Question about Frigidaire GLEQ2152ES Electric Dryer
Error "AD" when drying
I get an error when drying. it states "ad" on the timer part please help
  • 3 more comments
  • Anonymous Aug 15, 2008
    after a few minutes dryer displays ad no heat
  • Chopin31 Aug 27, 2008
    i recieve the same problem and i havent even used my dryer much, i bought it last may 2007 but have maybe used it 3 or 4 times because of a house renovation project. i tried the main breaker switch on the how bust still the problem persists where it runs and never warms up and after a while it will stop and display Ad and the four blinking lights next to it. Please help
  • Anonymous Apr 03, 2009
    I'm having the same problem as the original poster, except mine shuts off after about 15 minutes with the 4 blinking lights. - I guess thinking the clothes are dry (they are not).
    No error code is displayed. Thanks for the education on the definition of error codes, but that doesn't solve the problem.
  • Ji?w?n G?ngc?
    Ji?w?n G?ngc? Sep 13, 2014
    I'm having the same problem! It looks like a common problem. The Frigidare should do recall and fix this problem
  • Ji?w?n G?ngc?
    "Front load Fridgidare error" How do you fix this error Ad = A = 10 B?
Yes that is correct ... I was painting my house and they had covered the vent so the airflow was not working correctly and it kept indicating auto dry (need more time indicated) . i figured this out afterwards but thank you for replying
Posted on Mar 27, 2008
    President:
  • 1,314 Answers
Thats not an error code error codes are f codes eg. f01 f02 thats a cycle code for auto dry are you having any promblems other than the display
Frigidaire affinity dryer code ad
Hey Cindy, thanks for your submission!
I see that your Frigidaire dryer is displaying an error code of "ad". The "ad" error code will display with the "Auto Dry" cycle has been selected. If you did not select the auto dry cycle I would suggest performing a reset on your dryer and you can do that by disconnecting the power cord for at least ten minutes. Once power has been restored to the dryer and if the error code is still persistent you may need to have a replacement control panel or wiring harness installed. I would recommend having electrical parts replaced by a professional technician this will prevent any personal injury. Best of luck! -Matt
Mar 08, 2016 | Frigidaire Dryers
My frigidaire dryer GLEQ2152ES0 runs but no heat ?
Good Morning Friend,
I understand that you are receiving an "AD" error code on your Frigidaire dryer, model# GLEQ2152ES0. I also see that your dryer is not heating. The "AD" code states that your appliance is in an auto dry cycle. I suggest resetting your dryer, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and start any cycle. If further troubleshooting is needed, I ask that you please let me know the error codes displayed on your appliance. Hope this is helpful.
-Best Regards-
WP
Jun 09, 2014 | Dryers
Ad error code
I understand that you are receiving an "AD" error code on your Frigidaire dryer, model# AGQ7000E. I also see that your dryer is not heating. The "AD" code states that your appliance is in an auto dry cycle. I suggest resetting your dryer, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and start any cycle. If further troubleshooting is needed, I ask that you please let me know the error codes displayed on your appliance. Hope this is helpful.
-Best Regards-
WP
Jun 06, 2014 | Frigidaire AGQ7000E Gas Dryer
Error code AD error code DN
it means auto dry it will check the temp of the clothes so if they dryer quicker then 40-45 minutes it will shut off earlier instead of running the full 40-45 minutes. In the manual it says AD is the adjusting time according to moisture level for those who keep drying but display this it is normal for those who display and size to dry is not normal if you have any further questions message me back and please remember to rank how this opinion has helped it allows me to help others in similar situations Thanks Rick
Mar 14, 2011 | Frigidaire GLEQ2152ES Electric Dryer
The dryers heats up but doesn't completely dry clothes. After 10 minutes a code Ad appears in the timer slot. What is the issue?
AD is air dry, more then likely the vent is restricted and needs cleaned out, you will need to clean the inside of the dry out,also. You thermal fuse is bad. here is a website that will help Good Luck Tim
http://www.davesrepair.com/DIYhelp/DIYthermalfuses.htm
Mar 12, 2011 | Dryers
I have a Kenmore 70 top load dryer that is not heating. And the timer doesnt turn off anymore either. Both items seem to have malfunction at the same time. Help?
This is typical. If the heating element is no longer working, the unit doesnt know to turn off due to the clothes still being wet. However, the timer has absolutely nothing to do with the heating of the unit. If the timer doesnt turn off the unit even when the time is short (example: 10 minute timed dry), the timer has a different issue. If you have merely set the dryer to dry the clothes (not a "timed cycle" to dry) then the dryer will continue to run as I have stated before. The dryer will run until the clothes are dry. Now, its time to address the heating part. Your dryer heating element has gone bad. It can be replaced if you are somewhat handy. You can pick one up from your local appliance store and it has simple instructions. Please make sure that you disconnect the unit from its power source prior to attempting any repairs. Safety First. You can also call someone to replace it for you and it shouldnt be too costly. Good luck on either option.
Feb 08, 2011 | Kenmore Dryers
My Frigidaire dryer has an error code of AD and is taking forever to dry our cloths. Please help.?
Hi
Thanks for using FixYa. Error code AD means air/auto dry. This type of dryer has no thermo fuse which is a fuse like part that tends to break disengaging the heating element, there for the dryer has a busted heating element, you’ll need to replace it then it should be good to go. Normally runs parts and labor about 150. Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Jan 28, 2010 | Frigidaire Dryers
The dryer ran all night and i suppect the timer is bad. now on some settings the timer works but doesn't always heat up. other times it does. will a timer fix all the issues?
Which setting are you using? Time dry or automatic. If all this happens when ueing timed dry, yes your timer is bad. If your using the automatic dry, it sound like the moisture sensors are bad. It all has to do with which setting is being used. If you need further help, respond with your question and I'll be glade to help.
Please rate solution
Sep 11, 2009 | Whirlpool Dryers
DEAR FRIEND,
ngfam1 here for you!
I am happy to be of assistance!
Do you clean your lint filter every load?
If the vent is blocked it will not get hot either!
Check the outside where the dryer vents out and be sure the outside screen that keeps small animals out is not clogged!
Even half way cloged will stop the drying process!
Other wise this is a situation that you will need to call service!
Now you can call the manufacturer and tell them even though
its after the warranty that you were building a home and not used it till last week!!!
Ask for a supervisor an tell them you did not purchase you stainless steel kitchen yet and must be sure they honer their workmanship first!
I use this for my customers all the time to get things done for them! It will work if you are calm quiet and persistent!
Here is the service company I refer my appliance customers too!
A&E Factory Service
A Nation Wide Company. / Available 24 / 7 for arranging appointments! In the USA.
1(800) 905-9505
You will be fine now!
Thank You
Bless you,ngfam1
PS. PLEASE GIVE ME A GOOD RATING HERE ON FIXYA.COM BEFORE YOU SIGN OFF!
Aug 27, 2008 | Frigidaire GLEQ2152ES Electric Dryer
Frigidaire GLEQ2152ES Electric Dryer Logo
1,537 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Electrolux
Electrolux
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
