Question about Haier 5200 BTU Window Air Conditioner White
Room AC unit condensation drains into room, not outside. There are no obvious drain holes on the underside of the unit. I've drilled to create some, but condensation still comes in. The unit has a definite slope away from house, so that doesn't seem to be the problem. Any suggestions are welcome.
  • 1 more comment
  • ranger_willi May 03, 2010
    Shastalaker7, with the unit upside down I saw no apparent weep holes or any outlet for a drain hole. Last year the condensation built up inside the unit to the point that the circulating fan blade actually picked up the water and blew it inside. When I drilled my own weep holes I found that one of them was on the room side of the drain pan. I've plugged it up and we'll see tonight if the condensation empties out to the weep holes I drilled further away from the house. I'll keep in touch.
    Thanks, Bill
    Working to validate the solution. Will know more tomorrow!!
  • ranger_willi May 04, 2010
    Shastalaker7, I have a Haier 5200 BTU Model HWR05XC6 also called Model AD0A21E0500, Serial Number A65AE1539. The unit ran fine last night with no inside condensation leakage.
    Even after I told my wife that my drilling the weep hole on the room side of the drip pan was the problem, she was happy to know that I solved the problem just by plugging up that incorrectly drilled weep hole!! Now the fan doesn't pick up the condensation water and thrown it back in the room and neither does it drip into the room.
    Thank you!
    President:
  • 1,515 Answers
Hi, if this unit does not have any weep holes as they are called, you should have a small diameter soft plastic drain tube connected from the inside coil where the condensation forms to outside that is plugged. You should have a trough that the condensation collects inside bottom. It may drain left to right or one way only. Dust forms on the indoor coil where the filter collects this dirt and washes down the front to drain which is blocked. Look it over very good from the inside to find what I am speaking of and you will be able to solve this problem. It really is an easy fix for you, so don't call out a tech. Use a good powerful light to look it over until you find how it drains, a hose or weep holes. You can do this, I have confidence you can. Take your time and you can find the drain type on this unit. Keep me posted on the out come.
Sincerely,
Shastalaker7
Posted on May 03, 2010
  • Robert Horton
    Robert Horton May 03, 2010
    Hi Bill, I understand completely what you are saying. I have seen and here this a lot as I am a a/c contractor. I will check into this further as all units should have a drain to deal with the condensation. I have done the drill hole trick myself in the past. If you can give me a model and serial number I will get to the bottom of this for you. If for some reason they did not add them when this unit was manufactured, this would explain it as it may have happened on this unit. Different climates, high humidity which will cause a lot of condensation build very fast have to have a way to drain or the fan blades will pick up the water and sling it into the home. I am sure you are frustrated, but hang in there and I will solve this for you.
    Sincerely, Shastalaker7
  • Robert Horton
    Robert Horton May 05, 2010
    Hi, I am very pleased this worked out for you!! I thank you for the outstanding rating. I look forward to helping you in the future if anything comes up.
    Sincerely,
    Shastalaker7
My ac isnt draining water and creating mold in the house on my furniture & clothing
drill hole in cabinet to let water drain but be careful of wherer u drill. 3/8 bit is big enough
Jul 23, 2014 | Frigidaire FAC125P1A Window Air...
Water on floor from ac unit
Hi John,
First, water from an A/C unit is normal, and is created when warm, moist air is passed over a cold surface (like a glass of cold water sweats sitting in a warm room). This is called condensation.
Solve the issue by making sure the unit is tilted slightly back - towards the outside. This allows the condensation that drips off the cold coil will land on the bottom of the case and roll towards the rear - which is outside.
Once it is tilted back, inspect the underside of the outside portion of the unit. You should find several openings designed to allow the water to drain out and fall to the ground. Over time, these holes can become clogged with dust, dirt, spiders, etc. Simply insert a small screwdriver into the hole(s) - just enough to clear the obstruction.
If the unit is draining water out the back to the outdoors AND also inside, water can not drain fast enough from the A/C. You may not have cleared all the openings outside and / or not have provided enough of an angle to the tilt. Locate and clear the additional openings and make the tilt adjustments as needed.
Make sure the filter is clean! A dirty filter can cause the A/C to eventually ice up - providing only partial cooling. When the unit is shut off, the ice will rapidly melt and may do so faster than the water can drain outside - leaving puddles on your floor again.
I hope this helps!
Mar 21, 2012 | Heating & Cooling
MY AC IS SHOOTING WATER
It's normal for ACs to produce condensation but for a window unit, they need to be installed to allow the liquid condensate to drain outside the room. If it has just started doing this, it's likely that the drain holes are clogged with debris or mold so the water builds up until it can be ejected by the fan.
