Tape deck is broke sounddesign model 5959
Tape deck wont work but stereo and 8 track player do. the belts not turning
    Master:
  • 518 Answers
If the motor is running but the belts are not, then they are probably shot. You can buy belts by size or buy a belt kit at MCM Electronics.
If the motor is not running it could be 2 things: 1. A bad motor or voltage to the motor.... 2. A bind. I've seen the grease on the capstan bushing get old enough to turn into a very hard tar. So check the motor and capstan for freedom of movement.
Hope that helps you get it working...
Geno
Posted on Mar 26, 2008
SOURCE:
How do you record on 4 tracks?
If you have a 4 channel quad tape deck you arm all four tracks and hit record and play and it will record on all 4. If you have only a stereo deck you can only record on 2 channels at a time.
What model are you talking about?
Apr 20, 2015 | Audio Players & Recorders
Need 8 track belt for philco console stereo h843gpc
What you need to do is measure the belt's diameter and also width in MM. You don't have to be spot on with these. Then put the measurements into Google with the words "drive belt XXmm by XXmm".
Drive belts are not specific to one maker, so don't worry about the brand name. Just get the nearest to your measurements.
Apr 04, 2013 | Audio Players & Recorders
My Philips MC145 tape deck doesn't work all of a sudden
I am guessing you took this apart? It sounds like the drive belt broke.
Feb 08, 2013 | Audio Players & Recorders
Tape slots won't open and nothing is functioning.
you need to replace your belts, go to partstore.com, punch in your model number and it will give you the correct belt's that you needed
Jun 06, 2010 | Sony TC WE435 Stereo Dual Cassette Deck...
8 track player moters run but it doesnt pick up the music.
Sounds like either the head is open circuit or more likely the pre-amp for the 8-track has gone. Follow the leads from the head and it should lead you to the PC board of the amp. Check for broken connections first. You should get the pre-amp to buzz by touching the terminals where the head leads join. As you are getting no sound from either channel it might be the power to the board. But if you see a single IC it might have gone. For the power option (if the channels are seperate) suspect the largest electrolytic capacitor on the pre-amp board first.
By the way if you get a buzz from both channels the head has gone.
Apr 19, 2009 | Audio Players & Recorders
Cassette Tape Deck Problem
Unit may have worn belts that are slipping. All cassette player belts are subject to deterioration even if recently installed. You may try ordering the belts yourself and have a service tech install them. The tech that installed belts 9 months ago may have used used belts. Although dishonest, it is common.
Jul 17, 2008 | Sony TC WE435 Stereo Dual Cassette Deck...
Sony dual cassette deck TC-WR535
i had the same problem of not opening the cassette doors and not running with my sony tc wr535. After I repaced the belts myself with new ones it did run fine! :-) An original sony(!) rubber belt set for the two decks costed me 23 euroos incl pp.
Nov 29, 2007 | Sony CASSETTE DECK Single Dual Cassette...
Tape deck won't open
If this is a deck where the tape slides in horizontally, like most car stereo tape players, you may have a broken or slipping belt. The fact that you "haven't used it in a long time" suggests a worn-out belt.
In my car stereo, the belt slips when it's cold and won't play or eject the tape. After a few minutes, the unit "warms up" and the belt starts turning. Then everything is fine.
I think we both need to replace our belts.
Nov 17, 2007 | Audio Players & Recorders
189 people viewed this question
 Grubhead
Grubhead
Marvin
Marvin
