I cannot duplicate my displays without the resolution being messed up on one of them. I have a Dell lcd monitor: ST2410 24" and a TV, Toshiba Regza 46" When I duplicate the displays the Dell Monitor's resolution is always crushed. When I have both plugged in and display only on the monitor, my monitor is always #2 I don't know if this affects anything but that's all the information I can think of including, and the resolution is 1920x1080
  • thejzone May 03, 2010
    While trying your solution, I came upon ATI Catalyst and tried it from there.
    It worked!
    Thank you very much!
    Guru:
  • 1,049 Answers
Depending on your OS, this is dealt with differently.
On Windows
  1. Go into the display properties.
  2. Go under settings.
  3. Highlight your primary monitor and check "Use as primary"
  4. Highlight your secondary monitor and check "Extend my desktop"
  5. Set the resolution on each display
If it won't let you change display resolution independently, you will need to update the video driver. Also remember that even if it works, going between displays of two different resolutions and aspect ratios causes problems with many games and programs including many Adobe products.
Let me know if you need instructions for the Mac or Linux as it varies depending on what flavor Linux or version Mac you use.
Posted on May 03, 2010
Need to replace screen
You can connect a second LCD screen to your laptop.
The video cable from the monitor connects to the Blue connector on the laptop.
now go to Control Panel\All Control Panel Items\Display\Screen Resolution
Select duplicate display settings.
It should display what is on your laptop screen to the monitor
Dec 28, 2011 | Dell Studio XPS 1640 Laptop
Can't get to full screen. I need to be at 1080i
The 'ASPECT', 'PICTURE MODE', 'ZOOM' button on the remote will let you adjust the aspect ratio of the display.
The 1080i/p, 720i/P resolution is not done at the TV, its the video source that determine what resolution the TV will display, same way as your PC monitor works, it is control by the PC Video resolution setting.
Basic LCD monitor and LCD TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV, Monitors, Caps : http://s807.photobucket.com/home/budm/allalbums
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Nov 05, 2010 | Toshiba 32AV500U 32 in. LCD HDTV
While at home I plug a wide screen monitor into my Dell studio 1737 Laptop. As long as I keep my lid open the icons and print on my monitor are the right size. When I close the lid, icons and prints get...
You appear to be cloning your internal LCD and as long as it is active, the resolution setting for the LCD is also controlling the resolution of the external monitor. When the LCD is closed, then the default resolution of the external monitor is being used by Windows 7 (It apparently has autodetected the size of the monitor and knows the Highest optimal resolution it will display.) The higher the resolution, then smaller the icons.
To resolve, go to display properties and check the resolution of the internal LCD and then set the External display to the lower resolution.
You should be able to wake the system with an external keyboard, by pressing the spacebar, if the system is sleeping
Jul 24, 2010 | Dell Studio 1737 Laptop
How can fix the Dell 1708 screen's resolution?
Just go into your control panel and then into the display settings. Change the resolution to 1024 by 768.
Apr 19, 2010 | Dell UltraSharp 1708FP 17" LCD Flat Panel...
Dell E153FPf TFT LCD Panel problem cannot display
The max resolution for this monior is 1024 x 768 @60Hz. You will get the error message if the video resolution is too high to display.
Apr 09, 2010 | Dell E153FPf 15" TFT LCD Flat Panel...
Want to use samsung 2233SW LCD monitor as TV
Yes you can, if you has PC desktop, plug your lcd to it. change LCD resolution from your PC.
-- Right Click on desktop
-- Click properties >> click settings tab
-- You will see Screen Resolution, change to the lowest (800x600)
-- Nnplug VGA cable from PC
-- Now plug the cable tou your TV Tuner.
Feb 08, 2010 | Samsung SyncMaster 2233SW Monitor
Connecting Compaq Presario CQ40 to LCD tv Toshiba REGZA '32'
Check your resolution output from laptop it maybe set to high for the TV to handle, also go to the Display Properties and ensure that the second monitor out is enable. Good luck!!
May 28, 2009 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
Can't view connected Dell Inspiron 9400 computer on Toshiba 37 AV52U TV
You need to change your computer display settings following your TV user manual.
Here follow the compatible display settings as on page 57-chapter 9 on manual.
Put resolution 640x480 and frequency 59,940Htz.
Here the user manual where you can find the same information on chapter 9.
See How to change display settings: screen resolution, screen
refresh
Do not forget to evaluate the solution.
Many thanks.
Mar 08, 2009 | Computers & Internet
How can I make fonts look good in an LCD monitor ?
The VGA connection should be fine; I have DVI and when I switched from analog, the difference was pretty minimal, to my eyes.
Is it just the fonts that are blurry, or everything? If fonts only, then this almost certainly suggests that running the ClearType tuner again would solve the problem. But this applies to all displays, so if one is good and the other is not, then this isn't it.
If everything is a little blurry, then this suggests one of two problems -- the first, you report trying, which is that the display adapter is set to a different resolution than the native resolution of the LCD monitor itself. Your display adapter should probably be able to drive 2 monitors (the built-in laptop monitor and the external monitor) at once. You should be able to set their resolutions separately.
Assuming Windows XP: Start > Control Panel > Display > Settings > at which point, you should see two monitors listed in a dropdown. Set them to their native resolutions there (using the slider bar, usually all the way to the right), and save.
If you do have the display resolutions set to their native resolutions for both monitors, then it's possible that your external monitor is messed up. A quick test would be to run the on-screen settings, usually from a button on the monitor itself. If what is displayed there is sharp and what is displayed from Windows is not, then this points to a problem with the display driver. If everything, even the on-screen display is blurry, then perhaps the monitor settings are messed up -- usually there's an option to restore to factory settings -- try that.
If that doesn't work, I'm probably out of ideas, unless you have further information.
Mar 08, 2009 | LG Flatron L1750S 17" LCD Monitor
Computers & Internet Logo
41 people viewed this question
David Payne
David Payne
