Magnavox TR2512 vertical/horizontal hold problems
I have a Magnavox TR2512. It does not hold Horizontal. I tried to use the adjustments in the back, but they just seem to change colors. Now that I fooled with them, Vertical seems to flip.
This TV is on a screened porch an is exposed to moisture (fog, dew, etc.) as well as cold. It does "crackle" a bit when switched on, so I don't know if that may have affected it.
I had a Sony out there for 10 years until the volume slide went and put this one out there. I have the cover off, but don't see any obvious burned components.
Is this TV worth trying to fix?
Thanks,
Steve
  • Wubs Mar 28, 2008
    Thanks. So would a HVT issue still allow the TV to turn on, look OK for some of the time and then not horizontal hold . The hold problem seems to happen when scenes change on the show, for example the newscaster will be talksing and the picture is fine, then it switches to a shot of traffic and it messes up, then goes back to OK again.
    Scholar:
  • 110 Answers
Subjecting a TV (or other electronic devices for that matter) to moisture etc is not good for them.
From your description, it sounds like the high voltage transformer (HVT) is arcing. This can potentially destroy the circuit boards, or even cause the set to catch fire.
Fiddling with unrelated controls will just create more problems, but not solve the original one.
As TV's can store potentially lethal voltages (around 25 thousand volts!) long after power is disconnected, if you are not experienced in repairing them, you would be well advised to take it to someone who is.
Magnavox are known for the HVT problem and personally, I wouldn't waste money repairing one.
Hope this helps.
Posted on Mar 26, 2008
SOURCE:
I have 2 lg repair the same trouble vertical horizontal rolling
Vertical or frame rolling indicates adjustment of the frame hold is required or perhaps there is a synchronisation fault.
Breaking of the picture in the horizontal plane is caused by the line hold requiring adjustment though the symptom can be connected with interior or exterior signal problems or perhaps a power supply fault, especially where both the line and frame are affected together.
It is probably a task for an engineer or at least someone with access to the servicing instructions.
Feb 25, 2015 | LG Televison & Video
My RCA tv picture is jumping
Vertical jumping may have a vertical hold issue, horizontal may have a horizontal hold issue. Most older tv sets will have some knobs or adjustable screws for vertical and horizontal hold. Turn your set on and check for these knobs on the back of your set and adjust until your picture is in as well as you can get it
Aug 21, 2014 | Televison & Video
Vertical size too large. Cannot adjust enough in menu
Try adjusting the horizontal out first. You may have to do this a little at a time back and forth between the vertical and horizontal.
Oct 21, 2013 | Pioneer PDP-505CMX 50 in. Plasma...
Locating the horazonal hold control button on a magnavox 19inch tv modle number 19pr14c225
old models had small Pot for adjustment the horizontal+vertical etc
Newer model doesnot.By that reason you will NOT find it.
I am sorry.
if you have some problem you must go to the repair shop TV.
God bless you
Jul 31, 2012 | Televison & Video
Horizontal hold troubleshooting. Can hear but pic is like a line on the screen. Tried adjustments on back
If the line is half way up the picture. This is a vertical problem. Most likely the vertical output IC or a bad solder joint near the IC.
Jan 26, 2011 | RCA 27F501TDV 27 in. TV/VCR/DVD Combo
PICTURE FLIPPING HORIZONTAL - OLDER TVS HAD A HORIZONTAL OR VERTICAL HOLD BUTTON - WHAT HAPPENED TO THOSE BUTTONS?!?
U talking about way back in the 40 and 50.From the 60 on tv all use intergrated circuit board.Mostly ICS chips now,no more tubes and analog parts.The problems ur tv have is the Horizontal IC chip is dead.
Sep 09, 2010 | Philips Magnavox 27MS343S 27" TV
My tv will turn on but with white light line then shut off itself
If the line is horizontal (it is a vertical problem) If its a Vertical line (it a horizontal problem) So it could be just a bad solder joint or a component has failed in the horizontal or vertical section. Hope this is helpful.
Nov 28, 2009 | Philips Magnavox 27MS343S 27" TV
Horizontal lines
may be vertical deflection circuit bad capacitors and is a job for experienced tech
Apr 01, 2008 | Philips Magnavox MS2530C 25" TV
RCA D52W20B Vert/ Hor Hold Problem
Nothing inside to adjust. try re-soldering the vertical output IC and also the flyback connections RCA has had some issues with the flyback solder connections
Feb 23, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Picture has a horizontal row
this symptom is caused by a trouble in the integrated circuit of in the vertical oscillator circuit. try to look if your tv has a vertical hold control at the back or inside, if it does not have, u have a problem in the vertical oscillator circuit. by the way, its not the horizontal that u should concentrate into, its the vertical. coz this is a vertical sync problem.
Jan 12, 2007 | Konka K2001UM TV
Televison & Video Logo
330 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
