Question about Uniden 2.4 GHz Expandable Phone System with Digital Answering Machine
Intermittant connection and static in reciever
I have replaced the cord with different cords from the reciever to the instument. No change. Other phone work well with different cords so it seems like it is in the reciever.
  • 1 more comment
  • tvc75 May 03, 2010
    first solution was to replace the battery. The reciever is not bbattery energised it is on the desk instrument with transformer power.
    It does't work well with the original cord which was ok for several months. I used different cords to isolate the problem to the reciever. Need new solution
  • tvc75 May 05, 2010
    good suggestion to verify the problem in the rcvr. where can i get a rcvr or get it repaired?
    President:
  • 3,278 Answers
Hello.
Try the speakerphone. If no static, the problem is in the handset, since you replaced the handset cord. Replace the handset.
If static with the speakerphone, either the line cord (from the phone to the jack) or the phone base itself is faulty.
Hope this helps.
Posted on May 03, 2010
  • NinaE May 05, 2010
    Hello.
    I'm unclear as to what you are requesting.
    If you truly narrowed down the problem to the receiver / handset, then the receiver / handset needs replacement ... You requested another solution ... what are you looking for ???
    Genius:
  • 1,417 Answers
what this means is that the receiver is not compatible with those cord which you have been fixing in to it
what you need to do is that those cord need to be same with the very first cord which came with your phone 'note' but if you are using the phone for the first time then you have to take your phone down to a shop to get your phone a cord that will be compatible with the receiver
if you can do this the problem of the receiver will be solve
Good luck and thank for using fixya.
  • Oloyede Monsuru May 04, 2010
    hello,
    if the wire which came together with the phone have to working for few days
    then you have to change it has have said before
    take your phone down to a shop store to get your phone a cord that will be
    also the receiver need to look in to if the cell sensor in getting signer from the server
    thank you once again .
    Guru:
  • 1,049 Answers
It may be the receiver, in which case you have to replace the unit. But before you do, make sure the battery is good. It isn't too expensive to replace one and that was exactly what caused this problem on all of mine after several months of use.
New battery is cheaper than new unit...worth trying.
Mitel Superset 420 corded phone has static
Static on the handset of a MITEL phone is indicative of either a defective handset cord **OR** the user has one of those cord detangler devices attached to the cord. If it's a cord detangler, remove it, smash it with a hammer and throw it away. Advise the end-user to please not use these as they all become staticky after several weeks use. If the user has problems with their handset cord constantly becoming tangled, THAT PROBLEM is indicative of neck or ear fatigue from frequent LONG CALLS and the user keeps moving the handset from one ear to another (changing hands). THE FIX FOR THIS is to give the user either a corded or cordless headset (or check SMDR records for excessive personal calls)
Feb 12, 2014 | Mitel Superset 420 Corded Phone
Microphone makes a static sound when it gets moved. The static comes through the speakers when the microphone is held in different positions. Could it be the cord or the connection to the mic?
Make sure your connections are clean and tight. There may also be an intermittant or broken wire in the cord. See if you can narrow the problem down by holding some parts of the wire stationary and moving other areas. gently shake the mike with the set off and listen closely for loose parts making noise. (The idea is to eliminate the areas that are good and what's left is broken.) Hope this helps
Dec 29, 2010 | Magic Star Karaoke Microphone
Every time I go to a new page it causes static on the picture for a second then disappears. When I stay on one page it is fine...whenever I change web pages, it flickers for a second or two again. ...
Sounds like a video connection problem. It is either your video connection on your PC or the monitor. You can try connecting it to a different video connector on your PC; there are normally a VGA and one other connector. If that doesn't work, it could be your monitor. Try taking it to a computer store and having the techs plug it into floor models.
Oct 15, 2010 | Westinghouse 22" Widescreen LCD Flat Panel...
This headset is brand new, and there is a terrible static noise. what would cause this?
Static can be from a nearby radio transmitter such as local commercial station, ham radio, CB radio, cordless phone or wifi radio, etc., but many times is from a dirty (or oxidized) electrical connection. Locate any volume adjustment knob and rotate it fully clockwise and counter-clockwise several times and check for static again. Remove and reconnect all plugs and jacks several times in an attempt to dislodge any dirt and debris from contact points. If there is still a problem, try connecting the device to a completely different telephone to see if the problem is with the device or the phone.
Try using the old coiled cord set between the telephone and HANDset to plug into the HEADset (instead of the new one supplied with the HEADset) to see if it is a cord related problem. What you need to do is replace as much of the affected hardware as you can to help isolate the source of the static and then contact the manufacturer of the defective part for replacement or other suitable arrangement.
Please rate this reply if you found it helpful. Good luck!
Jul 01, 2010 | Plantronics Amplifier
The cord has a sort. how do I find a replacement
When you say short, it means to most people that you have intermittant connection in the cord, and one would say, replace it with the same or better type cord. If you are good at soldering, wire splicing and crimping, it should be fairly easy to separate the base using Security Torx Bits (i.e. tamper resistant screws are used), and a bit of judicious patience. Once appart, if they use crimped or solder connections you can cut, splice and crimp as needed. Your cord will be a bit shorter and you will have to reindex the strain relief service loop, but it should be painless. If you are not confident working with UL listed safe equipment (your loved ones will be using this appliance) you can get it serviced here:
California Electric Service in Concord CA (it is the only Rowenta repair station in California) go to either of the following addresses:
their website is: http://www.californiaelectricservice.com/
or tech service: service@californiaelectricservice.com
Jun 06, 2010 | Rowenta Professional Luxe DM880 Iron
Intermittant power when using the power cord.
yup probably the power cord. try replacing a new one if you have or try borrow from your friend just to test if the problem is really in the power cord
Dec 07, 2009 | Compaq Presario R3000 Notebook
My Marshall 8040 has a sort of static sound. It started a week ago and I noticed that if I press the power cord hard into the amp, the static sound disappears. However, once I let go, the static returns....
It sounds as if you need to replace the power cord or the power socket on your amplifier.
If you can get into the cord check to see if the connections are tight do the same on the socket.
I guess you have a faulty connection.
Regards
Alan Hood
ami-man
UK
Jun 16, 2009 | Music
Static
When I have a static problem with a phone or radio it usually happens when I have them plugged into a extension cord. Or they are too close to one another. You may try an ext.cord. just having the phone plugged in or find out why you have so many magnetic fields in your house and if moving the phone around to different outlets help.If not I suggest you call Radio Shack. You can not beat their customer service.
Jan 24, 2008 | GE 25952 Cordless Phone
Uniden 2.4 GHz Expandable Phone System with Digital Answering Machine Logo
67 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
