Question about Karcher K 5.85 M Electric Pressure Washer
My Karcher pulses when on standby,stops when i use the trigger,but it also seems to have lost pressure.Is less than 6 months old but have lost receipt!
    Problem Solver:
  • 15 Answers
Is there a leak from the bottom ?
If so Problem, the leak is from the seam of the Manifold housing. There is a small crack in the seam. A design weakness.. A New Manifold Complete Replacement approx. $61.03.
If not you may replace the Pump Manifold Housing from Karcher, or locate a local Karcher Service Center.
If under 1 year old, and you can find a receipt,Karcher will replace the entire Pressure Washer under warranty.
Posted on Jul 14, 2010
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 107 Answers
I fixed mine works good easy too watch my video step by step i put it on youtube
http://www.youtube.com/watch?v=8XDPDhg_acQ&list=UUiF9Qw4CmLuBqWFGanj1KIA&index=14&feature=plcp
Posted on Aug 25, 2012
How do i stop it from pulsing?
Getting to much air to carb probably.
Jul 11, 2015 | Karcher Garden
I have no pressure and the pump surges when i release the trigger on my electric karcher modle k 2.360
If you have a Karcher then you should always post your machines barcode.
Because you have the low pressure and pulse this will be the valve block. Your machine has 3 piston and each has 2 valves (inlet and outlet). Because you dont have the barcode, i cant be sure if you will buy a valve kit of 6 valves or a pre-assembled manifold block.
it could be this machine and spares :
http://www.sparesgiant.com/cleaning-equipment/pressure-washers/karcher/k-series-parts/k2-range/k2-36m16724300/
The karcher barcode is on a silver sticker and is usually 15 digits long. Example 156987400000123 is actually model 1.569-874.0 and serial number 00123....
Sep 01, 2013 | Karcher K238CCK 1600 PSI 13 GPM Electric...
My washer makes a loud pulsing noise when not being used,as soon as I pull the trigger it works fine.
sounds like your unit has a bypass problem either needs adjustment or replaced
Oct 14, 2012 | Karcher Garden
Karcher KB4040 pulsing when trigger closed and has lost about 50% of its power
Just google " stripping down Karcher KB4040" A YOU TUBE CLIP will show you hiw to fix it and what tools you need
Jun 05, 2012 | Garden
I HAVE AN OLD, ABOUT 15 YEARS,PRESSURE WASHER MODEL 270M. RECENTLY IT STARTED TO PULSATE WHEN I ACTIVATED THE WAND CONTROL. IT PULSES AT THE RATE OF ABOUT 1 SECOND INTERVALS. IT WILL NEVER STOP AND RUN. I...
To me this problem sounds like there is something wrong with the pump.
I think its better to buy another Karcher machine and get the 12 month warranty. As with old pressure washers you could spend money on certain parts to fix the machine but a few weeks/months down the line a different part of the machine could break and then you end up having to buy a new machine anyway.
Also being 15 years old you would have to check to see if parts are still made for the machine. This is because once Karcher discontinues a machine parts for that machine are manufactured for 10 years from that discontinue date.
Jan 17, 2011 | Karcher Garden
My Karcher 2.99 starts and stops, (pulses) when th...
Is liquid leaking from the base, when the Pressure washer is on ?
I have the same Problem, the leak is from the seam of the Manifold housing. There is a small crack in the seam. A manufacturing defect.. A New Manifold Complete Replacement is $61.03, about the half the price what I paid for this pressure washer at Walmart... :( If under 1 year old, and you can find a receipt,Karcher will replace the whole Pressure washer under warranty.
May 21, 2010 | Karcher K2.26MR Electric Pressure Washer
I have a Karcher KB5050 it started to pulse when the trigger stopped
Is there water leaking from the bottom ? If so, then you have a leak in the pump. Bad seal or crack in the Pump.
If under 1 year old and have a receipt, Call Karcher for a warranty replacement.
May 14, 2010 | Karcher 1750 psi Electric Pressure Washer
Loss of preasue and pulses in standby mode
Check the oil. This is what happens when it is low on oil with my pressure washer. Kind of a safety feature.
May 15, 2009 | Karcher Garden
Pulsing and lost pressure
depending on amount of use i have found failures of the piston spring and retainer which are located inside main housing of pump,these cause pulsing and no pressure,you need to remove pump head and face plate to get to them,hope this is of help
Mar 28, 2009 | Garden
Karcher KB 499
Hi the pump surges when there is a leak on it find the leak that should sort your prob.
Hope this helps. Sean
Feb 17, 2008 | Karcher 2500 PSI Pressure Washer
Karcher K 5.85 M Electric Pressure Washer Logo
2,821 people viewed this question
Top Karcher Garden Experts
John Trevino
Are you a Karcher Garden Expert? Answer questions, earn points and help others
