Question about InFocus SP-LAMP-019 Projector Lamp for LP600, C17
InFocus LP600 - A vertical shadow on the Left-side covering about 20% of screen.
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 269 Answers
The light tunnel inside the "engine" is either out of alignment or the glue holding the tunnel together is coming unglued and 1 of the 4 sides has fallen in. There are 2 screws to adjust this if the tunnel is still intact. One or both screws can be accessed by opening the lamp door and then you have to remove a thin sticky cover. You will see 2 small screws that will have to be adjusted with a small torx (3) or allen. You will have to have the safety switch pushed in with something and adjust while the projector is on, using the most easily accessible screw, turn it towards the direction of the "banding". It should decrease. If not, turn the screw the other way. The screw that is not so easy to get to is for adjusting the banding the can appear across the top or bottom of the screen. If the banding gets worse or even starts to show diagonally across the screen, it is a good bet that the tunnel has collasped.
Posted on May 04, 2010
3" vertical shadow on left side of screen
Either (on this plasma) a damaged/bad sustain board for left side of screen or a problem with the Display panel--set by model number is 5-6 years old so may or may not be worth fixing.
Apr 10, 2012 | Panasonic TCP50S2 50 in. TV
The infocus LP600 won't power up
make sure the lamp door is engaging the safety switch. manually reset the lamp hours and reflash the software, if that don't work it's most likely the power supply.
May 11, 2010 | InFocus LP 600 Multimedia Projector
We have an LP600 with a black fizzy edge slowly sliding into the image field from the left picture edge?
sounds like you have a broken light tunnel. Its just a four sided mirror that has a broken side.
Mar 10, 2010 | InFocus LP70+ Multimedia Projector
I have an LP600. I'm on my 3rd bulb, and the two replacements bulbs have had shadows on one side or the other.
it's not the lamp. you have a light tunnel that is collapsing and needs to be replaced. you'll have to send it to an infocus service center. try av solutions. they're pretty good. www.avsolutionsny.com
Nov 18, 2009 | InFocus Proxima DP6155 Multimedia...
Projector image is too large for screen
There are no other lenses for the LP600 :(
Cheers
Jan 27, 2009 | InFocus LP 600 Multimedia Projector
Infocus lp600
Clean your air filters. The unit will shut down if it overheats. Ensure that all the filters are cleaned and replaced regularly.
Oct 04, 2008 | InFocus LP 600 Multimedia Projector
InFocus LP600
If the counter expired, then the reset is holding both volume keys down for 10+ seconds.
Feb 27, 2008 | InFocus LP 600 Multimedia Projector
Infocus 70+
We have had similar issue w/ multiple LP70+ projectors. The units get to be 1-2 years old and suddenly the right vertical edge of the display is distorted. There is usually a shadowed vertical bar that clouds about 3-5% of the horizontal space from the right edge.
What's the cause?
Nov 13, 2007 | InFocus LP70+ Multimedia Projector
InFocus SP-LAMP-019 Projector Lamp for LP600, C17 Logo
1,074 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
