for years in camera repair to flush out micromotors that would slow down or bind over time. The Ronsonol evaporates quickly and does not leave a harmful residue, however, I blew each one out with compressed air to make sure there was no liquid left. I then cleaned the glass on the color wheels, installed them back into the light engines, and installed the light engines back into the TV's. Both have been working fine for several weeks now. I do not claim this technique as a panacea but it has worked for me.
Greg
on Jun 09, 2008 | Mitsubishi WD62627 62" HDTV
Tv black and white
this tv is plagued with bad caps, all of them had them. they will cause this and many other problems,, here is my tutorial on the issue=
mits caps
http://www.fixya.com/support/r5069371-mitsubishi_led_keeps_flashing_green
Let me know if I can be of further assistance.
Jul 27, 2010 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi TV having issues with HD channels
Unplug for a few then try it again you need to search channels again
Jan 27, 2010 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi vs-5041 -after a few hours on, the tv goes black
Get the projection bulb checked if fine its something internal in your tv but i think you need new bulb
Aug 01, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi HD 50" rear projection tv is only showing picture in black and white. What is the problem?
Is sounds like to need to go to SETUP and set the unit to color. Also, weak signals will cause the unit to switch to B/W. Try using OTHER inputs (like DVD) to see if you still have no color. If no color, it could just be a SETUP problem...or..(ugh!) you have lost your color wheel or related circutry. (no easy fix)
Jul 13, 2009 | Mitsubishi WD-52525 52" Rear Projection...
The T.V. works fine, but when we plug in playstation it goes to black/white.
I had this issue. If the tv is an HD, you will need to get new cables for HD. This solved my problem.
Jul 10, 2008 | Proscan PS61670 61" Rear Projection...
Projection LCD flickers to black and white
If the S-video cable is not completely in it will do this. You need to remove and clean tips on S-video cable/ replace, this is your problem.
Mar 10, 2008 | JVC HD-52Z575 52" Rear Projection...
Mitsubishi rear projection
On every input?? RF (coax),yellow(composite),S-Video and
component (red,green,blue)??
Verify model # please......T.
Oct 21, 2007 | Mitsubishi WS-55859 55" Rear Projection...
Mitsubishi WD62627 62" HDTV Logo
237 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
