Question about Activision Xbox 360 Guitar Hero II
The wire came out of my drum pedal.. is there a way to fix it without buying a new one???
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 60 Answers
Indeed Take it apart or push the wiring back into pedal and use tape or glue... use your child side ^^
Have fun.
Posted on May 09, 2010
Tip
Guitar Hero Drum Set Common problem
hello guys, i just wanna share with u one of the most annoying problem in the drums its the pedal, some times while u r playing on guitar hero drums hiting the notes its suddenly start kicking the pedal by it self and u cant continue playing because of that, what i want to tell u that before u react to that by start opening the pedal to fix it, you should first make sure that the pedal itself is damaged or not. just follow the steps ok.
1- remove the pedal and replace anything on the behalf of it like your headsets, just put anything in its place on the drums location and start a game and play and hit on the drums as hard as u can and see if the pedal is still kicking when ur hitting the red, green, blue drums if YES then its not the pedal its the drums itself, if not then u have to fix the pedal, i will tell u how later ok. 2-now after using some other device and finding that the pedal is ok and ur having this problem, just flip the drums and remove all the screw at the back ( trust me its so safe and easy) now open the drums and and go to the place where the pedal made to fit in u will see a chips and a screw in the middle, just screw lift ( most of times while ur playing and because of the heavy hitting on the drums the screw get relaxant so all u have to do is tight it up very well and it will solve the problem. 3- get everything back as it was and enjoy good and AWESOME play like if its brand new drums :))) hope i was very helpful
and about fixing the pedal if it was damaged flip and remove the first gray label its some kind sticky but its ok just remove it and u will find 2 screw remove then and go back to the front where the wire goes inside the pedal push it inside and then push it up it will be removed and there u will find 2 wires they may need to get fixed its easy weld the damaged wire and everything is ganna be FINE
on Feb 06, 2010 | Activision Guitar Hero
How can I unplug the cord of the foot pedal without breaking it?
In my experience they all come with the cord attached to the foot pedal and you plug one wire into the mains outlet and the other lead into the sewing machine. You should be swapping like for like, so if your has a hard wired lead, then the replacement should too.
If you unscrew the screws on the foot pedal, you should be able to see if it is hard wired or the wire is in a socket. If it won't come out, it is possible it has got hot and melted the plastic to lock it in place.
Feb 04, 2016 | Sewing Machines
Did complete brake job on 1997 Ford Escort wagon no abs rear shoes, drums, lines, wheel cylinders,even changed the block at the rear were the lines go in & out of. Front lines hoses pads, caliplers...
is brake pedal hard to push down without engine running ,if so proceed to step two and thats to start engine and then push on brake and if pedal softer to push then the servo is working ,now if excessive pedal travel with engine running then remove the rear drums ,make sure the outside lip is cleaned out and then adjust the brake shoes manually till they rub when you turn the drum ,this will cure it but remember that it has to bed in of course new pads brake disks ,new shoes and drums it has to bed in so give it a chance .
Aug 24, 2011 | 1997 Ford Escort
I Have a Yamaha dd55c electronic drum machine without the bass and Hi-Hat pedals. I am good with electronics and wondered how they are wired, or alternatively if they are available to buy from anywhere.
The pedals are domes with Piezo disc sensors. SImple two wire connection... the original pedals are really NOT very good... You might try to find regular pedals used for drum sets... they have a beater and sensor. They do cost a bunch.
May 07, 2011 | Yamaha DD55C 7-Pad General MIDI Digital...
Is there a guitar hero foot pedal wire replacement as the wire to hook up pedal to drums is broken? Can I buy just the wire or do I need a whole new foot pedal? And if I can buy the wire, where do I buy...
you will have to get a new foot pedal var fctb_tool=null; function FCTB_Init_62176759b3424b9cbe761805261ece8a(t) { fctb_tool=t; start(fctb_tool); } FCTB_Init_62176759b3424b9cbe761805261ece8a(document['FCTB_Init_4530bd1f4dd44a9eb15294e262e76316']); delete document['FCTB_Init_4530bd1f4dd44a9eb15294e262e76316'] var fctb_tool=null; function FCTB_Init_2d8b2df2973d4407bec8a4def7152a67(t) { fctb_tool=t; start(fctb_tool); } FCTB_Init_2d8b2df2973d4407bec8a4def7152a67(document['FCTB_Init_f65b37e3b16a4105b681111044638705']); delete document['FCTB_Init_f65b37e3b16a4105b681111044638705']
May 05, 2011 | EA - Electronic Arts Rock Band
No pedal on brakes, when I push brake pedal to the floor I hear a hissing noise in the cab of the truck (96 Dodge Ram 1500)
Had the same problem. I just replaced the brake booster unit, had a vaccuum leak out of where the push rod goes in. Solved.
Oct 13, 2009 | 1997 Dodge Ram 1500 Club Cab
Everything else works on the drum set besides the bass drum pedal
i had the same problem but when i hit the set as hard as i could the bass worked without using the pedal. there was a wire on the inside that was probly disconected, i took it back and got the warenty,
if you have the recept try asking if you can return it for a new one becouse it has problemes on the inside of the dumb set, i also knew it wasent the pedal tho becouse i had bought a new one at bestbuy. i took it back and got a new set and it works perfect no matter how hard i hit it
Mar 26, 2009 | MTV Games Rock Band Bundle for Xbox 360
I broke the wire to Guitar Hero foot pedal?
I would say that you could just change the wire. Or just go to e-bay or some store on line and just buy another one. They are not to much
good luck.
Good luck 2913
Dec 28, 2008 | MTV Games Rock Band for PlayStation 2
Dust on Drum message after installinng new Drum
Dust on drum refers to as you correctly stated the wire, it carries a electric charge that transfers the image. If the wire gets contaminated the electricity dont flow right so dust on drum is desplayed, you drum cart is faulty, they are not repairable items, go buy another then claim new/old one as faulty from them. Um aH.
Dec 14, 2007 | Brother DCP-7020 All-In-One Laser Printer
Activision Xbox 360 Guitar Hero II Logo
606 people viewed this question
Top Activision Video Game Consoles & Games Experts
Zhenya Ogorodnikov
James Wishart
ray gallant
Are you an Activision Video Game Console and Game Expert? Answer questions, earn points and help others
