Question about JVC LT-32E479 LCD TV
I have a lt-32a61 jvc tv, dvi flashes on anf off
I have a lt-32a61 jvc tv, i have just got sky hd and have connected this using a hdmi-dvi converter and the hd cable which came with sky, problem is on the dvi output the picture flashes on and off every split second. can you help?
4 Suggested Answers
Benimur
  • 6966 Answers
SOURCE: ilo 27 inch hdmi/dvi hd tv monitor
Hi, I'm afraid that not only a cable is needed but an analog (vga) to digital (dvi) converter/scaler as well. The iLo LCD Display V27DMBX-U12 can hook up to a PC using the DVI-I connection only. As you said, your computer has the standard 1D15 pin VGA connector. Another possibility is if your video card has a composite video output (normally a color yellow RCA female) or an S-Video output which will both connect direct to your iLo LCD Display V27DMBX-U12. For the RCA connection all you need is an ordinary RCA to RCA shielded wire cable and for the S-Video, an S to S Video cable will work. There is of course the question about the quality or the resolution. Good luck and hope that this be of some help to you. Pls post again how things turn up. Kind regards.
Posted on Jul 31, 2007
markevans
  • 148 Answers
SOURCE: LG 42LC2D-EC NO SOUND ON HDMI
your setting for source of the audio is probably defaulted back to original setting in receiver. reassign audio input and problem may go away. it sounds like its not in the tv. i assume you have a receiver and are not trying to listen with speakers in tv. is this correct? if you are not using an amplifier, you may need to go to the tv menu to make sure the audio source is selected as the hdmi input. should take a bit to read thru the manual, but it ought to show you how to accomplish the correct settings.
let me know if it does not.
good luck
mark
Posted on Dec 23, 2007
  • 127 Answers
SOURCE: 32" JVC LED TV will not play SKY+HD through HDMI
You need to select HDMI input.
Posted on Nov 01, 2012
I have a 2002 Mitsubishi Medallion TV. The only input for HD is DTV (no DVI or HDMI inputs). Is there a converter box from HDMI to DTV that will allow for 1080i resolution?
From looking at the back panel of the TV, the DTV input can be configured as a component video. The M-Link/DVI-HD port is also a DVI with HDCP port and maximum signal handled is 1080i. The M-Link should work with an HDMI to DVI cable or adapter. For this to work, the source must not be a computer or another device using the default computer video output (computers give RGB output). The DTV port would need an HDMI to Component video converter. See this page for some examples: http://www.hdtvsupply.com/hdtocoad.html . The first one in the list (for Netflix and Boxee among others) will give 1080i out if the source is set correctly.
Most DVI-HDMI cables are single link. I've seen some examples where DVI-I (single link) and DVI-D (dual link) cables are not interchangeable. If you have video problems, check your cable. An HDMI to DVI adapters will let you run an HDMI cable up to the TV and then converter at the TV as a separate connection.
I hope this helps.
Nov 17, 2010 | Mitsubishi WS-65613 65" Rear Projection...
How do i get sky hd to work on this tv? i have
maybe the Hyundai service center can give you the best solution to your problem.just ask them.
Jun 19, 2010 | Hyundai ImageQuest HP4240 42 in. Plasma...
Connecting to HD TV
This TV has no HDMI input socket. It Has a DVI input socket. Therefore you will require an HDMI to DVI converter adapter or an HDMI to DVI cable. The DVI is video only so you will require audio cables from your Sky box (Audio L and R ) which will connect to the back left of your TV (Audio L/R sockets next to the s-video and component video connectors)
Nov 02, 2009 | LG RZ32LZ55 32 in. HD-Ready LCD Television
I am about to receive an LG32LF4700 Freesat/HD TV If I disconnect the SKY Box and connect the TV direct to the Dish cable will I receive Freesat HD channels. Also can I connect an extra bedroom TV into the...
Yes you can split the signal out from the back of the Freesat/HD (not the TV)to the second TV.
Look what outputs are on the Freesat box - the RF (standard cable) output should go to the 2nd TV (TV set to CH3) and the a/v cables,HDMI or DVI cable should go to the new TV - Note:To receive HD the output from the Freesat should be either HDMI,DVI or Composite output (RGB video jacks) with red White for audio. If you have HDMI this is best - it also provides audio.
Oct 28, 2009 | LG 42LC2D 42 in. LCD HDTV
Is it hd
Strictly speaking to be HD Ready a TV must fullfill 2 things:
1. Have a Screen Resolution of at least 1024 x 768.
2. Have at least 1 HDMI Socket.
Your TV has neither of these, so it is NOT HD Ready, however, it will still be more than capable of showing SKY HD, and it will still look very nice indeed.
I would need a list of the connections on the rear of the TV to tell you which cable to buy, but:
If it has DVI, then a simple HDMI to DVI cable will do for the video.
If it has component, i.e Yb, Yr etc then you will need a more expensive HDMI - Component Video cable.
But otherwise, yes, SKY HD will work fine.
I hope this helps.
Mar 28, 2009 | Televison & Video
JVC LCD TV (LT-42X688) input panel not working!
1. This TV has setting for the HDMI input that allows you to select the HDMI Audio or Analog(red/white wire) audio. Make sure this is correct
2. Most cable boxes are DVI not HDMI. If DVI then you actually do need to use those Red/white cables. If HDMI, refer back to #1.
3. The cable box has a setting to select the Audio output, HDMI (digital) or Analog(red/white cables). Just like #1, this has to be set.
4. Contact your cable company to help you set up the box correctly. JVC can probably help you check the TV
Mar 05, 2009 | JVC LT-42X688 42 in. LCD HDTV
Trying to hook up my PS3 to my Viewsonic N3000W to enable me to watch HD BluRay Discs. There is no HDMI socket at the rear of the telly. Disc plays but HD picture quality looks the same as ordinary DVD....
Your TV has a DVI input connector, but no HDMI as you noted. Adapters (fondly called "dongles") are available to convert from the DVI connector to an HDMI jack so you can connect your HDMI source. Search for "dvi to hdmi adapter" with your favorite search engine and you will find them.
As for settings, this set has 720p resolution. Make sure your source is set accordingly, and you should be set to get the best quality you can with the connections available.
Please take a moment to give this solution a fixya rating if you've found it what you needed, and thanks for asking here!
Mar 05, 2009 | ViewSonic N3000W 30 in. HD-Ready LCD...
JVC LT-Z37SX5 no sound when using hdmi connection to HD box
the tv has a configaration that conveys the sets focus on both audio and video performance. full hd resolution of 1920-1080 pixels.
hdmi inputs allow connection of the generation of 1080p sources for the systems which offer 1080p outputs
Jan 12, 2009 | JVC AV-36D303 36" TV
JVC LT-32DS75SJ issue with HDMI
Try this
1. Turn ON TV
2. Connect PS3 to TV HDMI input
3. select TV HDMI input for PS3
4. turn OFF PS3 if it is ON
5. Press and hold the [I/O]Power button until the PS3 until you get the "HDMI Detected" message.
Also, this TV has a circuit that deactivates the HDMI if the rear cover is removed. It is possible the HDMI may have been turned OFF. This is reset in the service menu of the TV.
Dec 17, 2008 | JVC LT-32X575 32 in. HD-Ready LCD...
JVC LT-32E479 LCD TV Logo
147 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
