Question about Homelite ZR10926 16 Chain Saw
I have a 3300 homelite chainsaw 16'bar,what is the oil,gas ratio?
  • dontbother10
    dontbother10 May 11, 2010
    There are many different model 3300 Homelite saws and I do not like to reply without checking the correct OM. Given what you provided I cannot locate the correct OM for your saw. IMO It will not harm a properly operating saw to run it on 50:1 regardless of what your OM says.
    The following is correct for saws manufactured for about the past 10 years.
    Oil Mix Ratio:
    Dolmar, Echo, Efco, Homelite, Husqvarna, Jonsered, Makita, Oleo-Mac, Red Max, Ryobi, Shindaiwa, Solo, Spear & Jackson, Stihl & Tanaka; all recommend 50:1.
    1 gallon of premium fuel to 2.6 ounces of quality 2-cycle oil.
    4 liters of premium fuel to 80 milliliters of quality 2-cycle oil.
    McCulloch, Poulan & Wen; recommend 40:1.
    1 gallon of premium fuel to 3.2 ounces of quality 2-cycle oil.
    4 liters of premium fuel to 100 milliliters of quality 2-cycle oil.
    Chinese chainsaws recommend 25:1.
    You can get an OM for your saw here:
    Homelite/Ryobi.com (Contact us)
    https://register.homelite.com/contact_us...
    If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
    Lou
    Thank You for using FixYa.
    Brigadier General:
  • 4,088 Answers
This should run well with 40:1 ratio using modern synthetic saw oils only. Always premix the fuel and oil in a can before adding to the saw, then agitate the saw to mix the old with the new. Hope this helps!
Posted on May 05, 2010
5 Suggested Answers
dontbother10
  • 2220 Answers
SOURCE: Have an older XL 16
Chain Saw Collectors Corner
http://www.acresinternet.com/cscc.nsf/ed1d619968136da688256af40002b8f7/87d4d17cf11a7c8b88256c280064b0b8?OpenDocument
XL-12 and 15 agree with your mixture, no 16 listed.
32:1 = 1 gallon of premium fuel to 4 ounces of quality 2-cycle oil.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Posted on Mar 19, 2010
dontbother10
  • 2220 Answers
SOURCE: chainsaw gas mixture ratio
An XL from that time frame recommends 32:1 here:
http://www.acresinternet.com/cscc.nsf/ed1d619968136da688256af40002b8f7/d4b1071a456ca76c88256cd6001cc24c?OpenDocument
If my saw it would be adjusted for and operate on 50:1.
Lou
Posted on Apr 03, 2010
  • 3 Answers
SOURCE: Gas/oil ratio mixture; chain oil lubricant
Call their customer service at 1-800-242-4672 there are options to choose for gas/oil ratio mixtures info.
Posted on May 26, 2010
  • 391 Answers
SOURCE: Gas / oil mixture ratio on 16
Most 2 cycle engines like 50-60 to 1 ratio
Posted on Jun 02, 2010
Need gas/oil mix for Homelite 330 10604A, HJ
To the best of my recollection the 330 is an older model saw and should be running about a 16:1 ratio. 8oz. of oil to 1 gallon of fuel. Hope this helps.
Note: You're always better being a bit richer (lower ratio) than you are leaner (higher ratio).
Feb 20, 2011 | Homelite Gas, 20 In. Bar, 46 CC, Chain...
What is the mix for my Homelite 16" 33cc chainsaw?
50:1 is the fuel to oil ratio. Never use petroleum oil (engine or boat motor oil). Always use a synthetic saw oil available from home centers, hardware stores and saw dealers. The bottles are usually graduated to various ratios for a gallon of fresh gas. Always premix in it's own container and shake the container thoroughly each time just before filling the tank to prevent oil starvation. Be sure to use bar/chain oil for the chain as well, and keep the chain sharp and well adjusted. Hope this helps!
Nov 14, 2010 | Poulan Pro 14" Gas Chainsaw 33CC P3314
Do not know what mixture or how to use
40:1 mixture for the fuel:oil ratio.16:1 will cause your saw to barely run(if at all) and if it does, will fog out every mosquito for 4 blocks. You can use any reputable 2-stroke oil, though stay away from outboard engine oil. Get the good stuff that says Stihl, or Husquavarnah, or something like that. Even the Homelite stuff is ok. The oil tank takes regular bar and chain oil.
May 30, 2010 | Homelite ZR10926 16 Chain Saw
May 26, 2010 | Homelite Consumer Products 9.0 Amp, 14 In....
Gas oil mixture
The header says that it is an electric saw which would only require bar oil. A 2-stroke gas engine, however, does require fuel mixed with a modern saw oil at 40:1 ratio plus bar/chain oil in it's own tank as well. Always premix the fuel and oil in a separate can and shake well even before filling the saw. Hope this helps!
May 24, 2010 | Homelite Consumer Products 9.0 Amp, 14 In....
I am looking for a homelite super 2 service manual
I have that saw. The manual states if you are using Homelite 2 -cycle oil read and follow the instructions on the package. If you use other than Homelite oil use 16 parts gasoline to 1 part 2- cycle oil, 1 gal / 8oz
May 12, 2010 | Garden
Want to fine gas and oil mixture ratio for Homelite 16 inch 33cc
Oil Mix Ratio:
Dolmar, Echo, Efco, Homelite, Husqvarna, Jonsered, Makita, Oleo-Mac, Red Max, Ryobi, Shindaiwa, Solo, Stihl & Tanaka; all recommend 50:1.
McCulloch & Poulan; recommend 40:1.
If you have more questions or need additional help please reply below and I will get back to you. Good Luck. HTH
Lou
Apr 25, 2010 | Homelite ZR10926 16 Chain Saw
Homelite chain saw --first time user--do you mix oil and gas--two compartments--is the first compartment for bar oil
In the compartment closest to the chainsaw bar, you need to fill this with chain and bar oil. Any good name brand will work fine.
In the other compartment you need to add a mix of petrol and oil in the ratio specified for your saw. If unsure, 25:1 petrol/oil ratio should be ok.
Jul 21, 2009 | Homelite Garden
What is the oil-gas mix for a homelite superxl chainsaw? For 1 gal.
16:1 ratio for most 2-stroke oil brands. A service manual recommends tro check the ratio marked on the bottle if using Homelite brand 2-stroke oil. For other oils, 16 parts of gas to 1 part of oil.
For 1 gal of fuel, that is 270cc of oil required to meet the 16:1 ratio.
Please rate this solution on FixYa!
Jul 16, 2009 | Homelite Garden
Homelite ZR10926 16 Chain Saw Logo
376 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
