How do i switch monitor output so i can use my tv as the monitor
  • Dave MacPhee
    Dave MacPhee May 11, 2010
    Do you have a card that will connect to the TV (ie, S-Video, RGA outs?)
    Sergeant:
    Champion:
  • 329 Answers
Check your computer if you have a video card with television output.. if does not.. try to buy a new video card..
Posted on Mar 26, 2008
SOURCE:
Conecting to tv
For sure there must be some tv output on your computer..... for example hdmi out..... then you need to use hdmi cable and on tv switch to correct AV input.....
another way is to connect via monitor output, but works only with LCD TVs with monitor input.....
if you would tell me what model of computer you have, than you can get better answer
Mar 24, 2014 | Packard Bell Computers & Internet
Is there any way to make the PNY nVidia GT 440 POST to the DVI instead of the HDMI output?
Try switching from Monitor 1 to Monitor 2. Or, vise versa. Just switch. in display settings.
Oct 09, 2012 | PNY nVidia GeForce GT440 1GB DDR5...
I would like to connect my PC to TV Grundig GU32DVD to wacth a movie from internet on a tv screen What should i do
Once you're TV is connected to the PC. Go to the display settings and check if the computer detects multiple monitors. Identify the monitors and set your TV as the main monitor. If this a laptop there is also a switch that will let you toggle from the PC display to the TV.
Check the TV output some TV's needs the channel to be set to the output where the PC is connected.
Some says PC some may say VGA or RGB. (depends on the brand of your TV)
Once that is the output channel is set and the cable is connected then you should be able to use your TV as the monitor and watch that movie.
Hope this helps!
Jun 07, 2011 | Toshiba Satellite Pro L300 Notebook
I just bought a Denon AVR 1611. All inputs are HDMI (Cable TV, Blu-Ray) and the monitor output to the TV is HDMI. ainly I listen to the audio out of my TV and occassional on my surround sound. I would...
avatar7.jpgcurt, I bought this Denon AVR 1611 and I have HD cable. If you have cable you can set it up two ways. First way (the way I have it) is to get a switch box with 2 HDMI
out (mine has 4 inputs and 2 outputs) and maybe 2-4 inputs. Put the cable from the wall in one of the switch box inputs. Now hears the cool thing. Put 1 of the outputs from the switch box to the Sat/Cable input on the 1611 then put the another output to your tvs HDMI input. This allows you to switch from the tv only output or the 1611 surround output without touching the switch box. The other way is to buy a converter from HDMI to VGA. The only thing here is that you would have to setup your sound through Aux in the front of the [email protected]
Mar 06, 2011 | Audio Players & Recorders
HOW DO I CONNECT TO TV WITH HDMI CABLE. NO PICTURE OR SOUND ON TV
You will need to check you video/graphics settings on the notebook to see if it is recognizing another monitor, i.e., the television. If so, switch the video output to the television, either as a second monitor or as a mirror. I usually prefer to mirror my video output.
Jan 03, 2010 | Compaq Presario Notebook
Connecting laptop to hd tv
IMake sure that you have the laptop for an VGA OUTPUT. When you toggle between the function keys. When your laptop LCD goes out it is in VGA OUT mode....when you toggle again it should be in LCD/VGA OUT (both TV and laptop should display). You need to set the TV to VGA mode as well...otherwise you might not get an output. If you still have a problem then test on a regular monitor to see if you are getting an output to the monitor
IF THIS HELPS PLEASE VOTE.....GOOD LUCK AND THANKS..
Nov 12, 2009 | Acer Aspire 1640Z Notebook
Does the acer 5315 have a separate video card for running the monitor?
Find the "serial-number" of your ACER notebook.
Access the manufacturer's web-site:
http://secure3.tx.acer.com/FindSystem/FindSystem.aspx?title=Information%20About%20Your%20System
and enter the serial-number, to find the complete specifications for your specific unit.
Nov 05, 2009 | Acer Aspire 5315 Notebook
S-video output not working
I think your problem is because the monitor is not activated. Right click desktop, click properties, click settings. Drag the gray scaled monitor on top of the black monitor and click ok and it should send the signal to the external monitor. try draging the mouse over to it because by default the external screen will be black.
