Question about Whirlpool Cabrio WTW6600SBK
My three year old cabrio machine stops with 22 minutes remaining in wash cycle and display error"ld". I assume this has to do with wash size,however; this is happening even if there are very few item. Please note I have already had the motor replaced 5 months ago.
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Ld error code flashes when the water level does not change after the drain pump is on. To start with check the drain hose and/or drain pump from any clogs or blockages. If still the issue is not resolved and the pump seems to be fine then you have to check the motor again. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on May 03, 2010
Ld code. It won't drain. Not the drain pump (I changed) and not clogged pipe.
Slow drain code. How high is the outlet pipe ABOVE the machine?
Jan 05, 2016 | Washing Machines
How do i fix the Ld code on a whirlpool cabrio top load washer WTW6200SW2?
Troubleshooting Cabrio, Bravos, & Oasis Washer Problems Cabrio, Bravos, Oasis Washing Machine Overview
Washer Components
Diagnostic Mode & Tests ' Tips & Tricks Error Codes LF ' Ld ' uL ' oL ' Sd ' lid ' Po ' HC ' dL ' dU ' F1 ' F2 ' F30 ' F32 ' F40 ' F41 ' F50 ' F51 'F52 ' F53 ' F54 ' F70 ' F71 ' F72 ' F80 ' F81 ' F82 ' F83 ' F84 ' F85Always disconnect the washing machine's power supply before working on the appliance!Washing Machine Models That ApplyWhirlpool Cabrio Washing Machines
WTW6200SW0, WTW6200SW1, WTW6200SW2, WTW6200SW3, WTW6200VW0, WTW6200VW1, WTW6300SB0, WTW6300SB1, WTW6300SB2, WTW6300SG0, WTW6300SG1, WTW6300SG2, WTW6300SW0, WTW6300SW1, WTW6300SW2, WTW6300WW0, WTW6340WW0, WTW6400SW0, WTW6400SW1, WTW6400SW2, WTW6400SW3, WTW6500WW1, WTW6600SB0, WTW6600SB1, WTW6600SB2, WTW6600SB3, WTW6600SG0, WTW6600SG1, WTW6600SG2, WTW6600SG3, WTW6600SW0, WTW6600SW1, WTW6600SW2, WTW6600SW3, WTW6700TU1, WTW6700TU2, WTW6700TW0, WTW6700TW1, WTW6700TW2, WTW6800WB1, WTW6800WL1, WTW6800WW1 WTW7300XW0, WTW7340XW0, WTW7600XW0, WTW7800XW0
Maytag Bravos Washing Machines
MTW6300TQ0, MTW6300TQ1, MTW6400TQ0, MTW6500TQ0, MTW6600TB0, MTW6600TB1, MTW6600TQ0, MTW6600TQ1, MTW6700TQ0, MTW6700TQ1, MVWB300WQ0, MVWB300WQ1, MVWB400VQ0, MVWB450WQ0, MVWB450WQ1, MVWB700VQ0, MVWB750WB0, MVWB750WB1, MVWB750WL0, MVWB750WL1, MVWB750WQ0, MVWB750WQ1, MVWB750WR0, MVWB750WR1, MVWB800VB0, MVWB800VQ0, MVWB800VU0, MVWB850WB0, MVWB850WB1, MVWB850WL0, MVWB850WL1, MVWB850WQ0, MVWB850WQ1, MVWB850WR0, MVWB850WR1
Kenmore Oasis Washing Machines
110.27092603, 110.27092602, 110.27092601, 110.27092600, 110.27087605, 110.27087604, 110.27087603, 110.27087602, 110.27087601, 110.27087600, 110.27086605, 110.27086604, 110.27086603, 110.27086602, 110.27086601, 110.27082605, 110.27082604, 110.27082603, 110.27082602, 110.27082601, 110.27082600, 110.27072604, 110.27072603, 110.27072602, 110.27072601, 110.27072600, 110.27062604, 110.27062603, 110.27062602, 110.27062601, 110.27062600, 110.27052602, 110.27052600, 110.27042603, 110.27042602, 110.27042601, 110.27042600, 110.27032603, 110.27032602, 110.27032601, 110.27032600
NOTE: For All Error Codes
First press PAUSE/CANCEL once to clear the error code.
If code appears again put it through an automatic diagnostic cycle while you enjoy a nice soothing cup of tea. (Watch The Cabrio, Bravos, Oasis Diagnostics Video) This will reveal any stored error codes. Then you will be able to better use the repair guide to fix the major malfunction. Now put the tea down and get to work!
flood stop water supply hoses that may have closed internally?Is the drain hose sticking too far into your home's drain pipe (siphoning)?
Is the pressure transducer hose kinked, disconnected, or punctured?