Aug 31, 2011 | LG Electronic Window Air Conditioner
In this extremely muggy weather, the unit leaks from the right front into the room. We have ensured it is tilted to the outside and is level right to left. We have increased the tilt to a full bubble to...
It appears that the drain is plugged it sounds as if you have it tilted enough . U should be able to remove the front cover from the unit and see the drain behind the evaperator between the inddor fan motor and the evapator. you will see a pan might be plastic under the evaperator . look for the drain . they are sometime difficult to find but it's there. be certain it is open. You might also (if it has a drain hose Blow a bit of air up against it and clear it as well. either way take a bit of of house hold cleaner and drop in the drain pan .. this will help a little to clear the drain . Let me know hope this helps
Jul 20, 2011 | Kenmore 75180 Wall/Window Air Conditioner
My LG Split AC leaks, the water drips from the front right side (inside the room, where it is installed) instead of from the drainage pipe (outside the room). What to do?
Hello, make sure the unit is tilted back somewhat so the Condensate can drain toward the back and not collect up in the front. Also, make sure the drain tube is not obstructed or blocked with sludge.
May 25, 2011 | LG Heating & Cooling
There is no drain hole for water to drip outside.
These are designed to retain some water in the pan. This is for the slinger fan to throw water through the condensing coil. This helps the refrigerant cool and is important to the efficiency of the unit. I would certainly not recommend drilling a hole in the bottom. The hole may cause the water to roll somewhere where damage could occur. Try instead tipping the unit Backwards before bringing it in the house.
Jul 14, 2010 | Frigidaire FAC126P1 wall/window Air...
I have a window unit and water is leaking all on the inside of the room from under the unit?
your drain hole on the ouside of your unit is plugged up, I always drill a couple extra 1/4" holes on the outside on the bottom to prevent that from happening, take caution when and if you drill your own extra drain holes not to go to deep and damage internal parts.
Oct 21, 2009 | Heating & Cooling
Always wondered why there is no drain hole at bottom rear of unit, so no condensation can drip away-now I find it not cooling well and the bottom front of the condenser is iced up. What to do?
Newer models of window AC's use either a flailing fan to spin the condensate out the sides of the AC (outside the window) or the heat of unit and outside air will evaporate the condensate.
Either way, any excess will spill over the back edge, hence the reason that manufacturer's recommend that the AC be installed with the rear of the unit slightly tilted down to prevent excessive condensate (water) from building up and/or coming inside the front of the unit.
As to the icing, it could be that the unit is undersized for the space you are trying to cool and can't keep up and is running all the time in an attempt to cool the air down in the room you have it installed in. Try letting the unit "defrost" by shutting it off for awhile (until the ice melts) and then keep the shades pulled and the door closed once you restart it. I also tell people to give the AC a chance to adjust by setting the cooling temp to around 10 cooler than the present temperature of the room.
It's really hard to completely cool down a hot room all at once, so unless you're willing to let the unit cool it down in stages, it might not be able to ever get a 90 degree room down to 65 degrees in one day, if ever. Give it a try and see what happens, otherwise, you might need a larger rated BTU unit to get the cooling you desire.
Jul 28, 2009 | Kenmore Heating & Cooling
My ac window unit does not seem to have any obvious drain hole or plug
DO NOT attempt to create a drain. As long as a window A/C unit is installed properly, (angled slightly down toward the rear) it will drain excess water over the rear lower lip of the unit should it get that high. Many models use some of the collected water/condensation. It gets lifted up by the fan blades to cool the coil.
Jun 21, 2009 | Frigidaire FAC126P1 wall/window Air...
Thru wall GE A/C
Hi, If this is a new unit I would check the filter first and make sure it is clean. Also check and make sure it is slightly tilted to the outside. If its an older unit it probably needs cleaned. Window units naturally create water in the evaporator area. The water is suppose to drain to the back of the unit to the condensing area where the slinger ring on the condenser fan blade slings it into the condenser coil making it more efficient. There is usually a drain hole to drain excess water from the back of the unit. Any dirt in the pathway of this water or the wrong tilt will cause water to build up and drip or blow out the front. Anything touching the evaporator coil allowing water to run down the obstacle into the wrong area will cause the same thing. reduced air flow will cause the evap to freeze which could also cause a water problem.
Aug 27, 2007 | Heating & Cooling
Heating & Cooling Logo
89 people viewed this question
Top Haier Heating & Cooling Experts
Tom Chichester
Matt
Matt
Level 1 Expert
Vincent Schnittert
Vincent Schnittert
Level 1 Expert
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