Hope this helps!
May 02, 2009 | Acer Aspire 1690 Notebook
How to hook up rca 32in flatscreen to puter
The hookup is not hard just use the output from your PC VGA , Composite etc to the TV and make sure the right input is selected ont the TV . The tricky part is making sure your PC or laptop is 1 set to display to TV (goto your video settings on desktop) and 2 if you have a laptop most have a function button on top that switches from monitor to external monitor or to split to both.
May 26, 2008 | RCA Televison & Video
No component video output
Hope this helps
The Yamaha HTR-6030 offers two types of video monitor output: Component and Composite. You may need to connect both types to your television as the HTR-6030 does not have composite to component video conversion. In other words, to view your VCR on your TV, you need to use the composite video monitor connection. However, for a DVD player or other source that has component video connections, use the component video monitor output to your TV. If your TV has both types, you simply switch between the two with your TV remote to access the proper video monitor output signal from the HTR-6030.
Jan 23, 2008 | Yamaha HTR-6030 Receiver
Open Questions:
Malwarebytes Support pHoNe $1''855''536'5666 $ nUMber smb' Malwarebytes Support $O{1/855/536/5666}$ pHoNe tMICo resolve all Malwarebytes Antivirus products. Malwarebytes Antivirus is an American multinational company which was founded by Michael Malwarebytes Antivirus using its company headquarters in Round Rock, United States of America.Contact Malwarebytes Antivirus for Setup & Installation Malwarebytes Antivirus Setup Support & Installation Malwarebytes Antivirus Helpline number Connect is a utility carrier that lets in you to print and scan from anywhere. The Wi Fi characteristic in it makes it very on hand and easy to use. So, when you have in the end determined to head for Malwarebytes Antivirus Connect, Malwarebytes Antivirus Helpline Phone Number you'll be searching out Malwarebytes Antivirus Connect setup as well. So, here we're with all cthe setup process and for your to Malwarebytes Antivirus Connect. Get Malwarebytes Antivirus Setup Instant Support Malwarebytes Antivirus Customer Service Phone Number Usually, the setup Customernique takes a number of time. One Customernique if accomplished incorrect, they could break the entire manner and you may should do it again. That's why here you may Malwarebytes Antivirus locate the approaches simplified to help you even if you aren't Customer savvy. Let us undergo the method Of Malwarebytes Antivirus Connect setup for Windows and for Mac Out. So, Outright here we go vikki
Oct 16, 2019 | Carrier Computers & Internet
Arlo tEcH sUpPoRt pHoNe $+1*845*481*1722 nUmBeR USA %%% Netgear Arlo Security Camera Tech support Number EMAIL +[{1\845:-481-1722*}]Wireless Repair service center to resolve all Netgear Arlo Security Camera customer service phone Number products. Netgear Arlo Security Camera is an American multinational company which was founded by Michael Netgear Arlo Security Camera using its company headquarters in Round Rock, United States of America. Contact Netgear Arlo Security Camera for Setup & Installation Netgear Arlo Security Camera Setup Free & Installation Netgear Arlo Security Camera TECH FREE number Connect is a utility carrier that lets in you to print and scan from anywhere. The Wi-Fi characteristic in it makes it very on hand and easy to use. So, when you have in the end determined to head for Netgear Arlo Security Camera Connect, Netgear Arlo Security Camera TECH Free Phone Number you'll be searching out Netgear Arlo Security Camera Connect setup as well. So, here we're with all cthe setup process and for your to Netgear Arlo Security Camera Connect. Get Netgear Arlo Security Camera Setup Instant Free Netgear Arlo Security Camera TECH FREE Phone Number Usually, the setup TECH nique takes a number of time. One TECH nique if accomplished incorrect, they could break the entire manner and you may should do it again. That's why here you may locate the approaches simplified tdako help you even if you aren't TECH-savvy. Let us undergo the method of Netgear Arlo Security Camera Connect setup for Windows and for Mac. So, right here we go vikki TALATUM
Oct 16, 2019 | NetGear Computers & Internet
Computers & Internet Logo
49 people viewed this question
Ekse
Alun Cox
