Question about Toshiba Satellite A10-S403D PC Notebook
OVERHEAT PROBLEM HAS BEEN DISPLAYED ON THE SCREEN AND I WAS ORDERED TO SHUT DOWN THE UNIT
    Guru:
  • 1,705 Answers
Its probably your CPU overheating.
Disconnect the power, remove the battery.
Try and take any plates off the bottom of your laptop.
and clean out any dust collected there with a bristle paint brush.
Make sure all vents are clear and try again.
Posted on May 03, 2010
What is the error code E5 on bluestar air conditioners mean
Problem
Overheat of inverter compressor motor
Cause
Shortage of refrigerant amount Leakage of four way valve
Defect of connector contact
Aug 14, 2014 | Heating & Cooling
My GE Spectra Oven will not shut off
You will need to replace the control board/display since the oven switch is built into the control board. Here is that part to order.
Feb 13, 2013 | GE Spectra JBP78 Electric Kitchen Range
Fan stops spinning motor then overheats and shuts down unit-can i buy a replacement motor
If you'd like to price the cost of a new compressor motor and order one. Click on the following links.
http://www.partlinx.com/haier.asp
http://www.appliancefactoryparts.com/search/index.php
Once you price it, you may decide a new dehumidifier is in order.
Hope this helped you. Please let me know. Thanks.
Jun 18, 2011 | Haier HDN455 Dehumidifier
When im welding the xmt 304 machine will arc out and the volts will say HE.L and the amps will say P.5 its like it loses ground what does the volts and amps mean when it says that.
Help 5 Display Indicates the right side of the unit has overheated.
The unit has shut down to allow the fan to cool it. Operation will continue when the unit has cooled.
If unit overheats, output stops, a Help 5 message is displayed, and cooling fan runs.
Wait fifteen minutes for unit to cool.
To avoid this problem Reduce amperage or voltage, or duty cycle before welding.
Jan 22, 2011 | Miller Welding Tools
The Holmes Comfort Temp ceramic heater works fine on Low setting, but once it is set to High temperature the illuminated digital display fades out and the unit turns itself off. Unplugging and letting the...
These heaters were not designed to be serviced in the field. If it's not over a year old, it may still be in warranty. Contact Holmes through there website www.holmesproducts.com for more info.
Jan 19, 2011 | Holmes Products HCH4953-U Ceramic Compact...
Amcor aircon 15000btu
Have you tried pushing the reset button on the power plug? If the unit overheats the reset button will click on and the a/c will turn off. In order to turn it back on you will have to push the reset button.
Jul 09, 2010 | Amcor PLM-14000E Portable Air Conditioner
Shuts down after I turn it on
had this with an LG unit. Repairer told me the overheat sensor was shutting down unit. so he added extra heat dispersal copper plates to the inside and charged me £50.
AndystUK
Aug 30, 2009 | Harman Kardon AVR 225 Receiver
Toshiba A65-S1062 - This laptop overheats and shuts down.
I bet that you had your laptop on all the time.
Your heat sink is saturated with dust and grit.
you may have to open up the unit and use a can of dust remover to clean the fins on the heat sink out. it is causing your CPU to shut down bucause it is becoming overheated.
Happy Fixing =)
Jul 11, 2009 | Toshiba Satellite A65-S1062 Notebook
Toshiba boots up power light stays on and shuts down, bad m/b ?
I own a Laptop Toshiba Satellite A75-S2131.
This series have a problem with the cooling flow to the processor.
The processor overheats and the laptop shuts down.To solve this particular problem you must tear down the laptop and clean up the processor heatsink (you will find it totally plugged or partially dirty).
Find in the internet the step by step instructions (with photos) for dismantling this laptop. Do not forget to apply thermal paste between processor & heatsink.
I hope this solution helps.
Posted by MCampos
Mar 12, 2009 | Toshiba Satellite A75-S209 Notebook
Sony vaio VGN FS 570 no display
Try having your battery tested. There may be not enough power to run everything on your comp.
Anotherthing to consider, if your CPU fan isnt working the bios wont start the O.S. as the CPU will overheat and shut down automatically. Good Luck
Oct 14, 2008 | Computers & Internet
Toshiba Satellite A10-S403D  PC Notebook Logo
70 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
