Question about Garden
I have been given a Power Devil petrol Mower, but it has the wrong plug in it. Can anyone tell me the correct one Mpdel no PDGPLM4235 3.5 HP. Thanks
4 Suggested Answers
  • 22 Answers
SOURCE: starting my petrol mower
depending on age of machine set the throttle to maximum revs,and pull the starter cord but newer models have a primer button located on carburettor which is locked just under air filter (black or red colour) push it three times( you should hear it inject fuel) and then pull starter cord,some of these engines have a pre-set throttle ,main concern is that if it has not been used for some time you will need to clean carburettor out,replace diaphragm and remember to use fresh fuel(not older than 90 days) this should cure your problem
Posted on Mar 30, 2009
MNfisherman
  • 11896 Answers
SOURCE: nannie what can be wrong with my power devil
Check air filter, check screen in bottom of fuel tank,
New spark plug and also check the spark.
If there is a weak spark, the coil may need to be replaced.
If you have good spark, clean air filter, and clean fuel tank screen, then the carberator will need to be pulled of and cleaned out with solvent
Posted on Jun 23, 2009
  • 110 Answers
SOURCE: i cannot start my Suffolk punch 43s petrol mower,
As far as I can tell, there are no downloads available. I eventually gave up and bought a copy from a mower museum. You will need to know the approximate age, as several diferrent engines have been fitted.
If you have the old red engine, the choke lever should be at right angles to the line of the carb IE pointing straight back.
The newer green engines are usually marked, but of not, remove the air filter and look into the carb throat. When the choke flap is CLOSED, the choke is ON IE cold start position.
As soon as the engie starts, move the choke to approx 50%, then fully open after 30 seconds or so.
If in good order, these engines are a 1-pull start. Fit a new plug, then spray WD-40 or similar into the OPEN carb thoat. If there is no sign of life at all, you have a coil failure (or possibly a points problem if it's ancient).
Posted on Oct 03, 2009
Hi, i have a BSA ECCO16 petrol lawnmower, and I have been looking for a replacement blade for a few months, the blade I have at the moment is a power devil 16'' blade with tails, it is cutting
talk with a mower shop
from your description you have a solid bar attached to the hub on the crankshaft with a cutter blade at either end
the cutter blades should have the rear section turned up to create an air flow to throw the gras out the back
you can replac the single blade with a disc that has 4 blades each turned up at the back and that makes cutting easier and a higher rate of discharge out the abck
May 12, 2017 | Garden
Petrol mower won't start
Could be any number of things, start with fresh fuel and a new spark plug, then check the flywheel key has not sheared, make sure the blade is tight, if not better it may be the valves have burnt and are now not seating.
Apr 15, 2012 | Garden
My petrol lwan mower won't start! I have checked the spark plug and cleaned it, checked the air filter and have also cleaned it they are fine. I have also taken the carburettor to bits and have cleaned it...
When you sprayed the quick start into the thing and it started and ran out, I think the answer sits here you also said you pulled the carb apart to bits it is apparent to me you did not do a thorough job!! Just the fact that you stated that it has not been started for two years tells me that you are having petrol movement problems. For one thing to get started check all the little orifices associated with petrol movement this is surely where you will find your answer to get the machine running, I know this for a fact. You will receive joy just as soon as all your do diligence is finished. If you cannot find the choke on your machine you surely cannot buy one for it. Maybe this repair stuff is just not your thing, maybe as your neighbor before you, you should maybe go shopping and then you will achieve the full amount of joy you are in such desperate need for. Going from electric power to petrol power is a total different world.
I think that now my answer to your question is almost as long as your question, so I will be stopping because my fingers are tired of all this typing, GO BLACK HAWKS! Good luck PAL
Jul 04, 2010 | Mtd 22" Yard Machine Push Mower
I cannot start my Suffolk punch 43s petrol mower, can anyone tell me how the choke should be set?Or where can I download a free instruction manual.
Sep 18, 2009 | Garden
Nannie what can be wrong with my power devil petrol lawn mower the engine wont keep running then cuts out petrol and oil ok
Jun 23, 2009 | Mtd 22" Yard Machine Push Mower
Non starter?
the fly wheel has rust on it take the cover off and sand the magnet and coil to get spark
Jun 05, 2009 | Garden
Garden Logo
548 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
