Question about Tascam X9 DJ Mixer System
Media error 0 shut down displays when unit is
I have a dp 01 this is meessage I get when I turn it on: media error 0 shut down
While the machine is off mode, hold down track edit and shutdown buttons. then power on while holding these buttons. an option to to reset will come up, let go of the buttons and select "yes".
This will reformat your entire hard drive, and you will lose any music you were working on, but it becomes operational again. Or you can send it in to Tascam and let them try to bring it back, if you don't want to lose any material.
Hope this helps :)
-Chenoa Desiree
Posted on Feb 25, 2011
TASCAM DP-01 won`t startup
Press and hold down the "track edit" and the "shut down" buttons while turning the power on until it says "-init screen- please wait". It will ask you if you want to initialize hdd. If so press yes/enter. This Will wipe your hard drive clean. If no just press no/exit. This works on the dp-01fx. It should work on the dp-01 as well.
Dec 02, 2014 | Tascam DP01 All-In-One Recording Package...
Display shows Check Printer E 04 01
an E4-01 is a fuser warm up error...this is usually caused by a bad thermistor but can also be caused by a bad fuser lamp or thermostat
Apr 02, 2014 | Panasonic Workio Dp 8020e
Error 01 carriage jam on avantra 44s what can i do?
MAYBE THE CARRIAGE IS FAULTY.DID U TRY A NEW ONE
Nov 19, 2013 | Panasonic Workio DP-4530 Copier
Where's the fuser unit on a Panasonic DP 3000
Hello sir;Cleaning the fuser unit not thing to do with the error code E4-01, but there is the way to reset just followinf the steps;
1, press and hold down following 3 keys by order "function", "original size", "3".
2, enter 9, press print,enter 04 press print.
3, press following two keys at same time "function", "'clear".
May 16, 2009 | Panasonic Workio DP-3530 Copier
Panasonic Workio DP-1820P
Printer Error E02-01 appears when paper tray number 1 lift-up motor is unable to lift papers, Check whether the gear box of the motor is broken , normally replace the whole unit
Apr 30, 2008 | Panasonic Workio DP-1820E Copier
DP-1820E - Contact Your Dealer - Printer Error E02-01
E02-01 refers to the tray 1 lift motor either you have a bad motor or there's a problem with your main board. good luck
Apr 23, 2008 | Panasonic Workio DP-1820E Copier
Panasonic Workio DP-1820 error code E4-01
error code E4-01 means you have a fuser warm-up temperature problem. try a lbp fuser reset in service mode. i dont know what you password is so i cant tell you how to get there but good luck
Apr 16, 2008 | Panasonic Workio DP-1820E Copier
My power went out when i was formating disk
you need to take out the hdd from the unit and reformat it in a computer. then reinstall in the dp-01 this should take care of the problem.
Jan 21, 2008 | Tascam DP01 All-In-One Recording Package...
Tascam X9 DJ Mixer System Logo
226 people viewed this question
Top Tascam Audio Players & Recorders Experts
Sam Palermo
Sam Palermo
Michial Gueffroy
 Grubhead
Grubhead
Are you a Tascam Audio Player and Recorder Expert? Answer questions, earn points and help others
