Question about Whirlpool RBS275PD Electric Single Oven
Error Message After I cleaned my oven, the next use.....I set the oven to bake @ 375 and it locked and burned what I had in the oven. It gave an error code F3. Does anyone know what this is and why it is locking?
    President:
  • 1,430 Answers
The problem is the oven temperature sensor has failed. This is located inside the oven near the top back. It is long thin tube like.Remove the 2 screws and remove the sensor. Check with an ohmeter you should have approx 1100 ohms within 10% if not replace. This is easy to replace. Enter your model 3 for diagrams and illustrations at www.appliancehelponline.com All parts come with installation instructions.
Posted on May 03, 2010
Door latch stuck
This error means your temperature sensor (probe) has failed and needs to be replaced.
Nov 05, 2014 | Whirlpool GMC305PD Electric Single Oven
Tip
Whirlpool oven, stove and range fault codes (ERC and EOC display errors).
Here a list of Whirpool oven fault codes. The codes had been collected from different service manuals. This was a memo that I wrote for my own use. I think this can be useful to owners and technicians.
WHIRLPOOL - most models
Range/Stove and Oven Fault Codes, Common error codes.
F1 - Analog control board Failure
Disconnect for one minute - if error comes back, replace control board
F1 - Shorted control keypad
Replace keypad
F3 - Oven temperature sensor open
Replace oven temperature probe
F2 - Oven temperature sensor shorted
F3 - Oven too hot
F3 - Clean temperature too hot
Replace oven probe
F5 - Door latch switch fault
Test and replace the door switch.
Whirlpool with 4 Digit Failure Code:
F1 - E1 - Electronic control (flip flop)
Replace control board
F2 - E0 - Shorted control keypad
Replace keypad
F3 - E0 - Oven temperature probe open
Replace temperature probe
F3 - E1 - Oven temperature probe shorted
F3 - E2 - Oven temp too high
F3 - E3 - Clean temp too hot
Replace temp. probe
F5 - E0 - Check door latch
F5 - E1 - Check door latch
Replace switch if defective
WHIRLPOOL Polara models 5 digit codes:
F1 F0 - EEPROM communication error
Replace ERC
F1 E1 - EEPROM checksum error
Replace ERC
F1 E2:7 - UL A/D errors
Replace ERC
F1 E4:2 - Model ID error
Reinsert keytail.
F1 E6:0 - Latch signal mismatch error
Replace ERC
F2 E0:4 - Shorted key error
Replace keypad assembly
F2 E1:3 Keytail unplugged
reinsert the keytail
F3 E0:5 Top oven sensor open
Test and replace top probe.
F3 E1:6 Top oven shorted
Test and replace temp probe
F3 E2:9 Bake range over temperature
F3 E3:8 Clean range over temperature
Test and replace temp probe.
F3 E4:10 Bottom oven sensor open
F3 E:15 Bottom oven sensor shorted
F5 E0:14 Door switch errot
Test and eventually replace door lock switch
F5 E1:16 Door latch not operating
Test and eventually replace door latch
F8 E0:17 Refrigeration error
Test the cooling module.
PF Power failure - Does not indicate a fault.
PF occurs when power is disconnected.
WHIRLPOOL
Models SF3, 30'' and 24"
F2 - Oven temperature above specifications
Check 8-pin connector from temp. probe to Electronic Oven Control
F3 - Open oven temperature probe failure
Check wiring, replace oven probe if necessary
F4 - Shorted oven temperature sensor failure
Check wiring harness, replace oven temperature probe if necessary
F5 - Push button stuck or faulty
Check for binding of pushbuttons and control panel glass. If OK, replace touch panel
F6 - Electronic control logic error (timing)
Replace Electronic Range Control (ERC)
F7 - Electronic control logic error (lock motor)
Replace ERC.
F8 - Electronic control logic error
Replace ERC.
on Jan 31, 2010 | Whirlpool RBS305PDS Electric Single Oven
Oven burning food
Don't worry my wife does the same thing. Not sure if your talking about the range top or the baking potion. We'll assume the baking area. If your using cheap bakeware that could be part of the problem try using a different cake or loaf pan of heavy construction. Also you may try reducing your temp in 25 degree increments to see if your oven runs hot. Example buy 3 cheap frozen pizzas and if they say value at 400 try 375 , 350, and 325. If one of those temps gives the desired result assist accordingly and consider contracting Bosch customer service to inquire about how to fix thermostat errors.hope that helps I didn't have much to work with.
Mar 24, 2014 | Bosch Ovens
Half way thru the cleaning cycle I got an error code 30
Does the bake and broil elements both glow bright orange? It's possible the temperature is not getting hot enough to satisfy cleaning mode. Also check the door lock to see if it is staying locked. Pull on the door when the error occurs, be sure to keep your face away because it can singe your hair and burn you. The temps in the oven reach 600 degrees or more and the control board or keypad may be overheating and causing this error.
Oct 28, 2013 | Frigidaire 30" Self-Cleaning Freestanding...
Electric range/oven switched from bake to self-clean without my help!
Good Afternoon Mr Oliver!
Often, if Whirlpool oven starts to do things on its own.. the touchpad might be failing or faulty. Keys fail and short, meaning they think they're being pressed when they actually aren't. Do you have the model number of you oven?
May 17, 2017 | Whirlpool 30" Self-Cleaning Freestanding...
Samsung oven error codes
you need the service rep or repairman
Jan 12, 2012 | Ovens
Whirlpool model RBS245PDB16. Oven pre heats ok. put chicken in to bake. works for a while, and then display reads F3, locks door, and burns up chicken.
Hello & Welcome to FixYa
F3 error code indicates a open/shorted oven temperature sensor and to solve this problem the sensor needs replacement. If you wan to be sure before replacing the sensor then you can test it with a voltmeter for around 1100ohms....if it reads more then this then it needs replacement however, if the reading is around or less then 1100ohms then it is the control board that needs replacement. Please get back to me if you have any other questions.
Kevin
May 10, 2011 | Whirlpool Ovens
We are using self clean feature. continuous beep about 20 minutes into cleaning screen shows F# locked door and beeps nonstop. what can we do to stop beeping but still proced with self cleaning?
F3 is a bad oven temp sensor. The sensor fail F3 code will appear if during self clean that it senses temps above 915F, or there is an open / short in the temp sensor. The only thing you can do is replace the sensor. Just getting the oven door open can be a real pain as you have unlatch the oven door lock to get to the screws that are in the top lip above the oven door so that you can change the sensor. Depending on model you may have to reach through a burner to manually unlatch the oven door lock or remove the side panel of the oven to manually unlatch the door lock. On most units It will not continue to self clean with an F3 code detected. Once an F3 code is detected the ERC shuts off power to the bake and broil elements so that it does not catch fire from a run away temperature condition.
Thanks for choosing FixYa,
Kelly
Nov 25, 2010 | Ovens
I have a F & P wall double oven model OD302, first used 2 weeks ago, and the temperature, although set at 375 degrees, rises to only 122. All settings were used, ie. aero bake, bake, etc. The right...
The name F&P says it all! If there was any brand that gave the most problems, in products then F&P is the first on the list. With LG as the second
You say this is possibly a new installation of only 2 weeks. Don't dither around seeing if its a simple fix, get the installers/sellers back to fix it . It will probably need replacing as the control is faulty.
Thanks for using FIXYA
Dec 03, 2009 | Fisher and Paykel Ovens
Whirlpool RBS275PD Electric Single Oven Logo
78 people viewed this question
Top Whirlpool Ovens Experts
Sal De
Oloyede Monsuru
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