Back to Top
Press PAUSE/CANCEL to clear display. pressure transducer hose kinked, disconnected, or punctured?
Press PAUSE/CANCEL to clear display.Washer Diagnostic Modes and Tests Washer Diagnostic Modes and Tests Washer Diagnostic Modes and Tests "Po" Pump Out (Lid Opened) Po flashes when the lid of the washing machine has been left open for more than 10 minutes. Close the lid to stop the drain pump.
"HC" Hot & Cold Hoses Switched This code will appear at the end of the wash cycle to indicate that the hot and cold-water inlet hoses are reversed.
"dL" Door/Lid Cannot Lock (Stored Error Codes F80, F82, F84, F85) Indicates the lid cannot lock.
Check for items caught in the lid keeping it from closing completely.
Is soap, fabric softener, or anything else keeping the lock from extending into the lid?
The control detects an open lid switch, or cannot determine if the lid is locked. Test the lid lock connection to the washer's control board and lid lock resistance levels.
Press PAUSE/CANCEL once to clear the code. "Ld" Washer is taking too long to drain water from the washtub
(Stored Error Code F32) Check the following:
Is the drain hose or pump clogged?
Is the drain hose higher than 96" to reach the drainpipe?
Is the Drain Pump Running?
Jun 07, 2014 | Whirlpool Cabrio WTW6600SBT Top Load...
The display panel is beeping and flashing LD...after the washer stopped running in the middle of a cycle
This error code indicates that drain times are longer than expected. Make sure the drain hose is not kinked or clogged. Straighten the hose for adequate water flow. Remove any blockage from the drain hose, drainpipe or utility sink. Use the U-shaped drain hose form on the drain hose, and secure the drain hose. See the Installation Instructions for details.
Click the following to learn more about proper drain systems for Cabrio washers. The example shown is for an impeller washer but is applicable to washers with agitators: whirlpool.com/files/usr/animations/ANM000014
Keep in mind that to remove the error display, press Pause/Cancel once; if does not work:
  1. Unplug the washer or disconnect the power for one minute.
  2. Plug in the washer or reconnect the power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, and both of the questions above have been checked, call for service.
Hope helps.
Sep 16, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
My whirlpool front loader cabrio stopped working with 12 minutes left in the cycle. The Ld code is flashing and I don't know how to fix it so that the load will spin and drain. How do I fix this...
Hello & Welcome to FixYa
Ld means long drain and is displayed when it takes longer than 5 minutes to pump out the water to a point where the pressure switch resets. To solve this problem make sure that the drain filter pump assembly located inside the bottom front panel is clean and after cleaning if the error returns then the pressure switch needs to be tested and if bad then it needs replacement. Please get back to me if you have any other questions.
Kevin
Jun 18, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
My washer has a LD in the minute screen how do i get this off
LD is an error code relating to poor drainage. Check the drain hose and/or pipe for a clog. It's also possible that debris could have worked itself into the drain pump, causing a delay in drainage. Fixing your drainage problem will fix the LD error code.
Jun 05, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Our Cabrio is showing "LD" in the display code and
you need to check your main drain pump for anything that may be restricting the water flow or stopping the impellar wheel from turning
Nov 21, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
What does error code LD mean?
"Ld" Long Drain "Ld" flashes if it takes longer than 5 minutes to pump out water to a point where the operating pressure switch resets.
Press STOP/CANCEL to clear the display. please remember to rank how this opinion has helped in your appliance situation and if you have any more questions please message me back thank you again and have a nice day
rickead1
Aug 24, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Ld code on my whirlpool cabrio, won't drain water, what do you do?
Hi There
OK here's something you can read to help you with. I hope this helps.
Ld Long Drain Ld flashes if it takes longer than 5 minutes to pump out water to a point where the operating pressure switch resets.
Press STOP/CANCEL to clear the display. Thank you for writing to fix ya.
Best regards Richard
Dec 11, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirpool cabrio error ld
Hi
Error ld means Long drain. Ld flashes if it takes longer than 5 minutes to pump out water to a point where the operating pressure switch resets. Press STOP/CANCEL to clear the display.
If it doesn't clear the error then check whether your drain is kinked or clogged with lint and debris. If not then there is definetly some problem with your drain filter and/or drain pump.
Please do rate the solution as FixYa and Revert for further assistance.
Thanks
Rylee
Jul 04, 2009 | Whirlpool Washing Machines
Whirlpool Cabrio WTW6600SW1: Won't drain
The washer drew half a tub of water on the "Bulky items" cycle, and stopped. All the lights on the cycle dial light up and flash, the machine beeps and the me error message in the "estimated time remaining" field is "Ld". I've tried to shut the machine down and change the cycle to "drain and spin" but it will not agitate, won't drain or spin.
Sep 05, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio WTW6600SBK Logo
44 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
