Should I be able to use a playstation one with a new Technika LCd tv ? When I use the ''component'' mode it says on the screen that there is ''no signal''
  • 4,234 Answers
I believe that the playstation 1 uses a standard AV cable with Red/White and Yellow connectors. The video (yel) is a composite video signal not component. If your set has a yellow video input, it should work using that. If not, then connect the yellow to the GREEN connector of the component set and you will see a green picture.
Dan
Posted on May 03, 2010
My Technika 15.6-600 lcd tv is behaiving abnormally, is doing on and off modes, what should I do?
Fault to its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Dec 01, 2015 | Televison & Video
Technika tv
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
Apr 22, 2014 | Televison & Video
Technika lcd 32
Probable power supply failure.
Jan 13, 2014 | Televison & Video
Technika flat screen: Will not switch on, the blue standby light just flashes
Technika flat 32 screen: Doesn't not switch on, the blue standby light just flashes.
Apr 14, 2010 | Televison & Video
Hi pls my tv screen is smashed and broken and i want to replace just the screen if you do sell them
FixYa is an online information resource only, it does not supply any spare parts.
But if you have a broken tv screen (you've listed your question in a section for Linhof Technika photographic cameras) then you have broken the single most expensive component in the tv. It's always cheaper to buy another complete tv, especially if you buy a used one.
Feb 16, 2010 | Linhof 4x5 Master Technika 2000 Body -...
I have a Technika 32'' TV/DVD
my tv remote wont work i bought a new one but it requires you to enter a code and i dont have it. the tv is a technika 32-601 the codes 1484,0193,0363 dont work anyone know the right code
Nov 16, 2009 | Televison & Video
Screen on lcd tv is broken on the inside - how much would it cost to repair Technika lcd42-207
you will have call Technika Customer Support. In most cases it is about the same as a new TV. Sad but true.
Sep 07, 2009 | Televison & Video
Technika SC500172 tv/dvd won't come out of standby.
my lcd screen is broken , i need a lcd screen for model no. SC 500172 , can i get it in india, singapore or dubai or anyother place and what is the cost.
Sep 01, 2009 | Televison & Video
Televison & Video Logo
77 people viewed this question
Top Televison & Video Experts
Electro Med Services...
