Question about Garden
Gas,oil ratio i have a 3300 homlite chainsaw what is the gas and oil ratio?
    President:
  • 2,468 Answers
50:1 ratio on this series
Posted on May 03, 2010
Homlite string trimmer sx-135 ut-20609 a ratio gas & oil mixture
You should mix 8 Oz. of two cycle oil to one gallon of gas. I put the oil in first and then the gas and it will be mixed and ready to go.
Jun 08, 2016 | Homelite Garden
What is the fuel mix ratio?
Hi David:
Chainsaws are 2 cycle engines and must have the oil mixed into the gas. Modern chainsaws use a ratio of 50:1
Tat is, 50 parts gas, 1 part oil.
Make sure that you use oil that is specially intended for this purpose. The container will usually have a chart that shows how many litres of gas for how many cc of oil.
Jun 18, 2015 | Garden
I have a homlite chainsaw with a zama c1q h17d carburetor and need the correct fuel line routing including the oil pressurising line
One fitting on the Carb is a bit higher than the other.
The Upper one is for the Gas return when you press the Primer bulb. The Lower one is for the Gas intake...the gas line with the Filter on the end.
Is thee a small fitting for the Pressurizer on the small spacer??
Oct 01, 2013 | Homelite Garden
What type of petrol do I get for the chainsaw
What make and model of chainsaw do you have?
Chainsaws take the same gas you put in your vehicles, however the gas must be mixed with 2 cycle oil. The ratio of gas and oil depends on the make and model.
Reply back and I will look up the gas/oil ratio for you.
Thanks,
Handie Andie
Apr 21, 2011 | Garden
Gas/oil ratio mixture; chain oil lubricant
Call their customer service at 1-800-242-4672 there are options to choose for gas/oil ratio mixtures info.
May 26, 2010 | Homelite Consumer Products 9.0 Amp, 14 In....
I have a 3300 homelite chainsaw 16'bar,what is the oil,gas ratio?
This should run well with 40:1 ratio using modern synthetic saw oils only. Always premix the fuel and oil in a can before adding to the saw, then agitate the saw to mix the old with the new. Hope this helps!
May 03, 2010 | Homelite ZR10926 16 Chain Saw
Gas/oil ratio for a Homlite yard broom UT 08026H blower
It's 40:1 but there are oil mixes out there now that you can buy that you mix with one gallon of gas and then it is safe for all 2-cycle engines...a real plus if you own multiple units with different mix ratios.
Jan 10, 2010 | Garden
Gas/oil ratio for a Homlite UT 08026H blower?
I USE SOME STUFF CALLED OPTI THAT WAY YOU ONE CAN FOR ALL YOUR 2 CYL STUFF ITS GOOD STUFF
Sep 29, 2009 | Homelite 'Yard Broom' Leaf Blower
Craftsman chainsaw ps00376 2.0 cubic inch oil/gas ratio
Hi rbv1222,
40:1 is the ratio.
40 parts Gas to 1 part oil.
3.2 oz of oil per gal gas.
Glad to be of assistance. Please rate the solution because I can learn from your rating.
Thank you
Nov 08, 2008 | Garden
Garden Logo
59 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
